Question about BenQ G900WAD LCD Monitor
Hello, Small question i noticed that the light/dark colors is not quite as it shoud be. I tried already to adjust the brightnes and the other options i haver in windows but still its either to dark or to white in some parts. I don't have the driver installed yet, -it's only the default Plug and Play monitor driver from windows. Can this be the cause or is this coming from the video card? Any sugestion would help, thanks in advance, V Sabin
5 Suggested Answers
SOURCE: BENQ FP731s Monitor Problem white blank screen
BenQ brand new high-voltage wire circle
BenQ LCD Controls circle / BenQ LCD accessories more high success rate, and easy maintenance, fault lower again!
Name : LCD Controls circle
Model : specifications : 1J.26048.011
BenQ LCD accessories four small mouth lights of the high-pressure reverse pressure plate used for high temperature must Taiwan curbs are enameled wire system. With a small noise, power, brightness control in high-efficiency low-loss. Rapid cooling loop can be designed according to customer-specific products.
2 features the use of high-precision inverter line Rao, insulation and can be a long time. 3 to 1. Electricity use light line measurement of high-frequency currents. 2. Backlight voltage output of a sinusoidal waveform. 3. The backlight brightness and the same as the original high-pressure plate. 4. 1-2 4.1 filament output AC exchange through the export of Maintenance and Spec - CN5 link to the. 5 and storage temperature and Temperature temperature ranges : -5 -- 50 ℃ work humidity range : 10% -- 95% RH the backlight should be within the scope of the above, the following conditions can store 40,000 hours. Operating temperature : -10 -- 80 ℃ work Humidity : 20% -- 95 % RH
BenQ LCD maintenance information
1 : BenQ LCD can switch planes normal (no signal light yellow, green signal), Looking carefully at the screen whether there are changes, they generally do not carefully read the screen can not see a change, oh, look at carefully Matata. Change or switch to a normal plane, the main board intact, such a high-pressure situation on board is no work, no lights lit backlight.
2 : disassemble machines, starting with high-pressure plate (box 220V piece of the plate), a screwdriver button open, not lazy. Power board and put the Main Board are removed, this is a good Off Power Plate,
3 : Measurement C5707, FQU11P06 (Some of the machines are used FU9024), whether the damage (breakdown) If the damage (breakdown), he seemed to see the appearance .22/160V capacitance whether deformation, If deformation replace, if not capacitance deformation on regardless.
4 : damage to the replacement of the device, if the fear of electricity burned again, you can Controls circle together too, In order to save costs if you should not start for high-voltage wire circle -- testing, If the damage C5707 meeting on the need to replace the high-voltage wire coils (most of the damage to the C5707 is Controls 72.9% Circle aroused),
5 : measurement of high voltage power supply board whether short circuit, without short-circuiting I would be grateful if insurance (PF801) new ones (General C5707 damage, insurance will certainly damage), If you do not have insurance you connect with fine copper wire, this 3-A insurance. Please stop the PF801 power-measurement, measurement inaccurate.
Understand how maintenance of electronic maintenance steps friends
2 : disassemble machines, starting with high-pressure plate (box 220V piece of the plate), a screwdriver button open, not lazy. Power board and put the Main Board are removed, this is a good power to remove board.
3 : replacement C5707 4 (Q809, Q808, loops, Q815) four high-voltage wire coils (T001, T002, T003, T004). 2 FQU11P06 or FU9024 (Qingdao, Q805). PF801 Insurance (insurance for the three A).
Posted on Dec 27, 2007
SOURCE: benq computer monitor shuts down after standby in energy saving..
There are 6 (reduced quality) capacitors in the BenQ Q9W5 which cause the screen over time to 'fail to sync' when turning on or resuming from standby.
They are;
4x 470uF 35v, and
2x 1000uF 16v.
I recommend the following replacements if you are in Australia (the ones I purchased from Jaycar only lasted 12 months);
(470uF) http://www.altronics.com.au/index.asp?area=item&id=R4865
(1000uF) http://www.altronics.com.au/index.asp?area=item&id=R5182
Posted on Aug 05, 2010
2pagescouk
  • 325 Answers
SOURCE: i have LCD monitor screen & windows xp as
may not be THE solution, but try turning your refresh rate in you video settings down to 60hz
to do this right click somewhere on the screen desktop
left click properties click settings tab click advanced click monitor tab there should be a screen refresh rate dropbox
select 60hz then apply
Posted on Mar 20, 2011
  • 160 Answers
SOURCE: ~Hello! My monitor dispays picture, but
Hey, have you bene able to try another monitor and see if its the same thing?
