Question about Frigidaire ATF6000ES Front Load Washer
LOAD KNOCKING NOISE WHEN OPARATING THE FRONT LOAD WASHER
    Brigadier General:
  • 6,277 Answers
It is necessary to ensure absolutely that the machine, even when empty, has all 4 feet very firmly on the floor, and I mean firmly ;-0)
Doesn't matter whether it is empty or not but switch it off then-
very firmly push one front corner diagonally into the centre of the machine and see if the machine moves or rocks AT ALL, even the slightest. If it does you will need the open-ended spanner which came with the (new) machine........which of course went missing a long time ago?!! An adjustable spanner will suffice.
Adjust the foot under that corner downwards until it is very firmly- almost pushing- against the floor but not so far that the corner lifts up!
If this corner did not rock do the same to the other.
Once you cannot rock the machine the slightest little bit, screw the locking nuts up tight to the underside of the machine so that they will not move. Ideally the rear feet should also be locked.
If this has not cured the problem it is possible that the internal drum suspension is malfunctioning.
Good luck,
John C
Posted on Mar 17, 2011
Loud knocking during spinning
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about the noise and vibration that front loadwashers can make..
Washer Problems Washer noise when spinning
heatman101
Aug 21, 2011 | GE WSXH208A Front Load Washer
I have a maytag mah8700aww washer,when it goes into spin,there a loud knocking sound
heatman101
Aug 13, 2011 | Maytag Neptune MAH5500B Front Load Washer
DURING THE SPIN CYCLE THE WASHER STAR KNOCKING.
Check out this tip I wrote about the noise and vibration that front load washers can make..
heatman101
Apr 20, 2011 | GE WSXH208A Front Load Washer
LOUD NOISE AND KNOCKING ON FAST SPIN
Washer Problems
heatman101
Feb 21, 2011 | Hotpoint Aquarius WF220 Front Load Washer
Whirlpool duet steam washer knocking noise when in spin cycle.
Washer Problems
heatman101
Feb 13, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Final spin is knocking
Washer Problems
heatman101
Jan 16, 2011 | Frigidaire ATF6000ES Front Load Washer
Washer is making a knocking noise as it turns
heatman101
Nov 25, 2010 | Whirlpool Duet GHW9150P Front Load Washer
It has begun to make a loud knocking noise when on fast spin, what could be the problem?
Its very possible that the load you have in the washer was too big, you had too many clothes in there. That or you had something heavy like shoes or something in there or while washing your load got off balance (clothes shifted to one side) and thats what started the knocking.
May 15, 2010 | Zanussi FJS1225W Front Load Washer
Samsung front loan washer makes knocking noise during rinse cycle.
I have had a repair guy out for a separate issue and been told my knocking noise most prominent during rinse and spin is the bearings going. I have a samsung WDJ1225c front loader
May 14, 2010 | Samsung WF337AA Front Load Washer
Fridgidaire Washer has a loud knocking noise during spin cycle.
You need to replace your washer, the Inner tub Spider broke.. I repaired mine, With me doing the labour, $285 just for the part alone. plus about 3 to 4 hours labour.
Mar 14, 2009 | Frigidaire FWTBB30DS Front Load Washer
Frigidaire ATF6000ES Front Load Washer Logo
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
