Question about Campbell Hausfeld Garden
Engine is working but pressure does not come up fully, more than supply pressure but not adequate for pressure washing.
    Sergeant:
  • 261 Answers
Probably a bad impeller or waterpump. I have had this problem my self several times... Need to go into the shop or you can change the water pump yourself and save some money. Good luck.. HDTV GURU JAY.
Posted on Mar 17, 2011
ERROR CODE 1e
An IE error code signifies that the washing machine is filling with water slowly or not at all. This can occur when water supply taps are not fully open or the water pressure to the tap or house is too low. Other possible causes are kinked, pinched or bent water line hoses, or clogged water inlet filters.
TIP Make sure the water taps are fully open.
Make sure the hoses are not kinked or pinched. (Use caution when moving the washer.)
Clean the inlet filters.
Check another faucet in the house to make sure your household water pressure is adequate
You may try the following link, too http://www.lg.com/us/support/answers/front-control-top-load-washers2013/control-panel
Sep 19, 2015 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
What is the error of 1E
Sep 19, 2015 | Washing Machines
My fuzzy logic LG washing machine, is no longer spinning or washing the clothes its showing error
Check another faucet in the house to make sure your household water pressure is adequate.
Reference:
May 19, 2015 | LG Washing Machines
Washing maching wont spin out comes up e10
Hi Noeline, this is JK. Thank you for your post. I understand that you are receiving error E10 on your washer. This error means that the fill time is too long. Make sure that the washer has adequate water supply, check the faucets to make sure they are fully open on both hot and cold and make sure that the water pressure is above 30 psi. If these suggestions pan out there could be something going on with the pressure switch/sensor, main control board or the inlet valve assembly and may require a professional to diagnose.
Hope this helps!
Mar 11, 2014 | Electrolux Washing Machines
Washer does not fill
Widgett,
I understand that you are having trouble with water entering into your washer. Here are a couple of things to check out.
1) The water supply is possibly not adequate in the area where the washer is located. Check another faucet in the house. Wait until water supply and pressure increase.
2) The water supply faucets are not completely open. Fully open hot and cold faucets.
3) The water is being used elsewhere in the house. Water pressure must be at least 30 psi. Avoid running water elsewhere while washer is filling.
4) The water inlet hoses are kinked. Straighten hoses
If you are still having issues, I would suggest to contact a local authorized technician. When they come out they can take a look at the appliance up-close and determine what exactly is going on.
-Best Regards-
Jan 16, 2014 | Frigidaire GLTF2940ES Front Load Washer
We bought samsunf fully automatic but we dont have adequate water supply so how to use it by adding water manually
check to make sure the filter at the connection where the hose goes into the washer is clear of debris. this can cause low water pressure if it's clogged. it's real simple to fix. just disconnect the hose from the washer and remove screen from inside the hole and clean it off and replace. Notsure if you can run the machine mannually by adding water.
Aug 11, 2010 | Samsung Washing Machines
Error code H20...My washing machine, a hotpoint wt740 is showing the warning light H20...does anybody know what this means? thanks
Well error H20 does indicate no fill.
Make sure that that there is an adequate supply pressure to washer, check that there are no kinks or restrictions in hose. To be certain if you have an adequate supply turn off water valve to washer, disconnect hose and hold the hose into the sink or a bucket, turn the water back on, and see what the pressure is like..
If ti is too low, then the valve will not operate properly.
If you think it is ok then it is quite likely a valve fault, also check the filter built into the valve inlet.
Please post comments if further you have the same problem or you need more help or information........
Good Luck!!
Thanks
Dec 24, 2009 | Washing Machines
H20 fault is flashing on my hotpoint washing machine all connections are correct but still the machine will not fill with water?
Make sure that that there is an adequate supply pressure to washer, check that there are no kinks or restrictions in hose/s.
If ti is too low, thjn the valve will not operate properly..
If you are satisfied it is o/k then it is quite likely a valve fault, also check the filter built into the valve inlet.
Dec 08, 2009 | Hotpoint Aquarius WD640 Front Load...
Washer code le ?
Possible Cause:
• Water supply is not adequate in area.
• Water supply taps are not completely open.
• Water inlet hose is bent.
• The filter of the inlet hose clogged.
Solution:
Check another tap in the house.
Fully open tap.
Straighten hose.
Check the filter of the inlet hose.
Jun 17, 2009 | LG WM-1832C Front Load Washer
''poor pressure hot water only on new 531 series''
If you remove the supply line from the faucet and open the valve into a bucket, do you have adequate pressure? If you do, you will need to remove the hot water stem to see if something washed up into the faucet when you first turned the water on.
Apr 10, 2009 | Price Pfister Savannah Two-Handle Kitchen...
Garden Logo
260 people viewed this question
Top Campbell Hausfeld Garden Experts
John Trevino
Mike Squire
Are you a Campbell Hausfeld Garden Expert? Answer questions, earn points and help others
