Question about Sanyo Televison & Video
I have an older sanyo dvd player the surround sound is built in an doesn't have plug ins in the back for the speaker but stripped bare wires. Well any way the remote control number RB-TS760MT has quit working again, If I bye another one this is three I would have for this dvd. Is there problems with these remotes and is their anything sony can do for me. These remotes are 30 dollors apiece and I'm dissabled and can't afford to bye another remote or a surround sound dvd system. Thank you Curtis Cifelli
SOURCE: Cant find universal remote control code for Curtis DVD Player model 1056
stop buying Curtis BS products!!
Posted on Oct 02, 2008
SOURCE: Curtis DVD-7620 (7600 series) Combo VHS / DVD Player - what is remote code?
It all depends on the brand of remote your trying to program,for a nexxtech the codes are one or the other 0929 or 0928.
Try typing in the search engine for example Curtis vcr/dvd7600 RCA universal remote codes. You may get better results.
I hope this helps you.
If not at least you will learn how to use the different code retreival methods they don't tell you in the booklets/pamplets that come with them or if you lost it.
Good luck
Posted on Nov 23, 2008
  • 46 Answers
SOURCE: codes to program a universal remote to this device
You can try the following four digit codes:
0670, 0695, 0873, or 1919.
Posted on Jan 20, 2009
SOURCE: Panasonic DMR- EA18 DVD player/recorder - Remote control Problem
I figured out, unlike all the other posts, you don't have an enter button. But Instead, you would hit the 2 and OK button at the same time for a few seconds. I had the RC1 message and I did the 1 with OK and it worked. so if you have RC2, you should hit the 2 and OK. Should work!!
Posted on Jan 31, 2009
SOURCE: remote control code number
20816, 20874, 21023, 21129
Posted on Apr 24, 2009
Hi i have recently got a lg surround system without a manual, i think all the speakers are set up correctly as i have done a sound test on it and they all seem to make noise however i am having trouble...
You should have 2 RCA jacks on your TV and on the back of your receiver ... a white and a red. These are the left and right audio jacks. Generally, I hook up the audio out from the TV to the DVD player, then from there into the receiver ... this makes it easier to turn off the connection to your receiver if you want to use the TV speakers for news and whatever (by turning the DVD player off). Once the RCA cables are all hooked up, the information should have no problem transferring to your surround sound receiver. Now that the connections are all made, check the settings on your receiver. Make sure that you have the surround sound turned on, and that the receiver has all speakers selected (hunt through the menus and find the "dolby 5.1" or "THX" surround options and turn one on. This SHOULD resolve the problem.
If this did not repair your issue, make sure that all of your equipment that you are running through is all capable of surround sound (if you have a really cheap DVD player like me, it may not be able to handle surround sound). If your TV is surround capable (LCD, Projection, and Plasma TVs are usually all capable of this ... CRT tvs are not always capable) but your DVD player is not, hook your TV's audio RCA cables directly to your surround sound receiver and you should be set. If your TV and DVD player are not capable of Dolby or THX surround sound, then you will probably not be able to use that feature, so your satellite speakers might not work, but the main left and right should still work fine.
One other thing that I have had issues with in the past is the connections on the back of the receiver. If you are using speaker wire (a lot of newer systems have input jacks instead of wire because they are easier to deal with) then make sure you have stripped enough of the wire to make a good connection in the back of your receiver. If you have too little wire exposed, or if you have pushed the wires in too far, the insulator on the wire will block the connection. To be sure this is not the case, be sure that only the exposed part of the wire is sticking into the back of your receiver. Also, make sure that you are not trying to run too much wire between the receiver and the speakers -- if you have a 100ft wire between the system and the speakers, they might not be getting a strong enough signal to work -- you can buy a signal amplifier for your speaker wire, or you can use a shorter wire.
Most likely you have to find the settings in your menu and turn on the other speakers. If the sound test worked for all of the speakers, the connections are all good, and it is the system not telling the speakers to work.
May 26, 2011 | Nintendo Wii Console
My Logitech computer speakers are playing distorted sound. Also notice that the green power light is dim and wavering.
Could be the outlet, or the power strip if it is on one. would try a new outlet in a different room. return the speakers if this does not work.
May 02, 2011 | Logitech Audio Players & Recorders
I can hear the music when playing dvd's on my Spectoniq dvd player, but can't hear when people talk. Can anyone help me?
Yes, I can help you. Your DVD player should have output connectors in the back of it to plug your amplifier or receiver into. If you have a Stereo system (no surround sound speakers, or front center speaker) connect the DVD Audio Cables on the back of the DVD player to the STEREO Output Jacks. If it is connected to the Left Front and Right Front jacks of the "Surround Sound" output jacks instead of Stereo is that the dialog on is sent to the CENTER channel output. If you have no center channel speaker you will not hear it.
If you have a surround sound system with two speakers in front and two speaker in back. Then you need to make a change in the Receiver Setup (Which may be set up for 3 speakers in front) so that it is set up for 2 speakers in front.
The last thing my simply be that you have a center channel front speaker that is not completely connected because of a wire falling off, etc.
Hope this helps,
Best,
Mark
Jan 13, 2011 | Spectroniq PD-3000HD
I only get sound out of 2 front speakers with 5.1.
refer owner manual page 46-51, try different surrounding sound modes.
Apr 08, 2009 | Sony STR-DG510 Receiver
No 5.1 surround when adding a Philips upconvert player to the San
Sounds like you are getting analog signals from your componet cables and a true digital input from your HDMI into your tv.
However that unit is Analog audio input x 1 only.
So i dont think your going to get true digital surround sound.
The problem being
Sanyo =
Inputs: Analog Audio x 1 Outputs: Composite x 1 · S-Video x 1 · Component x 1 · Digital Audio Coaxial x
Feb 03, 2009 | Sanyo DWM-2500 System
I cut a speaker wire
well I have in the past been able to strip the rubber back to the bare wire on both ends and then twist them together. use electrical tape to cover any exposed wire this should fix it.
Jan 25, 2009 | Durabrand 5.1 Surround Sound Computer...
Umi freeview dvd tv combo to surround sound
I am not familiar with the manufacture and model of your TV set. This does appear to be a compatibility issue between the TV set and its DVD player, and the surround speaker system. The TV set may not be able to directly send the proper information to the speakers. I would consider to call the manufacture support people to have a definate answer.
Jerry G.
Dec 28, 2008 | Philips 17MD250V 17.1 in. LCD TV/DVD Combo
Help getting sound from New Sony LCD Television Model XV HTD520 DVD Player with Surround Sound S HTD520
While I could not find it in the manual, I found that you must
go to the menu, open Sound Options and set Speakers to "Fixed".
Note: If you turn off the Surround Sound or DVD player combination you must then go back to the menu and turn the speakers back to Televsion.
Jul 21, 2008 | Audio Players & Recorders
No sound
u gotta make sure all the connectors are right, The dvd player output cables are plugged into the OUTPUT of ur dvd, and they go into the Video Input of the amplifier, U gotta make sure ur speakers are plugged in into right too, out put speakers. Surround system only works on DVDs and some music CDS, so dont expext to have surround sound from all music CDS/
Feb 10, 2008 | Audio Players & Recorders
Televison & Video Logo
60 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
