Question about Dell 3100cn Laser Printer
Can't get the cartridge out to replace with new on.
  • 314 Answers
Hi bbroyles662,
I would highly recommend for you to look through the Manual which came with your printer, they should have Detailed information on how to remove and replace the cartridge ink.
i hope this helps, good luck!
Posted on Mar 17, 2011
Replace drum in xerox phaser
asic technical parameters forToner cartridge chip of Xerox Phaser 3450B:
chip-b.jpg" ]
Version: No area limited
Yield: 5,000-10,000.
Printers Model compatible: Xerox Phaser 3450B
Toner cartridge Model: Xerox 106R00687-BK and Xerox 106R00688-BK.
Manufacturer regulations pages yield ofToner cartridge chip for Xerox Phaser 3450Bis 5,000-10,000 then printer do not print andDrum chip for Xerox Phaser 3450Bhas mission paper pages count.You should resetDrum chip for Xerox Phaser 3450Bcaused by following reasons:
And then, you can choose one in three following plans: replace Toner cartridge, replace Drum chip or reset Toner cartridge chip.
1.Replace new Toner cartridge for Xerox Phaser 3450B:
- If you choose plan replace Toner cartridge then cost is too high. Each Toner cartridge for Xerox Phaser 3450B (Xerox 106R00687-BK and Xerox 106R00688-BK Toner cartridge) costs about $150 - $200
- With replace new Toner cartridge solution is not optimal, because the price is quite expensive.
- When Xerox Phaser 3450B shows errors about computing limits of Toner cartridge chip, you continue to replace new unit.
2.Replace new Toner cartridge chip for Xerox Phaser 3450B :
khe-chip-b.jpg" ]
- If you choose plan replace Drum chip then cost higher than reset chip. EachToner cartridge chip for Xerox Phaser 3450Bcosts about $6 - $10/color.
- With replace new Toner cartridge chip solution is cheaper replace new Toner cartridge.
- When Xerox Phaser 3450B shows errors about computing limits of Toner cartridge chip, you continue to replace new Toner cartridge chip.
3. Reset Toner cartridge chip for Xerox Phaser 3450B
If you choose plan resetToner cartridge chip for Xerox Phaser 3450Bthen that is best plan. It cheaper than replace Toner cartridge or replace Drum chip
The phenomenonToner cartridge chip for Xerox Phaser 3450Bout of count are printer do not print and display error on the LCD monitor:
-"Drum low", "Drum eppty", on monitor laptop or desktop appear yellow exclamation mark corresponding color, on monitor printer report Drum empty.
-"Tone life end", "Replace new unit"
- "The x unit an error". In that "x" is color of Toner cartridge or code of Toner cartridge
How to fix the errors:"Drum low", "Drum eppty", on monitor appear yellow exclamation mark corresponding color,"Tone life end", "Replace new unit", "The x unit an error"? cheaper, the most effective.
We use unismart device toreset Drum chip for Xerox Phaser 3450B
Unismart is a device reset Drum chip. Unismart can reset for many Drum chip of manufacturers: Samsung, Hp, Canon, Epson, OKI, Xerox ...
Unismart system is designed to offer a complete solution for writing, resetting, testing various chips with the combination of Unismart Box and Unismart chips. Unismart include: unismart box and test head, power adapter, Data wire, flat writer.
unismart1.jpg" ]
Test head is used for data transmission between Unismart Box and Unismart chips. There are 20 types of test heads designed according to different chip shape, which can be used for operation on all chip models that
current Unismart system supports. Please choose the right test head in accordance with the PCB code. Some PCBs share a same test head, which is clearly indicated in the chip compatible list.
In Case You Still Having Problem Then Follow Us For On :Xerox Printer Support
Jan 23, 2014 | Xerox Phaser® 860, 8200 Standard Capacity...
How to remove ink
http://support.dell.com/support/edocs/systems/PRN810/en/index.htm#online_documentation
Jan 20, 2011 | Dell 810 All-In-One InkJet Printer
Hp printer model A909a indicated new ink cartridge needed. When I installed new cartridge kept giving message needed new cartridge. When I removed new cartridge ink was leaking on outside edge of...
Follow the instructions below to replace the printheads in the All-in-One product.
