Question about HP LaserJet 2840 Printer
At the onset of copying one side of the paper is fed into the machine faster than the other side and the paper then jams.
    Master:
  • 325 Answers
You have worn pickup rollers, as a temporary measure you could take them out and clean them with rubbing alcohol and a fine sandpaper. but idealy replace them.
it could also be a jam that is blocking check the place where feeding is slow and ensure there is no dust or paper fragments in there.
Posted on Mar 17, 2011
Paper jam
  • Discover the location of the jam. Carefully open the cover of the copy machine and the paper tray to see exactly where the paper is jammed.
  • 2Turn off the copy machine before pulling out the paper.
  • 3Pull the page out, the opposite way it is fed into the copier. Pull the jammed sheet out gently. If you tug too hard, the paper may rip.
  • 4Check for any paper fragments and clean up any torn pieces.
  • 5Check the roller where the jam occurred to be sure none of the copier parts are loose or broken. The roller should be smooth all the way across with no possible snags.
  • 6Replace the cover and paper tray and turn the machine back on.
  • 7Press the button to cancel the paper jam message. This button will vary among copy machines. The display will tell you which button to push
    see the diagram for copiers and let`s the way of paper for troubleshooting .
  • 12_19_2011_4_33_16_pm.jpgsincerely. Merry Christmas.
    ernesto cuadra
    managua, nicaragua. c.a
    Dec 19, 2011 | Office Equipment & Supplies
    When I go to print or copy the machine makes a loud clicking noise and then says paper jam. Brother MFC - 8460 N
    The loud clicking noise is either the toner cartridge or the paper feed. If the jam occurs in the drum and toner cartridge then I recommend changing the toner.
    If the paper is not being fed at all then you need to have the paper feed kit replaced.
    Thanks,
    Pat
    May 11, 2010 | Brother IntelliFax-2820 Laser Fax
    Paper jam/no paper fed
    make sure the photo paper is in glossy side face down,
    set the paper type to photo.
    If it keeps jamming it's because the paper feed is probably dirty and not taking the paper properly
    Mar 24, 2010 | Brother DCP 130C All-In-One InkJet Printer
    Won't photocopy / warning light flashing /
    The paper feed system is worn (rollers, and separation pad). What is happening, is extra sheets are being fed into the machine primarily because the separation unit is not doing it's job properly. So rather than just one page at a time being fed, it is allowing an extra sheet to "creep" in intermittently, causing the jam. And the indicator you are seeing is the "jam" indicator.
    Jul 16, 2009 | Canon PC170 Copier
    Both our brand new copy machines SHARP M316 have problem with the
    first thsing to check is the side guides for the paper make sure they are set against the paper being fed through if not the paper will be pulled through at an angle and this can cause your problem you can alson get a slightly heavier paper and put that through to see if you have a jam..did you remove all the packing tags and paper protectors
    Jun 15, 2009 | Office Equipment & Supplies
    AL-800 cannot make copies jam light remains on with no jams
    First, is the paper being fed at all? If the paper is being fed and jams at the same location then a senor, actuator or switch is bad, out of place or broken. If the device will not clear the jam light, completely power down the device, unplug from wall, let set about 30 sec. to 1 min. and then replug in and see if it reset. If the device did not reset then again a senor, actuator, or switch is out of position ( being held up in the paper path). If the paper does not feed at all then the feed section is the problem. Clean the feed tire (s) the rubber restorer or a high alcohol base cleaner. Listen to hear if the feed tire (s) are even turning. If feed is not turning then it could be clutch, motor or board problem.
    Jan 04, 2009 | Sharp AL-800L Copier
    Paper Jam in Duplex mode when printing more than 1 sheet
    check between the rollers there will be small bits of paper jammed in that is the reason.
    Sep 09, 2008 | Minolta magicolor 2350 Laser Printer
    HP LaserJet 2840 Printer Logo
    169 people viewed this question
    Ben Johnson
    mukhtar21 shaikh
    mukhtar21 shaikh
