Question about Maxell 8GB USB 360 USB 308 - 503202 Hard Drive
When i plug my pen drive in it shows up as 2 locks , click on 1 UNLOCK comes up , click on tht as normal it just disapears , so i cant unlock ? plz advise , it as been working fine till today?
  • Maxell Master
  • 27,725 Answers
USB drives can be write-protected by modifying the StoreageDevicePolicies Registry key and WriteProtect Registry value.
click Start>run>regedit to open Registry Editor. and press control+F to open the find dialogue box and type "usb device" or "driverdesc" to open usb mass storage device or type "usb mass storage device" in the search windows. And right click on it and delete. This will set the policy value to 0. then insert your usb device. It will work fine.
# Remember: do not delete any unknow files in the registry as this will make some programes not work as usual.
also
If you are running a Windows XP OS then you might be able to:
- click start right click on my computer select open
- Right click the icon of your Flash Drive (It should be F:/ or something)
- Click Properties in the menu that comes up
- Click the Sharing tab
- Click permissions
- And finally, click Allow next to Full Control.
also you might
click start control panel administrive tools ,computer management ,device manager scroll down universal serial bus controllers you should see a yellow question mark?
right click to reinstall drivers or
if you can see your usb drive but its not working
ports(com&lpt)right click update driver
check the USB leads that attach to the motherboard usually red-white-green-black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems for a computer and its parts also
scroll to disk drives if you can see your drive + to expand right click you should see options to update driver,disable,uninstall scan for hardware changes. or
select properties you should see options in the general tab to troubleshoot,policies,volumes,driver and details under the driver tab you will have the options to check the driver details,update driver,rollback driver or uninstall
hope this helps
Posted on Mar 17, 2011
I need the sim unlock code for an LG 440G
Sim unlock code is nothing puk code plz call up th sim service provider Nd ask for puk code tht unlocks th sim access Nd jst to make sure jst on/off th phn Nd tht code can be used whenever u forget or lock th sim
Oct 13, 2016 | LG Cell Phones
My pen drive is write protected plz help
1.Look for a switch or button on the side of the micro SD card or adapter. It might have a lock/unlock symbol on it. 2.Move the switch to the "Unlocked" position to remove write protection. This position may also be labeled "R/W" for read/write. If you have no switch, continue to Step 3. 3.Download and install Sony EzRecover and attempt to use it to format the card (this will erase all content). If this doesn't work, try Step 4. 4.Delete and repartition the micro SD card using Windows XP. Select "Control Panel" > "Administrative Tools" > "Disk Management." Select the micro SD drive and click "Delete." Right-click on empty drive and select "New Partition."
Dec 21, 2010 | Electronics - Others
I have transcend 2GB pen drive. when i insert my pen drive in system it shows the removable disk icon in MyComputer window . when i click the removable disk it shows 'please insert disk' ...i cant open the...
may be the flash drive is locked...unlock the pendrive and then try again.
formatting can be done in other way.
goto run,type cmd,press enter,then type format f: in the cmd and press enter.this formats the drive
Sep 09, 2010 | Transcend Computers & Internet
I HAVE A PEN DRIVE 32GB IT IS GONE AUTOMATICALLY WRITE PROTECTEDWHAT ARE THE STEPS TO UNLOCK THE WRITE POTETION OF PEN DRIVE..and
ok
try
these steps:
1.plug your pen drive 32gb in your computer.
2.then open Control panel.
3. open administrative tools.
4.open Computer Management
5. a window label computer management will appear.
6. click disk management
7.locate you pendrive and select delete partition or format it fat 32 or other format convenient for your usage.
ok
hope this will help
cheers
uttam
Jan 13, 2010 | iLO (2 GB) MP3 Player
Dont permission
Some pen drives have a lock button. Also check if it brings some sofware to unlock it.
Jul 01, 2008 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Pen drive:access problem
There should be a lock and unlock button on the pen drive itself make sure it is in the unlock position.
Keep me posted.
Thanks,
Lee
Jun 21, 2008 | Computers & Internet
Unlocking write protected pen drive
hi- some pen drive has a little switch on the ends of it, make sure you have it toggle or positioned on the unlock, look on both ends if it has a black switch to unlock it, if there is none try to reformat the pen drive, reply for any concerns. Yhanks!!
May 16, 2008 | Electronics - Others
do u have write protection swicth on this drive. if yes than check and correct.
if not than go for replacement. moser bear gives 3/5 yrs warranty ad hence u can demand
Mar 30, 2008 | Kingston Technologies 512MB DataTraveler I...
Maxell 8GB USB 360 USB 308 - 503202 Hard Drive Logo
381 people viewed this question
Top Maxell Computers & Internet Experts
yobo007
yobo007
Eric
Are you a Maxell Computer and Internet Expert? Answer questions, earn points and help others
