Question about D-Link AirPlus DI-524 Wireless Router
DI 524 Connection Problem
I have a DSL modem through Iowa Telecom. And when I hook that directly to my computer it works just fine. But when i try to connect it through the router I cannot get onto a browser, it just showa the "you dont have a connection" screen. But when I go into the connection options in the control panel it tells me that I am connected to the internet. I tried to use the CD I got from my isp and when it got the the stage to configure my user id, it tells me i dont have a connection. I have chenked all of my cables, and I ran the wireless network setup wizard. But yet when I get to the step to actually connect to the internet, it doesnt work. Could the router be faulty or am I doing something wrong? Thank You
    Brigadier General:
  • 6,966 Answers
Try the DSL modem directly connected to the PC.No D-Link Router (powered off and disconnected). Verify that the PC couldsurf/browse/connect to the Internet. Go to Start, Control Panel, Network Connections, right click Local Area Connection, Properties, scroll down to/highlight Internet Protocol (TCP/IP), Properties button. Get the IP Add, Subnet Mask,Default Gateway and DNS assigned to the PC (write this down. This will be your WAN/Internet IP settings). Then Disable DHCP of your modem if it has one. OK, close, save or whatever is applicable.
Disconnect the DSL modem from the PC. Connect D-Link Router to PC (wired/LAN) without the modem connected to the router. Go again to Start, Control Panel, Network Connections, right click Local AreaConnection, Properties, scroll down to/highlight Internet Protocol(TCP/IP), Properties button. Tick "Use the following IP address". Enter this IP Add 192.168.0.10, Subnet Mask 255.255.255.0,Default Gateway 192.168.0.1 and the DNS from what you have written down earlier). This willbe your LAN IP settings. OK, close, save or whatever is applicable.
Open a browser and log into the D-Link router (192.168.0.1, using "admin" as a username and no password). Do not run Wireless Network Setup Wizard. In WAN/Internet/Modem setting of router enable/check Static IP Add.Use the IP numbers previously assigned to PC that you have writtendown as the router's WAN/Internet/Modem IP settings. OK, close, save or whatever is applicable. Rebootrouter. Connect DSL modem to router.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on Aug 02, 2008
I can not run 192.168.01 on my computer to change it to ppoe,i have a di-524 dlink and a motorola mstatea dsl modem,the other computers desk top and laptop can connect to the internet,but the one these...
you should type in 192.168.0.1.
In your request you have:
i can not run 192.168.01 on my computer to change it to ppoe,i have a di-524 dlink and a motorola mstatea dsl modem,the other computers desk top and laptop can connect to the internet,but the one these componets are hardwired to cannot.has worked fine for years but stopped suddenly!!!!!!!!!!!
Nov 11, 2010 | D-Link AirPlus DI-524 Wireless Router
I have hooked my di 524 from my DSL cable modem then hooked the two in line to my computer when I hooked up to the computer I have no connectivity why?
OK, if I understand:
telephone----DSL Modem--di 524--computer.
That is what you are supposed to do.
Has any configuration of these devices ever had any connectivity?
1. Is the DSL modem in "Bridge Mode"? That is the first thing I'd check.
2. Are you using the right wires and ports? There may be a DCE-DTE problem. Be sure you have used the wire that came with the DSL modem to hook it to the internet port on the DI-524.
3. What is the state of all the various lights? Do they show that you have valid connections?
4. Most of these devices can be configured with a browser. When you browse them, what do you see?
5. What is windows telling you?
Jan 09, 2010 | D-Link DI-524/DWL-G630 (di524dwlg630kit)...
I just conected my DI-524 with a new cable modem
The first question is whether your change of service provider really has any connection with your new lack of range. If your new cable modem contains a wireless router, it's possible it is interfering with your old router. You only need one, so in that case you should remove your DLink and configure your wireless cable router to your satisfaction. Otherwise, you may have coincidentally picked up a new source of interference; you may want to change the channel on your DLink router to see if that improves your range. The third possibility is that your DLink radio is going sour with age -- it happens -- and may simply need replacement.
Nov 25, 2009 | D-Link AirPlus DI-524 Wireless Router
Ethernet connection of DI-524 does not work
You have to make the Ip changes on the laptop not on the modem.
You said you have internet acces on one computer. Then use that computer to find out the exact IP address used by the modem.
On the laptop use the exact same numbers, (IP, Sub mask, Gateway, Primary DNS)
and chek if it works.
If you want to have both computers on the Internet, simply change the last number on the IP address ONLY.
Please don't forget to rate this answer if it helps
Sep 22, 2009 | D-Link AirPlus DI-524 Wireless Router
D-Link DI-524 is not communicating with modem
Checklist:
* Is DHCP configured correctly?
* Connect your server and laptop to a switch (not directly with the cable)
* Can they ping each other?
* Check that the firewall is configured (or switched off if you have another FW in place)
* Default gateway should be your router, not the computers (until you have configured RRAS for example)
Here you can find more information about how to configure various roles in 2008: http://technet.microsoft.com/en-us/windowsserver/2008/default.aspx
Sep 07, 2009 | D-Link AirPlus DI-524 Wireless Router
Connecting my sony vaio laptop through my linksys router with dsl
Try this:
Connect the modem to the router, and the router to the computer.
Pull the power cord out of the Modem.
Pull the power cord out of the Router.
Wait 10 seconds.
Plug in the modem, and wait untill all the lights go steady (ususally a minute or two)
Plug in the router.
Check your connection. Ask for more help if this doesn't work.
Jan 09, 2009 | D-Link DI 514 Wireless Router (DI-514)
Using a ppoe connection to a DI-524 is it necessary to put a modem in line?
DSL connection:
Computer -> Router(Dlink) -> DSL Modem -> Telephone wall jack/outlet
OR
Computer -> DSL Modem -> Telephone wall jack/outlet
PPPOE = using a username/password combination to authenticate the connection to the ISP.
Nov 04, 2008 | Computers & Internet
D-link wireless internet
It is always a good thing to start the different peripherals in an order. First, you start your modem. Wait 30 seconds. Then, start the router; wait another 30 seconds; then the computer.
Aug 24, 2008 | D-Link Wireless Cable/DSL 802.11G Router...
Connect to wireless D-Link and Westell6100
I am assuming that you have a functional LAN cable connecting the Westell and the DI 524, right? If you are unsure, replace it with a cable you know is good.
If the 524 is turned on downstream of the Westell modem, it should find what it wants. You may try rebooting the Westell and seeing if the 524 finds it, and you maybe should reboot the 524.
Sometimes, when the world gets jiggered up I have to work pretty hard to get my DI-524 resync'd to my DSL modem.
Oct 26, 2007 | D-Link AirPlus DI-524 Wireless Router
D-Link AirPlus DI-524 Wireless Router Logo
114 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
