My Logik 32LW782 fails to turn on and it has a constant blinking blue ring light at the lower front of the tv. Please help!
5 Suggested Answers
  • 2334 Answers
SOURCE: Akai LCT2701TD Won't turn on. Red light in front blinks.
There is a high power supply failure rate on these LCDs. The power boards are not longer being manufactured or not easy to find.
Write to jah2mil@hotmail.com for more info.
Posted on Sep 16, 2008
SOURCE: tv won't turn on. blinking red light in lower left corner
unplug the television...wait 10 seconds and then plug back in....if you listen carefully after 5-10 seconds you will hear a click sound (the same sound that you hear when you turn on or off) ...once you have heard it, turn the TV on again using the remote. Do not turn on until you hear the click. If this does not work, try again but turn the TV on again before you hear the click. I dont know why it happens but it is as if the TV gets confused as to whether its supposed to be on or off. Most of the time, the solution is to turn it on after the click so I would always try that first.
Posted on Feb 22, 2010
SOURCE: logik 32" TV when turned on the blue circle at
I have the sanme problem too! Did anyone find a solution? HIGGINS586@aol.com
Posted on Sep 09, 2010
techman007
  • 1112 Answers
SOURCE: I HAVE A 50' PHILIPS
HI:
This is a plasma unit and philips plasma's are nortorious for bad power supplys, your problem may very well be the power suppy in the television, it is possible you blew a low B+ fuse on the power supply. There is also a issue with the Y-sustain board failing in this model, If you open the back and looking at the unit from the rear the y board is on the left side of the unit and the PS is in the center. disconnect the Y-sustain power plug from the power supply and turn on the unit if the unit stays on with no red light then the y board is bad. it does the same then replace the Power Supply.
Posted on Mar 10, 2011
Testimonial: "THANK YOU I WILL GET BACK WITH YOU AS SOON AS I TRY THIS"
Logik LED TV making a constant tapping/clicking sound.
try turning off AND unplug for a couple minutes! USB may have pulled power down to start the switching noise. Try usb again and if it does it again then I wouldn't use that usb anymore.
Jan 17, 2014 | LG Televison & Video
I HAVE A 50' PHILIPS MODEL 50PFP5332D/37 FLAT SCREEN TV. I BLEW A BREAKER ON THE TV PLUG IN WITH A PORTABLE HEATER. TURNED BREAKER ON TV CAME ON WORKED FINE. TURNED OFF. 1HR. LATER A RED BLINKING LIGHT WAS...
HI:
Mar 10, 2011 | Philips 50PFP5332D 50 in. Plasma...
No , I just need to know how to unlock the tv with the remote.....blue screen with red lock Logik tv
Press and hold the SET and EIGHT (8) key, then release, the light will blink twice, then off, it is now unlocked.....hope this was helpful...
Apr 23, 2010 | Gemini 1 Device Universal Television...
Have model WD-62525 dlp tv front timer light constantly blinking and tv will not turn on
This problem can usaly be repaired by replacing several capacitors on several boards, The main problem will be with a board known as the DM board there usaly are four caps that have failed. Then a couple more on the power supply board that caused the problem and finaly on the Formater board there might be four more that have failed. Any or all of these will cause the micro processer not to boot up and cause the constant blinking. We have done dozens of these upgrades and even with all the right parts and test equiptment it takes well over a hour or more and is not a repair a shade tree tech should try.
Dec 18, 2009 | Televison & Video
KP-57WS500
I had this problem and at the same time I was getting blue tint. When the blue got darker, this would happen, Adjusted the voltage on the guns (3 screws in the front - lower panel off) and the blue went away and it stopped turning off. But later, it would start all over again. Same procedure, same fix.
Jun 24, 2008 | Sony KP-57WS500 57" Rear Projection...
I have an RCA Scenium HDTV DLP, Model HDLP50W151. Turned it on and went through it cycle, whining sound but the screen was gray. turned it off and then on again...no picture and there was no whining sound....
Sounds like the Color wheel on the Light engine has failed. Its a major repair. Contact Thomson at 1-866-465-7157 to find a local authorized repair center.
Jun 04, 2008 | RCA Televison & Video
Mitsubishi wd-62825 dlp
The WD62825 has a Digital Module located on the left side of the chassis looking at it from the rear of the set. It's housed in a metal box that can slide out of its holder after removing the trim screws.
The module has its own power supply board and there are a group of 16v/1000uf caps on that board which commonly fail causing the constant flashing standby light. Further back on the module is a small board about the size of a matchbook called the E2P module. Its SMT (Surface Mount Technology) caps also commonly fail which can cause the same symptoms. Techs can tell whether the E2P has failed by simply removing it, hooking the DM back up and trying to power the set. If it powers on the picture won't be much good - but at least you can tell what's keeping it down...
Back to the caps on the pwr board. If they've failed they usually will buldge visibly on top. And ESR is almost not necessary. In any event that's the nuts and bolts on this model.
Is it a job for a layman? Yes and no - you might strongly consider a tech if you don't feel comfortable removing all the connections that the DM has with the signal board. There are about six - multi-pin - wired connections to unplug and then sliding the DM out of the unit and carefully removing the screws and latching to take the DM top cover off...
Hope this helps.
Bill
Oct 29, 2007 | Mitsubishi WD-62825 62" Rear Projection...
Ws 55513
The constant blinking green light means that the TV is not booting up. This is a common problem on this set.You need to remove the shield from the DM board (standing upright on the left where the DTV RF connector is)and inside you will see the four leaky capacitors (1000 MFD 16 VOLT)replace them,plug the TV in and wait 70 seconds for the blinking light to stop,then turn on the TV.The hard part will be removing the board from the TV(lots of screws and connectors,takes time)
Sep 22, 2007 | Mitsubishi WS-65613 65" Rear Projection...
Televison & Video Logo
Top Televison & Video Experts
