Question about Sony CDX-CA810X CD Player
I got a sony cdx ca810x stereo and none of the face buttons work is there a way to reset it or is there something wrong with the unit please help as I have no money to buy another
    Sniper:
  • 50 Answers
Hello... I am sorry to hear you are having problems. You can manually reset the cd player. You can use a pencil or ink pen to press the small button to reset the unit. If you flip the face down it should be there on the actual unit. I should say "reset". This probably will not fix your problem. The other thing you should do is to remove the face and clean the contacts with a q-tip and some rubbing alcohol and see if that will remove any debris that may be hindering a good connection. Make sure the face is attached back onto the unit securely. If after doing this, it is still inoperable, then you will need to replace the unit. Unfortunately, at this point there would be no way to tell if it is the face or the unit itself that is bad, so complete replacement would be the best option. Sony has been good about keeping the same harnesses through many years, so it is possible that if you replace it, get another Sony and it will plug directly in and save you any install and parts costs. Hope this helped!! Good luck with your venture!!
20 year car audio/video installer
Bay manager
Posted on Mar 17, 2011
  • manaudio Aug 13, 2011
    Well just do one thing . change all the switches of your front panel . thats all you have to do ..... Man Audio Visual .... Pioneer Kenwood Authorized service centre .!! +919898615326, +919033769245
Sony CDX-CA810X / CD-playback drops aux amplifier
Do you have the remote turn on lead hooked up to solid blue wire from the back of the deck? Your amp shoild be hooked up to Bluw w/ white strip as the solid blue wire shuts off when the tuner is off, its used only for the power antenna.
Use Blu w/ Wht strip for amps
Jun 03, 2009 | Sony CDX-CA810X CD Player
The radio was working, but had to replace cars battery. Now nothing. Fuse is OK.
It's normally just a blown fuse in your main fuse box under the steering wheel area. I'm assuming that when you say you checked "the fuse" you mean the one on the back of the radio unit itself.
Make sure all the wires are connected properly (especially the power and ground wires)
Good Luck!
Apr 13, 2009 | Sony CDX-C5000X
Sony cdx-m630
I have a few suggestions that may help. Have you checked the fuses?There is on on the stereo and one in the car's fuse box. Are all of theconnections from the wiring harness secure? Make sure these are tightand show no signs of damage, especially the ground connection. Also, ifthe face is detachable, check the connectors (on the face and thestereo) for damage or dirt or anything that would prevent a goodconnection. Pushing the reset button should not have prevented you fromoperation of the unit, so it has to be either an external fault (likewhat I described above) or an internal problem. How old is the CDplayer? If it is still under warranty, I would call Sony or go to theirwebsite and speak to one of their techs. You can go to the site byclicking on the blue link: Sony Support Hope this helps... Please take time to rate how helpful this was. Thanks and good luck!
Sep 10, 2008 | Sony CDX-M630 CD Player
Sony CDX-M8800 face plate is non responsive
There is a ribbon cable that tells the face what to do. You will have to take it in to get serviced as it is very hard to change. There are alot of pieces / parts inside.
hope this helps
May 30, 2008 | Sony CDX-M8800 CD Player
CD won't work
Have you tried using the reset button on the front of the unit (under the face panel)
Jan 13, 2008 | Sony CDX-L400X CD Player
Sony CDX-M630
not open the face? or not get on the stereo? if not open the face maybe is too fit on the space for the stereo, check down if have space, if dont get on, check if are well conected
Nov 02, 2007 | Sony CDX-M630 CD Player
Sony cdx m610
The ribbon that connects the faceplate to the main unit has gone bad from flexing back and forth and will need to be replaced.
Oct 10, 2007 | Sony CDX-M610 CD Player
Sony CDX M8800 Front Panel Problem
u need 2 replace the ribbon that goes to the panel to the unit.i had the same problem with mine then i went on to ebay and found the ribbon there (cdx-m8800 repair kit)hope this helps
Dec 17, 2006 | Sony CDX-M8800 CD Player
Face does not come down and remote won't work
EXTREMELY common problem for these units. The faceplate ribbon cable has gone bad and needs to be replaced.
Sep 20, 2006 | Sony CDX-M800 CD Player
Sony CDX-CA810X CD Player Logo
98 people viewed this question
Top Sony Car Audio & Video Experts
xxxxxx xxx
Larry Stiles
Larry Stiles
Philip Rowney
Philip Rowney
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