Check andmake sure that all of your cables are tight and secure. If they are then you probably have a bad video card. they are fairly easy to replace:
Posted on Jul 15, 2011
Hi the screen on my 176c is so dark it can barely be read. I have to turn the light on to see whats going on.Is there any way to restore it to its former glory cheers ......john wainwright. ...
John, the light sensitive IC has failed. This is a small piece of electronic wizardry that adjusts the brightnessdepending on the ambient light. At night is is supposed to add brightnes and in sunlight reduce it
The sign of failure may have been early but you didint notice it. They often turn on ok then suddenly in daylight the screen will darken, turning the unit off and on resets it for a while. however it gets worse as time goes on.. iT is not a DIY and has to be sent back to the manufacturer for correction.
Contact Garmin for a quote before submitting it for repair, you might need a chair to sit on when they give you an answer. Contact the service support in 7 hills NSW 1 800 235 822
Please rate my help++++ Thanks forf using FIXYA
Aug 04, 2010 | Garmin GPSMAP 176C GPS Receiver
Color Speckling in Dark Part of Picture
the set needs to have an adjustment in the panel voltages. this must be done by a qualified tech. the panel has now gotten it's full aging and now needs to be adjusted. this adjustment does not need to be adjusted again after this has been done.
Feb 22, 2008 | LG 42PX5D 42 in. Plasma HDTV
When the screen is dark there are lines that run back and forth across the screen which is only noticable when pitcure is dark immage.
the screen bias needs to be turned down-ehind the front cover which is behind the grille there is a small black square about 3 inch square 6 little knobs sticking out 3 say in small letters screen and 3 say focus, don't adjust the focus just the screen for the coresponding color that shows up when picture is dark.best way to do this is darken the room and put it on video input with no signal if lines are white slowly
adjust 1 color after the other counterclockwise untill
lines disappear if only 1 color shows then only adjust the knob with the matching color. this is a very fine adjustment, to much will make your auto focus stop working. check it after you are done
Jun 20, 2010 | Sony KP-51HW40 51" Rear Projection...
Want a B&W copy from colored sheet of paper w/o dark background.
It's never going to be perfect (unless the background is quite light in colour), because the copier basically "sees" the coloured background as "gray", and the darker the background the more "gray" it looks. Try setting the original type to "photo" mode, and then adjusting the exposure a little lighter/darker....that's all you can basically do.
Mar 25, 2009 | Canon imageRUNNER C5180 Color Copier
The Contrast and Brightness on tv appears to be dark.
If this is a CRT-based TV and it's been played most of the time, you may have a bad picture tube, especially if strong red colors bleed to the right. CRT's dim with use, unlike LCD or plasma. But it could also be trouble in the video circuits - none of this falls into the DIY category, unfortunately. High voltage involved, unless you're comfortable around it and want to try turning up the screen controls inside the TV. If you do, let me know - but "no response at all" from the external adjustments points to a more serious problem.
Dec 10, 2008 | Toshiba 36AF41 36" TV
Mita dc 1560 prints are dark
nadark_1@yahoo.com
replace the Drum and the blade
Jul 14, 2008 | Kyocera KM-1505 Copier
Panasonic PT-61G63W Too much Black Serial No: MY83430025
The mirror should also be cleaned. but there is more adjustments that can bring up brightnes ie G2 on the flyback transformers but that is some thing a tech should do. Because you have to ad enough of each color to get a gray scale. if you are off the picture will be tinted and your color will be way off.
Dec 26, 2007 | Panasonic PT-61G54 61" Rear Projection...
Dark picture (projection tv)
Hi Steve,
The picture is darker because the dust build up on the lamps or CRTs. I would suggest to leave the TV unplug overnight and clean the lamps using a screen cleaner that works better then windex and clean the mirror that reflects the video to the screen if you can get access to it.
Mar 11, 2017 | Televison & Video
Awfull colors and very dark at 320x240
hello JareX Perhaps as far as I can tell you that your screen does not suppeot this resolution
Jan 20, 2007 | Samsung SyncMaster 740N 17" LCD Monitor
Dark spots on images
Dust on the CMOS sensor.
Sep 14, 2005 | Nikon D70 Digital Camera
BenQ G900WAD  LCD Monitor Logo
Top BenQ Computers & Internet Experts
JP Services
JP Services
Tony
Tommmix
Level 1 Expert
Are you a BenQ Computer and Internet Expert? Answer questions, earn points and help others
