Question about GE Washing Machines
Washing machine spin cycle works sometimes / clutch is good/ belt is good
  • 6 more comments
  • Bruce Stevens Mar 17, 2011
    I thought I listed the GE Model as F3200Y2WW top load machine
    GE Model #F3200Y2WW spin cycle does not work
    corrected model # S3200Y2WW Jumping the lid switch did not work. Please advise.
    The pump works fine, the tub does not spin to get the water out of the clothes. I suppose the final alternative is the control switch?
    There is no noise at the spin cycle. Are you suggesting the timer switch? Is there any way to check it; as it cost $138.20.
  • Bruce Stevens Mar 21, 2011
    I tested the timer and determined it was bad. Now the tub will try to spin but won't. I jumped the lid door and gave it a little help to spin. I haven't checked anything else at this time. I'm assuming the stuck tub, transmission, etc. broke the timer spin cycle. What's next?
    i replaced the timer and the tub will not spin. It wants to spin but will not start to spin on its own. What's next?
    I truly believe it is the transmission, Is there any other part that I should check? I'll probably be checking it out this evening after work. Time permitting.
  • 4,323 Answers
Hi
It seems that the issue is with the lid switch going bad and should be replaced however, please post back with the model no for further assistance.
Daniel
Posted on Mar 17, 2011
  • 5 more comments
  • Daniel Scott
    Daniel Scott Mar 17, 2011
    Though the model no you gave me is not correct but you can try to take out the lid switch and then try to jump start the washer, if it spins then replace the switch.
  • Daniel Scott
    Thanks for the model no...check this diagram...if you have already checked the clutch and also the lid switch then you should have also checked the drain pump assembly for any clogs...if not then check it first and clean it completely...after this if the issue returns and the pump is working fine then replace the control as everything else seems to be working fine.
  • Daniel Scott
    if the pump wont spin and is not making any noises then yes replace the control
  • Daniel Scott
    Yes you can test it, once you have taken it apart then inspect the contacts of the timer. If they appear to be
    burnt or damaged the timer is faulty. If not then set the scale on a volt-ohm
    meter to the RX1 setting to test the timer contacts for continuity. There is a
    cycle sequence chart stamped on the side of the timer or attached to the back
    of the control console. Refer to the chart for what contact points to test for
    any cycle. Touch the two probes of the volt-ohm meter to the contact points to
    be tested. Turn the dial of the timer to the appropriate cycle that is being
    tested. There should be no continuity reading on the volt-ohm meter during the
    test. If there is a reading on the volt-ohm meter, the timer is faulty.
    Hope
    this helps...please post back for further assistance.
    Daniel
    Yes you can test it, once you have taken it apart then inspect the contacts of the timer. If they appear to be burnt or damaged the timer is faulty. If not then set the scale on a volt-ohm meter to the RX1 setting to test the timer contacts for continuity. There is a cycle sequence chart stamped on the side of the timer or attached to the back of the control console. Refer to the chart for what contact points to test for any cycle. Touch the two probes of the volt-ohm meter to the contact points to be tested. Turn the dial of the timer to the appropriate cycle that is being tested. There should be no continuity reading on the volt-ohm meter during the test. If there is a reading on the volt-ohm meter, the timer is faulty. Hope this helps...please post back for further assistance.
    Daniel
  • Daniel Scott
    Daniel Scott Mar 21, 2011
    If you hear noise then replace the timer
  • Daniel Scott
    Transmission should be replaced.
  • Daniel Scott
    No I dont think its anything else....
My Kelvinator K600 Washing Machine sometimes does not operate on the Spin Cycle
Spin clutch soliniod not engageing underneath (replace).
Oct 02, 2016 | Washing Machines
Problem with washing machine spin cycle.
see if belt is loose if it is a no belt model you will need a repair man to change some parts
Mar 29, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
Frigidare top load mod# FWS445RFS2. Motor shaft spins on belt but will not engage tub. problem began going into final spin cycle. Tub pulley can be turned by hand and clutch appears to engage belt. What do...
Hi, you should check your wash and spin solenoid, located on gearbox assembly, or check for any device, that has wires connected to it, on gearbox, it's two soleniod, one for wash, one for spin, remove wires from solenoid, check for resistance, with ohm meter, looks, like your wash solenoid are burnt out, sometimes, they burnt out, if it's burnt out replace it. good luck.
Aug 08, 2009 | LG WM2077CW XL Front Load Stackable Washer...
Will not spin and smells funny
Does the washer agitate while in wash cycle? Does it move at all? It may be that the motor that drives the spin and wash cycle is not working. If it smells funny, it usually means that you have bearings gone bad or a belt, if it is belt drive, broken. You can replace these parts. All the parts involved with spinning can be replaced. The parts are available from the maker. It may be a spin clutch, agitator gear, pulley, or a transfer case..
Please leave good ratings, email me if you have more questions
Aug 07, 2009 | Washing Machines
How to change the belt in my whirlpool washing
It's probably the washer transmission. Belts aren't common anymore & besides it wouldn't work at all if there was a belt broken.
Jun 18, 2009 | Whirlpool Washing Machines
Rinse cycle does not work on washing machine
Sounds like a belt or clutch issue. What is the make and model #?
Nov 02, 2017 | Kenmore Washing Machines
GE Prodigy Washing machine making clunking noise
One common problem area is the clutch assembly. The clutch is built on top of the motor, the motor drives the clutch and the clutch assembly drives the rest of the washer. The clutch gets very noisy when parts inside are worn out. The shoes lining that drives the inner drum of the clutch wear off and you will get a metal on metal sound. Clutches often can be rebuilt, but sometimes they are too worn and replacing the whole clutch is the best repair. Please use this link here for clutch replace and repair info. The belt and pump may be the next items to check for noises. How to access the washer. Clutch repair help.
May 03, 2009 | GE Washing Machines
Final spin cycle problem
Sounds like maybe the clutch is worn?? Ge has several versions of this washer out some use a clutch and some dont Does yours have a clutch attached to motor or is it a solid pulley? Also GE uses the slow speed to start the spin and then kicks into high one or 2 mins into final spin. Is this noticable or does it sound like it starts slow and then never shifts???
Jan 20, 2008 | GE WBSE3120B Top Load Washer
Indesit wg1130t front loader washing machine
maybe the drive belt is off/broken. Take the back off to check
Oct 09, 2007 | Indesit W 123 Front Load Washer
Washing Machines Logo
62 people viewed this question
Top GE Washing Machines Experts
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
