Sanyo washing machine ASW-70ST ,,water keeps on overflowing.
  • 1028 Answers
SOURCE: Our washing machine keeps filling
ck for stuck open fill valve ..with power unplugged does it keep filling if so valve if overfills only during fill cycle ck waterlvel control and associated hose to side of tub look for kinked or otherwise pluged line also possible pin hole in line
Posted on Apr 27, 2008
  • 5 Answers
SOURCE: Washing machine does NOT stop filling w/ water!
If the m/c keeps filling, where is the water going ??? if the m/c doesnt reach the required water level it will not start, check the drain hose at the back, make sure its at least 24" above floor level, if it lower then it will just empty as quick as you fill it on gravity.
Posted on Nov 19, 2009
  • 5 Answers
SOURCE: My washing machine is SANYO ASW-90WRTP. showes E4
Check on the machine there is a schamatic and it has error codes on it. it may be on the in side panel.
Posted on Oct 11, 2009
Testimonial: "cool thanks for that just empty the tub then will check for skidmatics"
kel1guy2002
  • 3740 Answers
SOURCE: will not detect water level -overflowing
Since you did not provide a make or model number we are winging it here. Inside the control panel there is a pressure switch that measures the pressure of the water in your machine. This pressure switch has a tube connected to it that would look like a small automotive vacuum line. Either the pressure switch has failed or there is a problem with the line itself as in a hole or a disconnection somewhere. There are only 2 connecting points for that tube one being on the pressure switch itself and the other being on the outside of the base of the wash tub enclosure itself. Most often the pressure switch has failed but occasionally the tube gets chaffed or a pin hole over the life of the unit. One thing to note is if the pressure sensing line has become disconnected at the base of the wash tub your washer will be leaking. If you do not have any visible signs of leakage when the unit is filled with water then the problem mosly likely will be where the line comes through the top panel or connect to the pressure switch. Definately near the top of the washer. Without a make and model it is very difficult to assist you much further.
Posted on Jan 06, 2010
Testimonial: "My washing machine is a Maytag HAVBB-1 model. Thank you for your help. I will be giving this information to my husband. "
  • 13 Answers
mungkin
  • barangkali
  • agaknya
  • ')" onmouseout="ht(this)">perhaps pintu
  • daun pintu
  • laluan
  • ')" onmouseout="ht(this)">door
    tidak ditutup
  • tak bersalut
  • ')" onmouseout="ht(this)">uncoated
    dengan betul')" onmouseout="ht(this)">properly or penapis
  • tapis
  • menapis
  • ')" onmouseout="ht(this)">censor
    in pintu
  • daun pintu
  • laluan
    gagal
  • kecewa
  • terkandas
  • ')" onmouseout="ht(this)">failed
    . menghubungkan
  • sambungkan
  • menyambung
  • ')" onmouseout="ht(this)">connect
    pendawaian')" onmouseout="ht(this)">wiring penapis
  • tapis
  • menapis
    with ( 2 dawai
  • wayar
  • kawat
  • ')" onmouseout="ht(this)">wire
    ) jika tiada
  • sekiranya tiada
  • sekiranya tidak
  • ')" onmouseout="ht(this)">if no
    dawai
  • wayar
  • kawat
    penapis
  • tapis
  • menapis
    menggunakan
  • penggunaan
  • gunakan
  • ')" onmouseout="ht(this)">use
    magnet
  • besi berani
  • batu berani
  • ')" onmouseout="ht(this)">magnet
    diletakkan pada')" onmouseout="ht(this)">placing at mengenai kawalan')" onmouseout="ht(this)">on control litar
  • lingkungan
  • peredaran
  • ')" onmouseout="ht(this)">circuit
    Posted on Nov 20, 2010
    Sanyo asw 70st washing machine makes lot of nose while spinning
    Can any one provide me the Instruction manual for Sanyo #ASW-70ST?
    Feb 23, 2017 | Washing Machines
    Sanyo, washing machine, asw-ep70a
    It probably needs a belt. It may have been slipping so much with the bigger loads that now it is shiny
    Nov 29, 2013 | Washing Machines
    How to open child lock on sanyo asw-a85ht washing machine
    Apr 07, 2012 | Cars & Trucks
    Would you have a user manaual for a Sanyo ASW-F6OAT washing machine? gusov@mcdermott.com
    http://us.sanyo.com/Customer-Support-Owner-Manuals-Locator
    SANYO Owner ManualsTo find an Owner Manual for a SANYO product, enter the model # of the product below.
    Please Note: We are in the process of upgrading the Owner Manual search to also include discontinued product documents. Please check back in a week or two if you need an Owner Manual for an older SANYO Product.
    Model # ASW-F6OAT
    Search Results
    Sorry, could not find any documents that match your search criteria
    Feb 21, 2011 | Washing Machines
    SANYO WASHING MACHINE ASW F 950 T DISPLAY E A FAULT CODE
    I NEED TO FILTER ASW-F950 T,I AM FROM IRAN.MY EMAIL IS BEHAVARD@GMAIL.COM
    Dec 14, 2010 | Washing Machines
    My sanyo washing machine does not fill in water, its director drain out. model asw 40sit.
    If the washer is not filling with water then the water inlet valve needs to be checked.The water inlet valve is also called water fill valve.If the fill valve is faulty then it will not the water to get filled in the machine. (The water-inlet valve is the device on the washing machine that the fill hoses are attached to.) If they're clean, you probably have a defective water-inlet valve. If so, you should completely replace the valve. You can get required parts from www.repairclinic.com
    Thanks. Keep updated for any more query. You can rate this solution and show your appreciation.
    Aug 30, 2010 | Washing Machines
    Washing Machines Logo
    287 people viewed this question
    Top Washing Machines Experts
