Question about Epson Stylus Photo R340 InkJet Printer
I have cleaned the nozzle, but didn't do the alcohol syringe thing. Where do I put the alcohol. I wiped the post, that is not what you are talking about. I can't see where the ink goes into the head. My problem is that my printed pictures do not look at all like the jpeg picture before printing. For example, I had a light background and it prints out green. Can someone give me some suggestions
  • 108 Answers
Don't use a alcohol it may be damage your printer head.
Posted on Jan 07, 2012
Nozzle cleaning
Use old cartridge and put isopropyl alcohol with a mixtue of 3 parts alcohol to 1 part water into cartritge with a syringe . Go thrugh cleaning cycle 4-5 times and let sit with newspaper under printer for any leaks. Run cleaning cycle several times until you get printer to run clear on sheet of paper. Reinstall cartridge with new ink. Lot of work but have done this and it will work. Make sure you clean out old cartridge with alcohol first over sink and fill each color chamber up with mixture before installing cleaning cartridge. Also eBay offers some of these cleaning cartridges.
Jul 08, 2017 | Epson Stylus Photo R2400 InkJet Printer
My Canon won't clean its print heads
Have you tried power cycling the printer?
Feb 17, 2008 | Canon i860 InkJet Photo Printer
Black ink will not print but colors do
Most likely culprit is a dried up ink within the nozzles themselves. The best things for getting rid of dried ink in the nozzles is to use either a standard bathroom cleaner or rubbing alcohol. With the printer on open the door as if you were replacing ink. With the ink cartidges visable, unplug the printer so they stay put. Remove the cartridge and spray the cleaner in the where the ink is taking from the cartridge and clean it with whatever works. I really really good trick is if you have an old cartridge you can use a syringe to fill up the empty cartridge with your cleaning solution or rubbing alcohol. Insert the cartridge and run some test prints. This will for sure run the cleaner through the nozzle and hopefully dissolve the blockage.
Nov 29, 2011 | HP Photosmart C6180 All-In-One InkJet...
Printer acts like it is printing but it spits out blank paper. Ink supply shows up as good. What could it be?
If the printer has not been used in some time ink may have dried in the print head. Unfortunately Epson have a non-removable head, so it can not be cleaned without a kit available for purchase. If you have installed new cartridges make sure any air tags have been removed. these are usually on the top of compatible cartridges or on the bottom of Epson brand cartridges.
The kits are available online, Search for Epson head Cleaning Kits and you will find one.
I hope this helps
Regards GM
Apr 21, 2011 | Epson Stylus C88 InkJet Photo Printer
The printer turn on ok , then whene i print any thing the printer work ok but its not printing on the paper .
It seems like its a jammed print head for this try cleaning your print head using the cleaning utility thats present in your printer software, (NOTE: Head cleaning will consume a lot of ink) Or you can just clean your head with isopropryl alcohol.
Requirements:- 1. Isopropryl alcohol 2. Syringe 10 or 20ml 3. Tube(I used medical tube) that fits in the tip of the syringe and the nozzle
Steps: 1. First remove the needle from the syringe and fit the tube into the tip till its firm. 2. Pull 10 ml of isopropryl alcohol inside the syringe (note: no vacuum or air should remain inside the syringe) 3. Fit the tip of the tube on the nozzle of the print head and slowly squirt about 5ml of isopropryl into the nozzle and pull back till all the isopropryl comes back while pulling back clogged inks will come inside the syringe repeat this till the nozzle is clear. repeat this to all the nozzles. don't forget to throw away all the dirts (clogged inks that will come inside the syringe) and do it slowly, though it will take much time but it will be helpful. I was able to clear my jammed print head with this procedure hope this will help you.
Apr 17, 2011 | Epson STYLUS R230 InkJet Photo Printer
Hi from Finland. I have epson stylus photo r220 printer. Automatic printheads cleaning does not help. Is manual nozzle clogging with alcohol possible? And is manual ink pad cleaning with isoprophyl alcohol...
For the Ink Pads you can use just water but you have to dissasemble the printer to get them out.
For cleaning the nozzels you can use distilled water with a small syringe put a little in every color into the PRINTHEAD not into the cartridges and let it sit a couple of hours then try again the nozzle check. Good luck
Oct 21, 2010 | Epson Stylus Photo R220 InkJet Printer
The cyan isn'r printing. I cleaned and changed the cartridge. If clogged is there a way for me to unclog the nozzle?