Video of replacing the printhead
The following video demonstrates how to replace the cartridges and the printhead. You do not necessarily need to replace the cartridges. Simply refer to the video for replacing the printhead, and then stop the video.
Aug 28, 2010 | HP Office Equipment & Supplies
What is the replacement printer for HP Laser Jet
This document provides information about replacing the print cartridge for the HP LaserJet 1010 printer series, including life expectancy and replacement instructions. Print cartridge life expectancy The life of the print cartridge depends on the amount of toner that your print jobs require. When printing text on letter/A4-size paper at five percent coverage, the print cartridge lasts an average of 2,000 pages. This assumes that you set the print density to three and disable EconoMode. (These are the default settings.) See Ordering supplies for information on ordering replacement print cartridges. Changing the print cartridge Follow the below instructions to change the print cartridge:
  1. Open the print cartridge door, and remove the old print cartridge. See the recycling information inside the print cartridge box. Figure 1: Removing old print cartridge c00028312.gif CAUTION: To prevent damage, do not expose the print cartridge to light. Cover it with a piece of paper.
  2. Remove the new print cartridge from the packaging, and gently shake it from side to side to distribute the toner evenly inside the cartridge. Figure 2: Gently shaking new print cartridge c00028313.gif
  3. Pull the tab until all the tape is removed from the print cartridge. Put the tab in the print cartridge box to return for recycling. Figure 3: Removing tape from print cartridge c00035442.gif
  4. Insert the print cartridge in the printer, making sure that the print cartridge is in position. Close the print cartridge door. Figure 4: Inserting new print cartridge c00028315.gif
Apr 20, 2010 | HP LaserJet 1010 Printer
Replaced black ink cartridge and printer keeps asking to replace
The message that persists in saying to "replace black cartridge" could be due to a defective cartridge chip. The chip maintains counts and tells the printer when a new cartridge is installed. If you cartridge is remanufactured, they may have neglected to install a new chip.
Regarding the new fuser not working, I'll have to get back to you on that.
Oct 15, 2009 | HP LaserJet 4600dn Color Printer
I recently replaced the magenta cartridge in my HP 3210 Photosmart printer because the light indicated it needed to be replaced. However, the printer still won't print, and the message still says that I...
If you turned the machine off and replaced the cartridge, you can get this error.
Could you try the following procedure below please to clear the error, thanks.
  1. Turn on the unit.
  2. Open the top cover to access the print cartridges.
  3. Remove the new cartridge that is causing the message.
  4. Reinsert the cartridge and close the cover. The following message will appear on the front panel: "Press 1 for new cartridge or press 2 for a used cartridge."
  5. Press the 1 on the numeric keypad of the HP product.
If the message, press 1 for new cartridge or press 2 for a used cartridge, "does not appear after removing and reinstalling the new cartridge, and the low ink warning message still displays,
follow the steps below:
  2. Open the top cover to access the ink cartridges.
  3. After the cartridges stop moving, unplug the power cord.
  4. Remove both cartridges and close the top cover.
  5. Plug the power back in. The unit will reinitialize and a message will appear to insert the cartridges.
  6. Open the top cover and reinsert the ink cartridges. Close the top cover. The message,
  7. Press 1 for new cartridge or press 2 for a used cartridge," should appear.
Hope this helps
Regards.
Apr 18, 2009 | HP Photosmart 3310 Printer
HP Photosmart 3310 printer shows all ink cartridges need replaced
If you ran the ink cartridge refill routine, from your desktop using the utility supplied by HP, this should not occur, so try running the head cleaning and alignment routines and see if this clears up the problems.
I am assuming that all your cartridges are relatively full and trouble free and that the printer has been successfully and recently used, prior to your replacement of the one new cartridge.
Sometimes, if the printer has been idle for some time without use, the ink will dry on the heads of perfectly good cartridges, causing the problem you cite.
Use alchohol based cleaner with the kind pads supplied with a new cartridge to regularly clean the heads of your ink cartridges, according to instructions in your manual and CAREFULLY, so as to not damage the heads.
Apr 07, 2009 | HP Photosmart 3310 Printer
Dell 3100cn Laser Printer Logo
20 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
