Question about Frigidaire GLTF2940ES Front Load Washer
My washer wont spin
I have a frigid air front load washer. it was working fine but then i got a e 70 error message and then the spin cycle would not work. help me please i have only owned for 1 year and i cant afford a new one.
  • dshanem Aug 10, 2008
    During spin cycle the machine makes a screeching noise, and the drum does not turn. any ideas?
Frigidaire front loader model # GLTF2940ES3.
Cycle ended prior to spin segment. Checked error code history to find E47 fault. Troubleshot per manual. Found that the "PTC one-spot check" read ~1582ohms. Although the book indicates that this is sufficient and recommends (rather tells) you to replace the control board we were still skeptical seeing as this is a ONE POINT check on a device that is non-linear. We went with the lesser of two evils. Purchased and replaced a new door lock. Works again! Phew, that could have been costly.
Posted on Aug 05, 2008
GE will not go on wash cycle and keeps filling up. It will drain and go on spin cycle. but on normal wash will not work. how to fix please
Posted on Aug 29, 2011
I have a frigid aire front loading washer that is very noisy during the spin cycle. Sounds like a banging nose. Thinking it is the Shocks, bearing to the drum, or unknown. Helpful diagnosing tips?
As I could see it is bearing problem and very costly repair over $300
You should use it until it dies and then try buy new cheaper model top load washer such as top load Inglis or top load washers under $300
Dec 06, 2013 | Washing Machines
Spin cycle does not engage
UPLOADING OR FRONT LOADING WASHER..........CHECK ITS BALANCE LEVELS.
Feb 24, 2012 | Maytag Neptune MAH5500B Front Load Washer
My washer seems not to spin properly during the rinse cycle and will not spin now i get what i assume is an error message ue when its time for the spin cycle to begin
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Feb 18, 2011 | LG WM2455 Front Load Washer
My amana front load washer wont spin and is showing an "nd" error message. what does this mean and how do i fix it?
Hi
Thanks for using FixYa. From what I understand the error code ND means “No Drain issue”. You’ll need to check for any restriction in pump assembly. It can also be due to a restricted drain hose or loose wire at pump. If after cleaning the drain hose the issue is not resolved then it means the pump has gone bad and unfortunately needs to be replaced. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Aug 28, 2010 | Maytag NFW7200TW Front Load Washer
Spin cycle is not working error message F3
you have a blockage,also is there a plastic ball and ring in the sump hose.if yes take out and throw it away
May 25, 2010 | Asko W6461TS Titanium Stainless Front Load...
Error code f 70 and 71
F 70 overloaded
F 71 suds detect
To review: You got too many clothes up in here and you is using too much soap. These machines measure the weight. Take some things out or if you only have a small load add some things. It also measures the water quality in a load to determine IF a load is clean enough. Too much detergent throws the machine off. Then it trys to correct the problem many times and that heats up the motor and wrecks the sensors.
Basic rule of thumb:
HE: (2) Tablespoons Per Wash load
HE 2X (double concentrated) : (1) Tablespoon
HE 3X (triple concentrated): (1) Teaspoon
This reduces/prevents:
1) Musty Odor
2) Errors/Interrupted Cycles
3) L-O-N-G Cycle Times (longer than time displayed)
4) Insufficient Cleaning Results
5) Small Water Leaks from the air vent behind the washer or at the
front door gasket
6) Damaged sensors
7) Reduced Spin Speeds (laundry not spin-dried effectively)
Apr 11, 2010 | Maytag Bravos 4.5 Cu. Ft. Washer
Washer won't spin. Washed bath mats (small) and
Read a post from someone else on this - turned out it works fine, just wouldn't work with the small wet load. I added towels to the bath mat load, washed them, it spins fine. Washed clothes & that worked fine too. Yay!! Not broken. Just not found of small loads of bath mats!
Jan 22, 2010 | Frigidaire ATF6000ES Front Load Washer
Error Message and Tub not spinning
UE is likely an unbalanced load or load is too large. Reduce the size of the load and your issue should be resolved.
Jul 21, 2009 | LG WM-2277HW Front Load Washer
Frigidaire GLTF2940ES Front Load Washer Logo
534 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
