HOW TO REMOVE BATTERY FROM LATERAL THIGH TRAINER
    Novelist:
  • 137 Answers
It's in the Right Foot Pedal.  Under the right foot pedal is a "Computer Compartment" the battery is there: 1 AAA battery, should do it.
Link to the Manufacturer Owner's Manual.  You'll find battery installation under: "Assembly" (section 6).
Thank You For Choosing FixYa~!
Posted on Mar 17, 2011
What caused this groin?
The area between the abdomen and the thigh on either side of the body is known as the groin. Do you perhaps mean something else?
Sep 06, 2017 | The Health & Beauty
My lateral thigh trainer is stuck in one position and won't move when stood on.How can I loosen it?
Eat more Big Mac Meals and drink more beer. The resulting weight gain might break the tensioner loose. Also take the trainer tension adjuster apart, clean and lubricate it just a bit.
Apr 01, 2016 | Cars & Trucks
HOW DO I REMOVE THE OIL PAN OFF A 2003 DODGE STRATUS 2.4L 4CYL
Oil pan removal
1. Disconnect negative cable from battery.
2. Raise vehicle on hoist.
3. Drain engine oil and remove oil filter.
4. Remove oil filter adaptor from engine block
5. Remove structural collar
6. Remove lateral bending brace.
7. Remove transaxle dust cover.
8. Remove oil pan bolts.
9. Remove oil pan.
Feb 09, 2015 | 2003 Dodge Stratus
How to replace honda pilot steering lock assembaly
disconnect the battery.remove the lower dash cover.remove the steering column cover. locate 4 bolts holding the steering column to body and remove.don't let the column fail and brake wires.disconnect any wire if you need to lower the column.on upper part of ignition look you will find 2 bolt with round head broken sight in center.use chisel and lose the 2 bolt.remove the old look and install the new one. thigh slowly 2 bolt alternate to insure the look tight even on both side.on end the security head will break.lift the column and thigh the 4 bolt.connect any wire disconnected before.install the covers.
good luck
Mar 29, 2014 | Vehicle Parts & Accessories
The power cord on my lateral thigh trainer broke. Where can I get a replacement?
This is posted in the TV section but either look online for whoever made the unit or if it is a conventional cord (3 pin) like a computer or appliance you should be able to find it local.
If the power cord is wired in (not a plug in) most electronics shops will be able to sell you the part.
Let me know if you have questions as I am here to help
Mar 14, 2012 | Televison & Video
I need a diagram for installing rear struts for a 1996 plymouth neon, needing to know if i need a spring compressor to remove the old and install the new ones. and where i can find the best price for new...
  1. Raise and safely support the vehicle.
  2. Remove the wheel and tire assembly.
0900c15280079486.jpg enlarge_icon.gifenlarge_tooltip.gif Fig. Fig. 1: These vehicles are equipped with front (1) and rear (2) lateral links
  1. Remove the nut, bolt and washers attaching the lateral links to the knuckle.
0900c15280079487.jpg enlarge_icon.gifenlarge_tooltip.gif Fig. Fig. 2: Lateral link-to-knuckle attachment
  1. Unfasten the nut, bolt washer and toe adjustment cam securing the lateral link(s) requiring removal from the rear crossmember. Then, remove the lateral link(s) from the vehicle.
0900c15280079488.jpg enlarge_icon.gifenlarge_tooltip.gif Fig. Fig. 3: Rear lateral link removal
0900c15280079489.jpg enlarge_icon.gifenlarge_tooltip.gif Fig. Fig. 4: The lateral link also attaches to the rear crossmember
Jan 16, 2010 | Plymouth Neon Cars & Trucks
Replace heater core in 1994 pontiac grand am
Removal & Installation
  1. Disconnect the negative battery cable.
  2. Drain and recycle the engine coolant.
  3. Raise and safely support the front of the vehicle.
  4. If necessary, remove the rear lateral transaxle strut mount.
  5. Detach the drain tube, then disconnect the heater hoses from the core tubes.
  6. Carefully lower the vehicle.
  7. Remove the console if equipped.
  8. Unfasten and remove the sound insulators, console extensions and/or steering column filler, as required.
Unfasten the sound insulator retaining bolts ...
... then remove the sound insulator
  1. On some models it may be necessary to remove the steering column opening filler.
  2. Remove the floor or console outlet ductwork and hoses.
  3. Remove the heater core access cover.
Unfasten the heater core mounting clamps/bolts, then extract the heater core from the vehicle.
Unfasten the heater core retaining bolts; most later models are secured with clamps.
Remove the heater core from the vehicle
To install:
  1. Install the heater core, then secure using the clamps/bolts.
  2. Fasten the heater core cover.
  3. Connect the outlet hoses and ducts.
  4. Install the sound insulators, console extensions and/or steering column filler.
  5. Raise and safely support the vehicle.
  6. Install the drain tube and connect the heater hoses to the core tubes.
  7. If removed, install the rear lateral transaxle strut mount, if removed.
  8. Carefully lower the vehicle.
  9. Connect the negative battery cable.
  10. Fill cooling system and check for leaks. Start the engine and allow to come to normal operating temperature. Recheck for leaks and check coolant level. Add if necessary.
Nov 13, 2009 | 1994 Pontiac Grand Am
Cant figure out how to open back of phone to put in new battery
First: you need to simply remove the back; then after you remove the back the battery will be there. If it wasnt removed simply remove the battery from the back of the phone without it getting wet. There might be some slight difculty doing this. What you have to do is ; slam the back of you're phone; on you're thigh if you have anyproblems. also place the sim card in behind the battery u will find the sim card slot; . Then place it in the slot facing up wards.
Thank You; :-* Hope it works!
May 02, 2009 | T-Mobile Sidekick II
Computers & Internet Logo
718 people viewed this question
David Payne
David Payne
