Question about VeriFone 900 Printer
Printer begins to randomly feed paper and will sometimes feed two feet or more of paper without any transaction. If you tear off the paper, the VeriFone will continue feeding paper without stopping. We are wasting a huge amount of paper.
    Problem Solver:
  • 5 Answers
It's because of power issue You have to disconnect all the cables and clean make sure no dirt Connect the printer first and power up the register If still the problem persists you need to replace some files by doing a dialin
Posted on Jun 07, 2011
Printer will not advance to tear after print
I can't give the exact solution for this printer, however, I use the Epson POS thermal printer and here was our solution. In Windows 7 go to Devices and Printers. Click on Printer Properties. Then see if you see a tab that says Document Settings. Under that setting click on Paper Source. You should now see several options; I have mine set on Document(Feed, No Cut). There are other options but we prefer to tear ours off. You can chose Document(Feed, Cut) and it should advance then cut the paper for you.
Jul 10, 2014 | Datamax E-Class E-4205A Direct Thermal...
Paper stuck in printer
The best thing to do is gently try to remove it, without tearing it and leaving chunks behind. A pair of tweezers can be a great help. Some printers have a "feed" option to manually feed the paper. You might want to try it if your printer has the facility, feeding will turn the rollers and potentially release the paper. Be careful and check direction of feed as it could just as likely make the problem worse if it feeds the paper further into the printer.
Mar 27, 2014 | Dell, Inc Dell Color Printer C1760nw -...
Canon LBP 5050N Printer keeps coming up with paper jam. Have turned off, then turned on. Still did not fix. Can you help?
My LBP 5050N would print one page normally then stop with the next sheet just starting to feed (i.e. just touching the first feed wheel). When I took the paper tray out, there was one sheet left behind and I could pull that out easily without it tearing. It was gripped lightly at the beginning of the feed path.
Starting the printer again gave me another copy of the already-printed sheet (I guess that's Windows getting an error message from the printer and treating it as not having printed the first sheet).
As it will always print one page properly before jamming on the next one, the problem was obviously not a small piece of paper stuck somewhere.
I cleaned the rubber wheels with Isopropyl Alcohol as best I could, but they were not obviously dirty or slick/hardened with age. The result was the same.
Then I noticed that the two blue paper grips on each side of the tray showed a small gap of 1 or 2mm. I pushed them in to tighten them gently against the paper and the problem was solved.
I've been searching in many places for an answer to the 'frequent paper jam problem' and not seen this mentioned, so thought it would be useful to have it on record here.
Yeah, I was mentally challenged - I focused on the wrong thing from the beginning.
Feb 18, 2013 | Canon LBP5050N A4 Colour Laser Printer...
HOT TO ADJUST THE TEAR HEIGHT ON A MICROLINE 490 WITHOUT USING THE SETUP DISC
If you are using regular letter size continuous printer paper, load the paper normally with the machine turned off. You can even turn the knob to feed the paper through, it doesn't matter how far. Turn the printer back on and press "PARK" button. Then press the "FF/LOAD" button and when you begin printing it will automatically print at the top of form (TOF). If the TOF ever gets thrown off you can press "LINE FEED" until the tear is where you want it and press "SHIFT" > "TOF" to back back to the previous page (or top of form).
Simply put, pressing "PARK" then "LOAD" should set the tear where you need it.
May 20, 2011 | OKI MICROLINE 490 Matrix Printer
Paper feed not move
If I recall the KXP series, it is a track feed printer as well as sheet feed, there should be a lever on the top that you can move to different positions, one position is for feeding paper without the rollers, when the lever is placed in a different position it releases the rollers so the printer can feed the paper. The open position is for installing paper or clearing paper jams. Also if I recall, the lever is on the right side near the roller on the end. When you move the lever, and turn the roller, you fill feel it grab the paper. There is also a switch on the front for line feed and page feed allowing you to tear off a page and then pressing it again will reverse the paper to print position.
Aug 30, 2009 | Panasonic KX-P3696 Matrix Printer
Printer will not feed paper
there could be a small paper jam or then theres a problem with the pickup but try this solution first in making sure theres no jam:
  1. Turn off the printer.
  2. Remove any paper trays. Inspect them for wrinkled or damaged paper.
  3. Also open the back cover of the printer if this model has one.
  4. Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
  5. If necessary, remove the toner or ink cartridge. Place it away from light/ sun light to avoid damaging it.
  6. If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
  7. If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though. Do this step especially if the jam message comes up repeatedly without any obvious paper jam, there may be a small tear of paper inside.
  8. Ones the printer is free of paper Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
  9. If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
  10. see alternative if the problem is still not solved.
alternative :
Load a piece of thick paper, for example photo paper and press the resume button (may be diffrent button on diffrent models) a few times to the printer picks up the paper and puts it through the machine.
Jun 03, 2009 | Dell A920 InkJet Printer
Wrong adjustment using epson LQ-2180
Check to see if the pinch roller is set for standard sheet feeding the printer must feed by the tractor feed only.Does the paper get damaged when you try to feed or reset the page beginning, What we are looking for is a piece of one of the sheets loged in the pinch roller.Also check the pressure adjuster on the right side if you are not using multiple copie printing it should be set to medium . Let me know what you found... Be mucho blessed... Mark
Jun 27, 2008 | Epson LQ-2180 Matrix Printer
Label not advancing to tear-off perforation
Try this to have the printer auto-sense the size of the labels:
1. Make sure that printer power is off.
2. Press and hold the feed button.
3. Turn printer power on.
4. When the status light blinks, release
the feed button.
5. The printer advances the media to
measure and verify the length of
individual labels or tags. The printer
then prints a status summary and
remains in diagnostic dump mode.
6. To begin normal operation, tap the
feed button. The printer prints "out of
DUMP" and advances a label.
May 14, 2008 | Zebra LP 2844 Thermal Printer
Randomly printer stops printing - need switch off and on to restart printing
Sounds like you are just beginning to have problems with the paper feeding. Try cleaning the roller or applying rubber cement per my other post on the paper feed topic.
Apr 12, 2008 | Samsung ML 1210 Laser Printer
VeriFone 900 Printer Logo
143 people viewed this question
Top VeriFone Office Equipment & Supplies Experts
George Mclaughlin
Willie Cooper
Willie Cooper
Are you a VeriFone Office Equipment and Supply Expert? Answer questions, earn points and help others
