Question about Danby DWC513BLS Wine Cooler
DWC283BLS Interior fan clcles on and off All the time
  • rgnetz Mar 17, 2011
    This unit has auto defrost!!!!!!!!!!!!! the fan cicles ever 25 seconds on and off.
  • 4,924 Answers
This is normal ...It's job is to keep the interior ventilated so that the temperature to be even inside...and only when the sensor detects a difference in the sides it goes on to ventilate ...if it do not starts at all is a reason to be worry ...cause in that case it is frosty ...and need to be defrosted right the way to assure a good and even temp. in all the cooler's interior..
Posted on Mar 17, 2011
  • Catalin Turcu
    Catalin Turcu Mar 18, 2011
    if it is that often it means that this is the way it was set to work ...as long as the compressor do not start but when it is needed ..the fan does that cause it is probably in a power saving mode...For most refrigerators the ventilator fan works all the time ....unless it is in power saving mode or the unit is equipped with sensors for temperature differences...and starts only when is needed..
Fans stopped working
go to sears parts direct and enter your DWC283BLS you will have the plan and number parts you need
Mar 15, 2014 | Danby DWC283BLS Wine Cooler
F230073 p c card
try there http://www.searspartsdirect.com/partsdirect/part-model/Danby-Parts/Wine-beverage-cooler-Parts/Model-DWC283BLS/3055/0169000/50031952/00001?blt=06&prst=0&shdMod=DWC283BLS
Dec 16, 2013 | Danby DWC283BLS Wine Cooler
Need parts diagram for dwc283bls-1
http://www.searspartsdirect.com/partsdirect/part-model/Danby-Parts/Wine-beverage-cooler-Parts/Model-DWC283BLS/3055/0169000?pathTaken=&prst=0&shdMod=DWC283BLS
Dec 25, 2012 | Danby DWC283BLS Wine Cooler
My Danby has become loud and it sounds like maybe an issue with the fan. What should I do?
might be that the fan blades strike the casing. switch of your cooler. pull the plug out to prevent el-schock. turn fan blades manually and observe....
Mar 03, 2011 | Danby DWC283BLS Wine Cooler
Describe your danby dwc283bls top fan does not work. after removing the fan ,the problem is no output from the logic board, defective board or another part,sensor etc.????
Hi,from your problem,it seems the problem is from the logic board,you can however use a mulimeter to read the voltage supplied by the board,if it reads a low amount of voltage it means the board need to be serviced and cleaned thoroughly,but if it reads no voltage at all meaning its not supplying no amount of power,it means the logical board is bad and needs to be replaced.
Thanks and take care
May 06, 2010 | Danby DWC283BLS Wine Cooler
We have a danby dwc283bls wine cooler that no longer cools, and the compressor gets warm (above normal) does it need to be recharged
that's always a possibility but not always the case. The thermostat may not be cycling correctly or set wrong. The condenser could be dirty or if there is a fan, it may not be running. Freeze ups can also cause an "Out of temp." condition. Check it out.
Apr 15, 2010 | Danby DWC283BLS Wine Cooler
Top evaporator fan not working and compressor hot , not cooling below 79 degrees
the top fan is not suppose to run all thetime only when its too cold and the heater kicks then the top fan will come on,you probley have a leak in the system
Nov 10, 2009 | Danby DWC283BLS Wine Cooler
Compressor runs and gets hot but does not cool unit
This product has been discontinued
i dont think many danby units are parts supported
more likely generic after market parts fitted by air con mechanics do the job
relay first might be a thematic one and an compressor motor fan relay
then check gas pressure
https://www.winecoolerdirect.com/danby-wine-cooler-dual-zone-dwc283bls/DWC283BLS.html
Service Manual.pdfwww.reliablepartsinc.com/danby/Manuals%20.../Service%20Manuals/DWC282%20%...
Mar 06, 2017 | Danby DWC283BLS Wine Cooler
Danby DWC513BLS Wine Cooler Logo
76 people viewed this question
Top Danby Refrigerators Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
jason
Are you a Danby Refrigerator Expert? Answer questions, earn points and help others
