Question about GE Refrigerators
GE model PSH23PSWA SS...ref too warm, not making ice, water warm from the dispenser, constant beeping that door is open even if it's closed.
SOURCE: GE Profile Ref. Ice despenser motor does not turn. Auger turns
I had this same problem today, and after tearing apart the door and digging with the multimeter, I found that the bulb was drawing to much current {probably due to age} and that pulling it made everything else start working. The high resistance was drawing too much current from the IC on the door panel board.
I'm going to get a new bulb tomorrow, but if you yank the bulb it'll probably work. {If you have the same problem}
Posted on Dec 03, 2008
HVACRH20
  • 237 Answers
SOURCE: GE side by side refrigerator ice dispenser
If you take a look at this diagram, you should be able to see all the inner workings of that area and decide if you want to repair it. I think anyone with the most basic mechanical skills could easily handle this repair. See parts 62,63,67, etc. Could just be the spring is off or broken. Let us know what you find! http://www.partselect.com/Schematics/GE/00112435i01.gif
Posted on Jan 08, 2007
  • 115 Answers
SOURCE: Replace GE ice dispenser damper door on GE model PSI23sgna
take both hands and place on the front bottom edge of control panel pull up and out it is hard and you think you are going to break something but you are not when you get the control panel off there will be 4 screws at each corner undo them and slide that piece off then you can see your door
Posted on Dec 30, 2008
aasc
  • 1606 Answers
SOURCE: GE ice dispenser door hangs down
You should replace the dispensor solenoid and plunger due to rust . Very common problem with G.E.
Posted on Jul 11, 2009
aasc
  • 1606 Answers
SOURCE: ice dispenser door flap will not close.
Remove the top freezer hinge hover on top of the freezer door . Unplug the receptical there ( this will remove power to the door only ) .
Using a small screwdriver at the "crease" on the bottom of the dispensor control board inside the dispensor , twist slightly to disengage the 2 clips ( 1 on each side ) holding the dispensor board . Unplug the 3 connectors from the board . 4 screws ( 1 on each corner ) hold the dispensor housing shield . Remove these 4 small screws . After removing , at the top right , you will see a solenoid and plunger . These are probably rusted , holding the flap open . The part number for the solenoid and plunger is WR62X10055 . 3 screws hold this part on . When reinstalling the dispensor housing , It slides back on 2 "grooves" so make sure it is back in place , or the board will not snap back on properly at the bottom .
Posted on Sep 02, 2009
Where do I direct the hot air from an hair dryer to thaw out the water line in my hotpoint side by side refrigerator ?
Hotpoint ref.
made by GE
There is 2 different place they freeze up inside door water line for cold water dispenser & water feed to ice maker.
for cold water disp. Water line depends on model # will start at bottom of door loop over the disp. control and back down from top of control to cup area to defrost this line best way is to shut down ref and leave door on freezer open can take up to 12 hours.
taking door apart is a major project.
If its your ice maker fill tube easy fix turn water supply off.
on back of ref. there is a water line going up to the top of freezer
this tube will pull out from back the whole fill tube will come out
take to sink thaw with warm water replace tube You may need some caulk to seal area tube meet ref.
Mar 24, 2015 | Hotpoint Refrigerators
Have a SS #GSS22WGPEWWW Ice not coming out
Try taking ice pan with auger out hold door open and press light switch for the door in while someone presses dispense ice. I want to see if the motor is turning behind the auger ice tray. The door switch has an interlock and when door is closed the dispenser controls should be functional. When open this disables water and ice dispenser. waiting on your response, Sea Breeze
Jan 26, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Ge side by side water will not come out of door dispense
The water switch went bad or the water valve. Switch the two wires on the water valve on the back of the ref. Press water switch on door if water fills ice maker valve is bad,if not,door switch is bad.
Jan 21, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
No water or ice
sounds like your door swith is not working. it wont let water or ice flow when door is open (even when door is closed it is not making contact)
Jan 12, 2009 | Refrigerators
PSS26PSTA SS - Only dispenses crushed ice.
Remove the ice dispenser bucket. You will see a square hole at the back wall with a horizontal rod in it. You should be able to move it up and down with you fingers. If not, it may just be frozen. Warm it with a hair blower and try again. If still no luck, the WR62X58 dispenser solenoid may be burnt out / melted and need to be replaced. It is attached to the metal just above and behind that square hole. The removable tray at the bottom of the dispenser recess is a part number WR17X12133 for a PSS26PSTA SS. Contact any GE servicing dealer or general appliance servicer near you to get one. You can get parts direct from GE also, but the won't be any cheaper, and you may pay more shipping and handling.
Nov 20, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
GE Refrigerator Model GSH 25S GPA SS
that would really be a big job. what i can suggest is for you to fix the pinhole of the hose by applying a good quality glue or epoxy that would held water pressure. once this is done, you can be sure that water would go up all the way to the dispenser without leaking in the front of the freezer.
if water is still not coming up, you could just have a frozen water line, maybe because it has not been use for a while. just unplug the ref for about a day, open the door and make sure that all ice would thaw in the freezer section then plug it back and test it.
tnx 4 using fixya,
drcool
Oct 31, 2008 | Refrigerators
Ge profile refrigerator ice maker
I have a GE Profile PSW26P Stainless Steel Side by Side refrigerator that makes plenty of ice but will not dipense when the lever is pushed. The dispenser makes not sound when engaged. What do you think the problem is.
Sep 28, 2008 | GE Profile PSW26P Stainless Steel Side by...
GE Monogram ZISS480DMCS Ice Maker Problem
i would first check water supply to ref. measure the resistance of coil either open or resistance. if all this is ok then exit side of line needs to be checked for water.
Sep 22, 2008 | GE Monogram ZISS480DRSS Stainless Steel
GE Arctica (PSS26NGSB) ice and water dispenser
need to call ge at 1800-386-1215 some of these sxs have a door insulation issue that they will either send replacement doors to an authorized service company to exchange at no cost to you or offer a rebate for a newer model. yours might be in this group
have your model and serial number out of the ref located in the refrigerator section, about 4-5 inches from the celing down the right side and call and see
Apr 12, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Panel flashing, ice door opening and closing constantly
That is a faulty icemaker solenoid switch, or a contact on wiring.
Enter the model number on one of two websites below to get parts and diagrams for your appliance:
Appliance Parts From PartSelect
Appliance Parts Pros
Jan 10, 2008 | GE Monogram ZISS480DRSS Stainless Steel
Refrigerators Logo
126 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
RepairNinja
RepairNinja
