Question about GE RM24948 Remote Control
GE RC24914-E 1022 universal remote..Needed for an 46' RCA HD TV...None of the 4 digit codes that came with remote worked
Tengo un control general electric 24914-e y quiero el codigo para programar una tv marca toshiba
Posted on Mar 27, 2011
How do you program it to a GE universal remote
these are the codes
LG: 004 005 009 012 050 057 080 156 227 338
  • How to Program a GE Universal Remote ' Techwalla https://techwalla.com/content/program-ge-universal-remote Lost your Remote? Need help programming your GE Universal Remote? Most TV's, VCR's, DVD Player's, Cable and Satellite Boxes will work with a GE universal...
  • How to Program GE Universal Remote: Quick Steps www.brighthub.com > Electronics > Home Theater > Home Media 2011-04-18 · How to Program GE Universal Remote Using the Code Search Function. If you've tried the codes listed for your device brand and are unable to get your ...
  • GE Universal Remote Codes and Instructions ' direcTutor www.directutor.com/content/ge-universal-remote-instructions Goto GE remote Codes. Direct Code Entry for GE remotes with 4 digit codes. 1. Manually turn on the device (TV, VCR, DVD, etc.) you wish to program.
  • How to Program a GE TV Remote ' Techwalla https://techwalla.com/content/program-ge-tv-remote GE universal remote controls allow users to program multiple devices onto a single remote. The remote control uses codes to detect the device, and you can...
  • GE Universal Remote Quick Start Guide - YouTube Youtube
    • BY JASCOPRODUCTSCOMPANY
    • 3 MIN
    • 216K VIEWS
    2013-04-18 · Video embedded · http://www.jascoproducts.com Eliminate remote clutter with GE Universal Remotes
  • How to Program a GE Universal Remote Control ' eHow www.ehow.com > Tech > TVs > Remote Controls
    • BY EHOW ELECTRONICS EDITOR
    Programming a Jasco/GE Universal Remote Control takes about seven steps. As with programming other remotes, you need to know the code of the component you are ...
  • May 09, 2016 | LG "32"" inch New 2011 HD LCD TV With HD...
    Total Control Universal Remote. URC 4140. What is the 4 digit code to operate the above TV
    Search Results
      [PDF]Total Control URC-4140 - Universal Remote Control Codes
      www.remotecodelist.com/remotes/URC_4140_B00_and_B01.pdf
      UNIVERSAL. Remote control. URC - 4140 ... Your TOTAL CONTROL can operate four devices: a Television, ... The TV, VCR/DVD, SAT and AUX keys select the device.... 4. Enter your four-digit code using the number keys. The red light will blink twice.... To set up your other devices, follow the same instructions above, only.
      Codes and links for a number of universal remote controls, including Sony, RCA, ... GE Remote Codes, General instructions for GE Universal 3 and 4 digit remote controls. ... This manual may work for a number of Philips-Magnavox remotes. ... Total Control URC-4140, PDF Instruction Manual (remote also known as Crest .
    Jan 13, 2016 | Sanyo 42 in. LCD TV
    Need Source Dode for an RCA TV model DETK185R.
    The RCA DETK185R TV can be controlled with Universal Remote Controls. I tested several.
    The best match was a 4 digit universal remote from GE. Model Number 10841. Code 1961 worked almost everything.
    With a 5 digit remote from RCA, model number RCRN04GR, Code 12372 worked Power, Channel, Volume and Input.
    A 3 digit remote from GE, model RC24912-B. Code 166 was able to control Power, Channel, Volume and Input.
    An old 3 digit remote from RCA, model RCU-403A. Code 062 was able to control Power, Channel and Volume.
    Most remotes from GE and RCA will use the same code numbers. So even if you have a different model remote from GE or RCA, these codes may work.
    These codes should work with other TV models in this series from RCA, including Detk215r, Detk186r and Detk156r.
    Apr 15, 2013 | RCA Detk185r 18.5" Led Hdtv
    I have a ge universal remote and have a toshiba tv dont know codes and how to programe it could you please help?
    Which GE universal remote do you have? Does the remote use a 3-digit or a 4-digit code? To program most GE remotes for a TV, turn on the TV. Then press and hold the Code Search or Setup button until the indicator light comes on. Then press and release the TV button. Enter the first code available for your device. The indicator light should go off then check if the remote controls the functions of the TV. Repeat the above steps if the code doesn't work or doesn't control all the features of your TV.
    The manuals and code lists for GE remotes are here: http://www.jascoproducts.com/support/universal-remote-codes.asp .
