Question about Ingersoll Rand 2135PTI Pneumatic Titanium Impact Wrench
My I R 2135 ti impact dosent seem to be working rite dosent seem to be getting enough air when tightening something and sometimes the air nozzle gets pushed out and the trigger pops out
Replace reverse valve ir 2135
Did you ever get the 2135 reversal valve installed?
Jan 24, 2014 | Ingersoll Rand 2135Ti Air Impact Wrench
Model number 223
IR 2135-k303 air inlet repair kit along with a 2131-322 air inlet removal tool should get it repaired.
Nov 12, 2012 | Ingersoll Rand - Rand 1/2" Impact Wrench,...
Problem with Ingersoll Rand - Rand 1/2" Impact Wrench, Quiet Tool with Extended Anvil wont shutoffwont shutoff
The IR 2135-k303 air inlet repair kit along with a IR 2131-322 inlet removal tool should fix your problem.
Jun 02, 2012 | Ingersoll Rand - Rand 1/2" Impact Wrench,...
Help with air leak problem on Ingersoll Rand Ingersollrand 2135timax
I.R. has a tune up kit available which includes all the necessary gaskets and seals required for this tool.
Follow this link to see the parts list:
http://manualarchive.ingersollrandproducts.com/ir_pdfs/Tools/Vehicle%20Service%20Tools/Air%20Impact%20Tools/45534070_ed3.pdf
Tune up kit P/N 2135-TK2
Feb 17, 2012 | Ingersoll Rand Ingersollrand 2135timax 12"...
Ingersoll Rand 2100G air impact wrench turns when air is hooked up. I can stop it by hand and then use it with the trigger, and it works fine, but it continues to run even when I let the trigger go. What...
The I.R. 2100G shares parts with the 2135 series impact, the throttle valve seal on these models have a tendency to wear out or deteriorate casing the throttle valve to by pass air. On the model 2100G the parts in question is only sold as an assembly (item# 22).
But you can disassemble the inlet bushing and install an inlet parts kit p/n 2135-K303, it includes all the necessary parts.
I will provide to links for you to look at
2100G: http://manualarchive.ingersollrandproducts.com/ir_pdfs/Tools/Vehicle%20Service%20Tools/Air%20Impact%20Tools/45667599_ed2.pdf
2135Ti : http://manualarchive.ingersollrandproducts.com/ir_pdfs/Tools/Vehicle%20Service%20Tools/Air%20Impact%20Tools/45534070_ed3.pdf
The I.R. parts list shows the inlet bushing in detail.
Oct 28, 2011 | Ingersoll Rand Air Tools & Compressors
Have a Ingersoll Rand 2135 ti impact wrench with a trigger that sticks in. Don"t know if it needs a spring in the trigger part or if there is another problem. Took it apart and cleaned it and oiled...
i have the same problem, and a fellow co-worker of mine told me about the problem. here it is.. on the handle there are two slots on either side, push them in and the air inlet assembly should pop out along with a broken tiny metal rod.. this rod connects to the inlet valve and turns on and off ur impact wrench.. i have been looking for replacement parts but cant find any.. hope this helps you and maybe help me too..
Nov 12, 2010 | Ingersoll Rand 2135Ti Air Impact Wrench
Impact wrrench disassembly
Check to see if #27 is holding it in.
Sep 23, 2008 | Air Tools & Compressors
Ingersoll Rand 2135PTI Pneumatic Titanium Impact Wrench Logo
63 people viewed this question
Top Ingersoll Tools & Hardware - Others Experts
Mike
Eddie Tucker
Level 1 Expert
Lawrence Oravetz
Are you an Ingersoll Tool and Hardware - Other Expert? Answer questions, earn points and help others
