Question about Brother HL-2040 Laser Printer
I have a newer computer. I have connected everything. The printer is on and has paper. It does not print. What do I do. edalys@rogers.com
    Novelist:
  • 136 Answers
Brother, as you mentioned that its a newer computer so have you installed the drivers for this printer in this new computer.
If not;-
You can install the your laser printer driver by the disk which came with your printer. still if you are not able to print.
Try to print a test page from printer console as well.
if you are able to print that means printer is working fine and something wrong with software part or cable.
When you print if you are getting any error message then please also mention that in next post then it will be easy for us to fix it.
Posted on Mar 17, 2011
    Genius:
  • 1,114 Answers
Have you installed the printer driver on your pc? If not you can go to the Brother website, and download the driver for your printer and operating system on your pc. Once it is installed, you will be able to print.
My printer won't print, it says it's disconnected but everything is plugged in. I rebooted my computer, unplugged everything and let it rest but it is still indicating "not connected"
So what is the connection ? USB or Wireless or Ethernet ?
Did you try connecting though other ports ? Connectivity, standard
  • 1 Hi-Speed USB 2.0
  • 1 Host USB
  • 1 Ethernet
  • 1 Wireless 802.11b/g/n
see wireless setup shown in the below video at 24.34 minute mark
HP Officejet Pro 8610 Unboxing Setup
Mar 16, 2016 | HP Officejet Pro 8610 Inkjet Multifunction...
I have a cannon ir3300i printer is not taken print..computer says out of paper printing..but paper is available in printing..how to resolve this query mail id internetstation2012@gmail.com
try turning off both devices - start you computer first, then start your printer and see if that fixes your issue. if not try again this time leaving out the plug that connects the computer to the printer and then when the computer is turned on turn on the printer then plug it into the computer
Aug 08, 2012 | Canon (6981A002AA) for imagerunner 2200,...
Mfc-7420 says paper jammed/ and no feeding paper -all faulse messages-no paper there jammed
This is a huge problem, not only with the MFC-7420 printer, but literally every printer known to exist! The best way to solve this problem is to look at where the printer is connected. If it's connected to your computer, it may be trying to print something from there still, causing the information that the printer is receiving to become jumbled up and confused. I'm going to go step by step to try to help you out of your printer misery:
First: Unplug the printer from your computer entirely. Then unplug your printer's power source.
Second: Re-plug back in your printer's power source, and wait for it to turn on fully.
Third: Double check to make sure everything is working fine aside from the non-existent "paper jam."
Fourth: Re-plug back in the printer to the computer, and cancel all scheduled prints that are queued on your computer.
Lastly: Retry printing!
Hope this helps.
-Anonymity
Feb 24, 2011 | Brother MFC 7420 All-In-One Laser Printer
It stopped printing black, I cleaned everything then it stopped printing color. Then it will not print anything. I have ran the color and black clean up program at least 10 times, nothing works. Any...
The following may work: remove all the ink supplies. Remove the printhead and soak it for about 5 minutes in 0.5" of very hot water. Gently blot the printhead on a soft damp paper towel to remove the excess water, then replace in the printer and then reinstall the ink supplies.
Feb 10, 2011 | Canon PIXMA iP4000 InkJet Photo Printer
When i print ,I get this error 'Manual Feeder Paper Empty
You are most likely getting this message because of a paper size mis-match. For example, you are sending a print job as letter size but your printer is set to or has a4 size installed. When the printer sees that the print job is not a matched size to the paper in the tray, it will look to the manual feed tray for paper to print on, hopefully the correct size. Make sure your paper setting in printer properties on your computer match the paper in the printer and the print job "page setup" is also the same size/
Oct 06, 2010 | Samsung SCX4623F Laser All-in-One Printer
We have an HP Laserjet 2420 PCL 5e - it prints perfectly on regular paper but will not print envelopes. We have to manually feed the envelopes on the tray but it only prints gibberish. I have rebooted the...
This is not a printer problem. You have a computer problem. In ALL cases, the printer is told what to do from the computer, it does not report TO the computer.
Mar 10, 2009 | HP LaserJet 2420 Printer
I have this printer that is networked in a small office with 4 other computers. The person who installed this printer has left the left with all its documentations and the user guide. Someone has printed...
restart the Windows printing services, if they run Win2000 or newer. Go to Start > Run, type CMD, hit Enter, in the command dialog that opens, type NET STOP SPOOLER and hit Enter and it should tell you the service has stopped.
then type NET START SPOOLER and hit Enter and the service should start again.
Do this on all computers until printing stops. If printing doesn't stop, power off the printer and its server (unless it's connected to one of those pcs in which case you already restarted that service).
Jan 12, 2009 | Xerox DocuPrint N2125 Laser Printer
HP all-in-one 2200 series printer doesn't work w/Vista
For scanning you can go to Paint/ File/ from scanner or camera
Regards from
amir.tadros@rogers.com
Dec 16, 2008 | HP PSC 2210 All-In-One InkJet Printer
I have an officejet 6110xi all-in-one printer. I want to connect to a second computer in my network
HI Oliver
Do you want to move the printer to the other machine completely with scanning features or do you just want to print. If you want to move the whole printer, you will need to install the drivers and everything onto that machine.
Otherwise just share the printer on the current machine and install the shared printer via the add printer network section
Thanks
Roger
Nov 13, 2008 | HP Office Equipment & Supplies
Printer not responding...
try to check your setting for the printer before printing. maybe you have paper jam try to check feed papers. press the power if this is blinking. If the problem persist just restart your computer. Sometimes thist problem needs restart to continue printing.
Nov 07, 2008 | Microsoft Office Professional 2007 Full...
Brother HL-2040 Laser Printer Logo
20 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