Use a syringe filled with a liquid head cleaner. Add tip syringe with flexible hose (like the hose on the outlet head cleaning mechanic). Remove the ink tanks. Hose into the nozzle.Give the pressure slowly until the liquid head cleaner in the syringe out. Make sure no liquid is spilled in the vicinity of the nozzle. Replace the ink tanks, nozzle check and head cleaning. Is there a change from the nozzle check from the previous?
Sep 29, 2010 | Epson Artisan 700 InkJet Printer
How to clean cartridge
Once you remove the ink cartridge from the printer, you can make use of the Isopropyl Alcohol, and put at maximum of 10 drops in the ink cartridge. You will find a hole there, in which the ink usually runs from the ink cartridge to the head of the printer. When done, you can put the cartridge back in the printer and run the auto cleaning process from the printer's option in order to clean the blocked holes of the cartridge. I would suggest you to run print tests first and once you are satisfied with the results, you can start using the printer normally.
If you want to go further:
  • Remove the tank.
  • Connect a hose directly on the inlet ink.
  • Locate the sensor of reservoir and press it to make as if a cartridge is available.
  • Close the cover of the print head and clean the head by injecting air (under pressure) through the pipe.
  • Replace the tank up and do a test print.
  • Repeat the procedure several times if the nozzles are clogged.
Using a syringe and some alcohol to unblock the holes can also be very effective.
  • Step 1: Remove the cartridge from the computer
  • Step 2: With the syringe, take in some alcohol and put in some drops in the tiny hole where the ink runs from the ink cartridge to the head of the printer.
  • Step 3: When done, put the cartridge (only where the tiny holes are found) in some warm water. If some ink runs in the water, it means that the holes have been unblocked.
  • Step 4: Hence, let the alcohol act for 20 minutes on the ink before putting the cartridge back in the printer.
  • Step 5: Run some test prints before using the printer normally.
Note: I would suggest you to do an automatic head cleaning each time before any printing task. Hence it will reduce the risk of having the print heads blocked by dried ink.
Apr 03, 2010 | Lexmark Inkjet Z517 Photo Printer
MY YELLOW AND MAGENTA INK DOES NOT PRINT. i HAVE RUN THE CLEANER OPTION NUMOROUIS TIMES WITH NO SUCCESS. WHAT NOW?
Try using a cleaner. I went to youtube and got some ideas about cleaning the inkjet nozzles. You can find a cleaner kit (Liquid and Syringe) on ebay.
You will need to remove the cartridges and slide head to the middle. Make sure you get a paper towel underneath the head, just fold the paper towel so that it is thin enough to slide underneath the head.
You can use a water dropper to put a few drops of water and alcohol (If you don't have the cleaning kit). I tried using alcohol, some people say don't use alcohol, some say use Windex, but I just tried water and alcohol.
Drop alcohol on top of nozzle. Wait about 10 minutes. Towel will soak the alcohol and water. Insert cartridges and try printing.
I had the same problem, yellow and magenta was not printing. After researching on the internet, I decided to try cleaning it myself with alcohol. I was able to get the magenta to print, but yellow still is not printing, so now I am waiting for the cleaner kit with the syringe. The alcohol did make the other colors come out richer and crisper, so it must have done something right.
Anyhow, let me know what you decide to do and if it works for you.
Dec 13, 2009 | Epson Stylus 2200 InkJet Photo Printer
Epsom R340
print a nozzle check from the maintenance menu
see which colours are missing, run through a few head cleans and print another nozzle check see if there is any improvement
also replace the cartridges of the missing colour they may be dried up. have seen this before where a 3/4 full black cartridge just completely stopped printing
if the problem still persists then get a syringe or an eye dropper and some form of spirit (I have used vodka in the past but clinical alcohol is recommended as not as sticky)
choose change cartridges from the menu then remove the power cord. with the cartridges removed you now have access to the printheads.
using the syringe (or eye dropper) place the nozzle on the spike that goes into the cartrige and inject a small amount of the alcohol leave this to soak for a few mins then mop up the excess with a cloth repeat this a couple of times put the ink back in power up and run another head clean (you can also put afew drops on the spounge that sits under the print head during the head clean
print the nozzle check again you shoudl see most of the nozzles are now working run another head clean if desired now try with a pic
have used this on various epson printers including a stylus 700 R340 & 360
Jul 27, 2008 | Epson Stylus Photo R340 InkJet Printer
Epson Stylus Photo R340 InkJet Printer Logo
Top Epson Office Equipment & Supplies Experts
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
