Question about Apple iPhone Smartphone
Hi, my iphone is switched off and i dont know why I can not put this on, although it is off its getting warmer
  • 314 Answers
Hi gawlisia,
i highly recommend you taking your Iphone to the place where you bought it and ask them to check the problem. if you dont in time it might explode, so please do hurry.
i hope this helps, good luck!
Posted on Mar 17, 2011
I was out at the bar i was kind of intoxicated i put a passcode on my ipod touch now i dont know what it is and cant bypass it how can i reset my ipod touch???? or bypass the passcode i set???
There is no way to get around a password that you dont know. The best way to do it is to reset the device.
To reset:
Plug your iPhone into your PC or Mac with the USB cable
Press and hold the power button at the top and then slide to power off the iPhone
Press the power button to power the iPhone on and keep it held while simultaneously pressing the home button
After a few seconds a yellow alert triangle will appear and the iPhone will say it is iPhone Restore Mode.
Open up iTunes and click on the Summary tab
Click on Restore to restore your iPhone. This will reset all your iPhone's setting to the factory defaults, including the Passcode.
May 06, 2011 | Apple iPod touch
My iphone cannot detect sim card after fall down, no service at all although I took out n put in my sim card for many times, help~
You have damaged your iPhone or your SIM card.
If you have another phone, you could test your SIM card by putting it into it. If it works, then it's likely an issue with your iPhone. If you can borrow a friend's SIM card, you can try putting that in your iPhone. If it works then you know you have a problem with your SIM card.
In either case, you should talk to your service provider to see if they can repair it for you.
Mar 28, 2011 | Computers & Internet
My iphone turned off and wont turn back on
I know this sounds stupid and Im sure your not but does it have power? What happens when you connect the charger? It could just be faulty why dont you try phoning apple and asking for a repair or maybe a replacement Im not sure about the iphone3 because I've got the iphone4 although Im sure they are not too different.
Feb 12, 2011 | Apple iPhone 3G
My iPhone says: 'iPhone is disabled connect to iTunes' And when I do connect to iTunes, it says that I need to enter passcode in my iPhone to enter the phone. But when I slide to unlock the phone, it goes...
How long have you had the phone? it could be the software at fault, best bets is what Damien729 has already said, although you dont need to press the buttons simultaneously, just switch your phone off press the home button and keep it held down then connect your phone to itunes and restore as a new iphone, if you restore from a back up all your old software will be back on and you'll have the same prob!
Dec 19, 2010 | Apple iPhone 3G
Help on frozen iphone 3.1.3...want to restore
just switch off your phone and press home button and connect to cable and restore it from there it would get solved
May 25, 2010 | Apple iPhone 3G
The screen of my iphone doesnt work and it didnt get wet
i have the same problem this morning with my iphone i dont know what to do
Jan 31, 2010 | Apple iPhone Smartphone
I forgot the password for my iphone
If you have forgotten your iPhone’s Passcode you will need to restore your phone via iTunes.
1. First you have to put your phone into the restore mode which is a slightly fiddly process.
2. Plug your iPhone into your PC or Mac with the USB cable
3. Press and hold the power button at the top and then slide to power off the iPhone
4. Press the power button to power the iPhone on and keep it held while simultaneously pressing the home button
5. After a few seconds a yellow alert triangle will appear and the iPhone will say it is iPhone Restore Mode.
6. Open up iTunes and click on the Summary tab
7. Click on Restore to restore your iPhone. This will reset all your iPhone’s setting to the factory defaults, including the Passcode.
You should then follow these steps below to activate the passcode again.
  1. Click the Home button to bring up the main menu
  2. Click on Settings
  3. In the Settings screen click on General
  4. In the General screen click on Passcode Lock
  5. This will open the Set Passcode screen. Enter a memorable 4-figure code and re-enter it when prompted
  6. You will now be at the Passcode Lock screen. You can change when you are prompted to enter the Passcode. The default setting – Immediately – means you will be asked to enter it as soon as your start using the iPhone. But you can change the setting so that the prompt appears after a certain period of use
  7. Press the Home button to return to the main menu.
Dec 11, 2009 | Apple iPhone 3G
My iphone says !NO SERVICE! please Help!
Your sim is bad. Get a new one. If your using it off network that is probably a huge issue. If your not recognized on a network then they won't give you service
Oct 09, 2009 | Apple iPhone Smartphone
When i put my iphone's ringtone sound to the highest notch and when someone calles me it just vibrates. i dont know why. ive been working on it for hours but it still wouldnt work. please help me??...
There is a switch above the ringer volume. This switch turns the audible ringer to vibrate. Make sure to switch it to on. (If you are using a soft case, many of those are bad about hitting this button to off.)
Jun 23, 2009 | Apple iPhone Smartphone
CECT P168
try this ...this will show you how.
please rate me as fixya.
watch the video it will walk you threw the whole thing.
it should work...although i have not done this so good luck.
Aug 16, 2008 | Apple iPhone Smartphone
Apple iPhone Smartphone Logo
18 people viewed this question
Top Apple Cell Phones Experts
David
Martin Murray
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
