Question about General Cycling
The Deraulier. I put it back on but everytime i turn the crank shaft, the chain jams in the reraulier.
    Brigadier General:
  • 8,546 Answers
Easy way to remove timing chain on 20008 chevy impala ss with the 5.3 engine
the book shows it as a single chain from the crank to the cam shaft at the base of the V of the block
the easiest way to remove the chain on these is to undo the cam bolts and slide the can sprocket and the crank sprocket together
if you put on the crank sprocket it is difficult to get the cam gear back on the end of the shaft
so pull together
line up the marks and install together
Nov 14, 2017 | Cars & Trucks
I have a 96 F150 it backfired and went dead now it won't crank please help
What do you mean it won't crank ? Is it a no crank - no start or does the starter spin the engine an it won't start an run ?
Oct 24, 2015 | Cars & Trucks
Timming chain broke
place no 1 piston at TDC compression stroke. There are procedures for the timing of the balance shafts but if it is only the timing chain I will go to that
Align uniquely coloured chain link with intake camshaft sprocket timing mark-- INT--. ( this will be pointing at the 2 o'clock position)
install timing chain and sprocket as an assembly
align first matching coloured chain link crankshaft timing mark (5 o'clock position)
align the second matching coloured chain link with exhaust cam shaft timing mark--EXH ( at the 11 o'clock position
There is a special procedure to reset the balance tensioner and it is different to the timing chain procedure.
To reset cam shaft timing chain tensioner push piston fully and turn clockwise until locked
Once the tensioner has been compressed ensure the distance from end to end is 2.83 inches . If not repeat the resetting process
vehicles 30.000 miles the tensioner is released when the engine is first started . In vehicles over 30.000 miles manually release tensioner by tapping the plunger
Note cam shaft and crank shaft sprockets bolts MUST only be used once. If you want details on the balancer chain procedure then make a comment in the box
use tension wrench and a degree gauge
cam bolts are tensioned to 63 ft lbs + 30 degrees
crank shaft pulley is tensioned to 74 ft lbs + 75 degrees
Feb 02, 2014 | 2003 Saturn ION
My Husqvarna 350 bogs down and is not turning the chain.
something is pinching the chain when you have the side cover on. either the bar isn't sitting flush to the saw or you don't have the chain in the sprocket correctly and that is causing it to bind
Jan 27, 2013 | Husqvarna Garden
Setting of timing chains
Get Ford timing tool kit, part = otc-6488 (For about $119 USD on eBay)
4 timing chains (3 front including the optional balance shaft chain + 1 back)
2 cam guides (1 front + 1 back)
2 oil tensioners (1 front + 1 back)
1 jackshaft tensioner (1 front)
1 jackshaft guide/cassette (1 front)
1 balance shaft tensioner (1 front) (will probably be ok, so dont replace it)
1 balance shaft guide (1 front) (will probably be ok, so dont replace it)
new sprockets + bolts + gaskets etc.
new spark plugs + throttle body cleaner + lithium grease spray + oil change
head gaskets
some of these parts (the front stuff) can be obtained as a primary timing chain rattle noise kit Part# = 2u3e-6d256-** ab for 4*4 & bb for 2*4.
The kits also have later part numbers for us$ 76 @ http://www.fordpartsonline.com
My parts order (without the balance shaft stuff) was:
$76.04 KIT-TENSIONER TIMING 2u3e-6d256-ab
$47.93 Engine, Camshaft and timing, Timing chain, TIMING CHAIN, Explorer, Mountaineer, Rear - 4.0L SOHC - 4.0L SOHC
$57.36 Engine, Camshaft and timing, Chain guide, CHAIN GUIDE, Explorer, Mountaineer, Jackshaft To Cam - 4.0L SOHC - 4.0L SOHC
$103.22 Engine, Overhaul gasket set, OVERHAUL GASKET SET, Explorer, Mountaineer, Upper (Valve Grind) - 4.0L SOHC - 4.0L SOHC
$28.93 Engine, Camshaft and timing, Tensioner, TENSIONER, Explorer, Mountaineer, Upper - 4.0L SOHC - 4.0L SOHC
Its worth mentioning that this procedure is not enjoyable at all and should be undertaken with at least 8 full days to completion (I recon you could do it in half the time the second time).
It is basically on entire engine re-build with both heads off and the engine out of the vehicle.
It is not possible to do the rear chain or sprocket with the engine in the car as the flywheel needs to come off + at least 1 head, but it is possible to do the front primary chain and or front cam chain with the engine in the car.
You will be a ford exploder and timing expert after you do this - the main reason should be the love of your American built vehicle. Its a solid car - except for the plastic guides!
Disclaimer Note: This is how i successfully did the job, but i am not a ford mechanic and don't hold me responsible if this does not work for you.
Timing Overview
A Small Sprocket on the crank turns a larger (2 to 1 ratio) jackshaft sprocket that is in turn connected front & back to the 2 camshafts.
Thus a 360o turn of the crank will turn both the camshafts 180o.
Firing order is 1-4 2-5 3-6, Right side numbers 1,2,3. Left Side = 4,5,6.
At TDC pistons 1 & 5 are fully raised, thus 1 is about to spark & 5 is evacuated.
The engine will turn freely (no piston to valve contact) with the cams 180o out, it will even run (roughly) with 1 out 180o, any other settings may cause major damage to the valves.
The 2 cam shafts come with timing markings, "yes" real timing marks that anyone can use (even without special tools) to ensure correct timing.
The way to time it is to ensure both the off centre cam shaft slits are level/flat with the head.
With the engine at TDC both the cams need to have the off centre slot in the same position either up and level or down and level.
It is super critical that both the camshafts are 100% in sink with each other, i.e. not a few degrees off, the engine computer can compensate for crank timing but not engineering failure.
Be warned the camshafts can turn easily fast & hard by themselves as a few springs are compressed at TDC, I got my finger jammed and its still healing + if the engine is not at TDC you may damage a valve.
Now heres the hard thing that you will need special tools for - if you need to change the timing, you will need to be able to undo the cam sprocket bolt on both cams & these are done up real tight.
There is a tool that you attach that has 2 pencil thick shafts that fit into the sprocket and prevent it from turning - then you need to put about 90Nm of force on the bolt (remember the rear one if LHT)
For the $money$, its well worth getting yourself the tool kit - it will save you hours in the long run. Search eBay for otc-6488 should be US $119 - then sell them again for say $100.
There is also a tool version of the oil tensioner in the kit that screws right in and puts the correct amount of force on the chain + guide, to enable you to do up the cam bolt with the chain and sprocket in the right spot on the cam.
Dec 20, 2010 | 2003 Ford Explorer
Timing alignment for 2200
put it on tdc
and go from there
tdc top dead center
May 09, 2010 | 2001 Chevrolet Cavalier
Stihl ms290 chain runs constantly even when idling and when u put the chain brake on it kills the saw
The centrifical clutch is probably rusted (or has a broken spring). You can try a small amount of WD-40 inside the clutch to see it that will break it loose.
Also, be sure that the chain tension adjustment is not too tight!!
Oct 10, 2009 | Oregon Scientific Oregon Chainsaw chain...
Cycling Logo
Top General Cycling Experts
Michial Gueffroy
John Egan
John Egan
Are you a General Cycling Expert? Answer questions, earn points and help others
