Question about Thermador PRG304US Gas Kitchen Range
I have a 4 burner Thermador range/oven. I just cleaned the oven, now when I turn the oven on bake or convection I get an OFF message on the control panel. I have tried pushing every button thinking there is a reset but have not found the magic combination. The unit is approx8-10 years old. No manual
  • 24 Answers
Could you provide the part number of the control? Alternatively, you can look here for more information that may help diagnose the problem.
Posted on Mar 17, 2011
Top burners OK. On convect bake the oven will heat up to set temperature then shut off and cool down. Normal bake function seems to work ok.
PDF]BUILT-IN ELECTRIC CONVECTION OVEN - Whirlpool
https://www.whirlpool.com/.../Use%20and%...
Whirlpool Home AppliancesBUILT-IN ELECTRIC CONVECTION OVEN. Use & Care Guide ..... To Turn TonesOff/On: Touch and hold COOK TIME until a tone sounds and the lower oven ...
Teach me how to use my convection oven - Chowhound
Jan 01, 2016 | Maytag MES5875BAS Slide-In Electric Range...
Thermador Professional Oven
hey man don;t worry i have too much solution if i explain u every thing then you confused so i explain one and if u want another then e-mail me on mango4529@rediffmail.com so listen carefully
Step 1: Turn off the power supply, both gas and electric, to the range. Then remove the burner.
Step 2: Soak the burner in a solution of mild household detergent and water. Clean it with a soft cloth.
Step 3: Clear the gas ports with a pin or needle, rinse the burner, and let it dry. Caution: Do not use a toothpick or matchstick to clean the gas ports. If the tip of the wood gets stuck in the burner ports, it could cause a serious blockage.
Step 4: When the burner is completely dry, replace it, and turn on the power and the gas supply.
An oven that won't heat can occur for a variety of reasons.
and if not then open this link http://home.howstuffworks.com/how-to-repair-an-oven.htm
Nov 23, 2007 | Thermador POD301 30" Pro Series Deluxe...
1 of 2 bulbs in upper unit stopped working. I replaced the bulb 10W, 12v & both bulbs worked. Later, both bulbs stopped working. Both bulbs have continuity. New bulbs don't fix issue. Ideas??
Thermador Appliances ' Frequently Asked Questions ' Use ...
www.thermador.com/faq/categories.php?categoryid=53
ThermadorContact us for help with service & repair needs. ... The anti-tip bracket is not needed for 48" Harmony units. However, the anti-tip ... Oven light is not working properly. Replace ... Buy a replacement bulb. View the ... The rack positions that you would use when baking 3 racks in the convection mode would be racks 1,2 and 4.
Thermador Range/Stove/Oven Parts - RepairClinic.com
www.repairclinic.com/Shop...Parts/.../Thermador-Range-Stove-Oven-Par...
Huge selection of Thermador Range/Stove/Oven parts in stock. Same day ... Stove top potentiometer Kit that contains 2 potentiometer's and 1 simmer controller.
[PDF]for Thermador Professional Series Built-in Wall Ovens
www.msaworld.com/.../Service-Manual-Therm-Pro-BIWO_RevA3.pdf
Dec 19, 2015 | Thermador C272 Electric Double Oven
Thermador has had sudden no gas to whole unit
They may have accidentally turned off a little gas cock which is cunningly hidden on the front panel can\'t remember if it\'s top or bottom, it isolates the gas to the main control valve.
Mar 20, 2014 | capital Precision GCR484G 48" Pro-Style...
Seimans HD 2515 Oven stopped working
I have this same problem. Any resolution on the others' problem?
Mar 11, 2010 | Siemens HD2515U Stainless Steel Dual Fuel...
Self-clean turns off after 5 minutes with F2 error message
Hi MaryB,
F2 error code means that the oven temperature is too hot. You will have to replace relay board if faulty. Check and replace oven temperature sensor (RTD). If failure repeats, replace ERC (electronic range control or clock).For replacement part you may contact Sears at 1-800-252-1698; M-F 6:30 AM-10:30 PM - Sat 7:00 AM-9:30 PM - Sun 7:30 AM-9:30 PM - All times Central.
Hope this helps.
Thank you for using FixYa.
Apr 15, 2009 | Thermador C272 Electric Double Oven
Heating element on upper oven of a wall Thermador Oven
The control switch may be bad on it. If there are 2 elements on the top, they both are not bad at the same time.Check to see if the wires have not burned off the control switch first. Check to see if your breakers are O.K. Turn them both(maybe 3) off and then reset.
Jan 30, 2009 | Thermador Ovens
After running self cleaning cycle, oven won't heat.
I own a similar range. As you can imagine I was dismayed to find out that my $6000 heap can't run a clean cycle, unless of course you just don't want to use your oven again. let me give you a tip something WILL break on your oven every time you use the self cleaning "feature".
The first time I used the self cleaning feature the board burnt up, I asumed hat this was a fluke. The second time the pvertemp sensor burnt out. The next few times that I was brave enough to try it the overtemp sensor triggered this is what I hope has gone wrong with yours since while it's not easy or convenient to fix it is free. If you pull out your range and remove the backsplash and then the rear panel there should be a breaker with a button you can push to reset. On mine it is located near the top of the oven compartment on the left side near the middle. I hope that works for you and you will soon learn as I have after doing this a few times that the self cleaning cycle is just not worth it. It willdo this every time and it really is just easier to use easy off and clean the oven by hand. I realize that is not what you had in mind doing when you bought a luxury Item like a 36" thermador range, but I hope you don't have to hate yours as much as I hate mine.
Aug 26, 2008 | Thermador PGR366 Gas Kitchen Range
Both ovens do not heat max heat is 150 to 200
good luck.  We have the same range and have had issues with the ovens since the range was installed.  The overn does not heat evenly on convenction or bake.  Thermadore doesn't stand behind the product and neither does the distributor.  They tell us that Thermador isn't standing behind the product so there isn't anything that can be done.  We spent $8000 for an oven that burns the back corners of everything we bake.
Mar 21, 2007 | Thermador PG484GGEBS Stainless Steel...
After self cleaning, Range trips circuit breaker when using convection
self cleaning ovens use super hot seting to bake the oven clean and it sounds like it melted a wire and it is shorting out the oven on that setting. look at the wires you can see or easy to remove panels
Dec 22, 2006 | GE Profile JGS968 Gas Kitchen Range
Thermador PRG304US Gas Kitchen Range Logo
358 people viewed this question
Top Thermador Kitchen Ranges Experts
Dan Webster
Dan Webster
Colin Stickland
Colin Stickland
Are you a Thermador Kitchen Range Expert? Answer questions, earn points and help others