    Toshiba 4-digit TV codes are: 0159 0178 0109 0120 0181
    .............0105 0049 0095 0170 0260 0358
    .............0394 0924 0012 0095 0117 0141
    The 3-digit codes are 170, 181 or 641 for Toshiba HDTVs.
    Please note that the remote probably only has codes for devices that were released 6 months or more before the remote was programmed. If your TV is newer than your GE universal remote, you may need a newer remote.
    I hope this helps.
    Jul 06, 2011 | RCA Televison & Video
    NEED CODE TO GE UNIVERSAL REMOTE RC24912-D FOR RCA TV.
    The code to programme your remote with RCA TV
    3 digit code are
    000, 003, 004, 005, 007, 009, 011, 031, 048, 054, 078, 082, 083, 094, 096, 098, 099, 100, 101, 102, 103, 107, 113, 129, 133, 167, 179, 181, 187,188, 191, 194, 342
    4 digit code are
    0031 0004 0048 0054 0094 0100 0102 0107 0129 0191 0005 0009 0000 0162 0163 0342 0003 0015 0022 0096 0113 0125 0179 0187 0188
    thanx
    Aug 05, 2010 | GE RM24912 Universal Remote Control
    Lost my manual - need tv codes - ge universal remote - tv to program is a rca xl100 remote
    Hi! The code of a GE Universal remote for a RCA TV are 0031, 0004, 0048, 0054, 0094, 0100, 0102, 0107, 0129, 0191, 0005, 0009, 0000, 0162, 0163, 0342, 0003 ,0015, 0022, 0096, 0113, 0125, 0179, 0187, 0188. In case none of these works for your TV you can try these steps for you to program your remote conrol.
    1. Manually turn on the TV.
    2. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
    3. Press and quickly release the desired TV button. The red indicator blinks off once.
    4. Press the ON-OFF button repeatedly (up to 300 times) until the TV to be controlled turns off. The red indicator blinks off with each button press.
    5. Press and release ENTER to install the code.
    Jun 14, 2010 | GE JASRM24912 Remote Control
    Remote codes for k2598u tv
    Seeing that you haven't listed 'all' the codes that you have already used i decided to add these. Didn't know if it was 3 or 4 digit codes you needed so i posted them all. If there are codes in the 3 digit list that aren't in the 4 digit list just add a zero before the beginning and try them (that's if your using the four digit codes!)
    eg. 3 digit code not on the 4 digit code list is 053 > then try 0053.
    All the best,
    Hughie. (codes below.)
    4 digit.
    0053
    0011
    0016
    0047
    0066
    0103
    0412
    0413
    0029
    3 Digit codes
    011,
    016,
    047,
    053,
    066,
    157,
    158,
    176,
    412,
    413
    Jun 19, 2009 | Konka K2568U 25" TV
    Remote code needed
    20839 is the DirecTV & Access HD universal remote code for Mintek, Shinsonic, & US Logic. None of which brands are listed in my Yamaha RAV283 remote code list (uses 4-digit codes).
    20717 is also listed for Mintek by DirecTV. Other brands with the same code on DirecTV remote are: Apex, Blaupunkt, GE, Greenhill, Initial, KLH, Nesa, & RCA.
    Of those brands, only Apex & RCA are listed in my Yamaha remote's list. I tried all of the codes for those 2 brands under types DVD, DVD Recorder, DVD/VCR, & TV/DVD. None worked. It appears to me that only those 3 brands for 20839 share the same remote code settings. If your remote doesn't support any of those 3, I doubt you will be able to use that particular remote with the Mintek DVD-1600.
    I hope my research helps someone with this, as it was unfruitful for myself. Good Luck!
    Jun 15, 2008 | Mintek DVD-1600 DVD Player
    Universal remote
    Click Here
    For the 4 digit Universal Remote Code List From GE (suppose to work with all GE Universal Remotes as long as they use 4 digits to program.)
    Click Here
    For the 3 digit Universal Remote Code List from GE (uses 3 digits to program, unless the remote was purchased before August of 2002)
    Click Here
    For the 3 digit Universal Remote Code List from GE if your remote was purchased before August of 2002.
    Oct 28, 2007 | Televison & Video
    Need code for sanyo tv
    Welcome to FixYa.
    SANYO TV Codes: 0154, 0159
    Please be informed that the codes vary with different make and model of the universal remote that you have. If none of the codes above work, please post back with make and model of your universal remote included.
    Thank you for using FixYa.
    Jas247
    Sep 01, 2007 | Sanyo DS31590 31" TV
    GE RM24948 Remote Control Logo
    473 people viewed this question
    Top GE Televison & Video Experts
    matt martin
    matt martin
    Are you a GE Televison and Video Expert? Answer questions, earn points and help others
