Question about Seth Thomas Radio-Controlled Howard Wall Clock - SET717
Since DST started I cannot get my radio controlled clock to reset to the actual time. I replaced the battery and now the clock will set itself four hours from the time it stopped, then stop again. i have placed the clock in front of a window for three days in a row, nothing. Help
  • 604 Answers
Take the batteries back out and leave them out for at least 2 minutes. next put the batteries back in and put the clock near a wall or window so that the back of the clock faces colorado (where the WMV transmitter is),. It will most likely take all night for it to set properly, just after you put in the battery make sure that you have set your time zone on the back of the clock and if there is DST button press that too. just be patient, it will set itself. worse comes to worse you can set it by hand, but kind of defeats the purpose of having an "atomic clock". by the way the reason they call it "atomic" is becausee WMV's clock is tracking the decay of the Seisum atom, or some such bs.
Posted on Mar 17, 2011
    Brigadier General:
  • 8,546 Answers
Yiou have to make sure you have the cirrect time zone set.
After replacing the batteries in both the clock and the outside unit, everything is perfect except I cannot get the clock to allow me to change to Central Standard Time. Have followed instructions...
Hello
After replacing the batteries do the following to set the time.
To set up your clock simply install one fresh AA, LR6 ALKALINE battery. Due to the nature of long wave radio signals it is normally not possible to receive a signal during the day so it is best to install the battery late in the evening. Select your time zone by pressing one of the four time zone buttons PT-Pacific Time, MT-Mountain Time, CT-Central Time, ET-Eastern Time. The time zone buttons may be pressed any time after installing the batteries. If multiple buttons are pressed the clock will set to the time zone selected last. If no time zone is selected the clock will default to Pacific Time. Another time zone can be selected during or after the clock has set itself. Your clock can only set itself to one of the four time zones stated above. For time zones outside of PT, MT, CT or ET you must manually set the time using the Manual Time set button on the back of the movement.
When the battery is installed the second hand will advance eight seconds (two seconds per step x four steps). The clock is now searching for a signal. For the initial setting it is recommended to stand the clock in an upright position near a window. Within five minutes the clock will either receive the WWVB signal and set itself to the exact time, or it will determine that the signal is not receivable at its current location and time of day. If a signal is not receivable it will fast-forward the hands to the 4, 8, or 12 o'clock position and search for WWVB each
hour until a signal is received. If the time is manually set the clock will continue to periodically search for a signal and automatically reset the hands when the signal is received.
Select a location to place your radio controlled clock where it will be at least six feet away from a TV, computer, air conditioner or other household electrical appliances. The optimal location is near a window. Windows facing Colorado providing the best signal. The WWVB time signal will easily penetrate Masonry and wood framed buildings. WWVB will penetrate almost every residential building and most steel buildings if they have adequate windows. It is not possible, however, for WWVB to penetrate most indoor shopping malls and rooms in the center of large office buildings that do not have windows. In buildings that WWVB cannot penetrate you may set the time using the manual time set button. When the clock is exposed to the WWVB signal it will automatically set the hands to the exact time.
OK.
Aug 25, 2011 | La Crosse Radio Controlled Atomic Clock
Our Skyscan atomic wall clock will not stay at the correct time since we had the daylight savings time. I replaced the battery because each day at noon it would randomly reset it self to the old time (1...
take the batteries out and leave them out for at least a minute. when you put the (new) battereis back in be sure that you have the correct time zone pushed and if there is a DST button or switch make sure that is pushed/set as well. place the clock with its back facing colorado and leave it overnight, it should reset itself ok.
Mar 17, 2011 | SkyScan 86709 Atomic Wall Clock
I am having problems setting the alarms on my Emerson Smart Set clock
Directions for Resetting the Daylight Savings Time (DST) Start & End Dates on the Emerson Research Smartset Dual Alarm Clock Radio (cks5055s):
  • This should work for all Smartsets, but I cannot make the guarantee (and no, I don't have any other directions, sorry)!
  • Adjusting the DST Start Date on an Emerson Research Smartset:
    1. Depress & hold the MONTH/DATE and the ALARM1 buttons (at the same time). After 3 seconds the display will show the DST 'start' month, week, and date. It should be alternately showing "4 F" (April and first week week) and "4. 1".
    2. While still holding the MONT/DATE and the ALARM1 buttons, press the DOWN (or "-") button 3 times, until the display is showing "3" (March) and the week as "F2". It should alternately flash "3 F2" and "3. 11".
    3. After this is set, the clock should "automatically" reset itself
  • Adjusting the DST End Date on an Emerson Research Smartset:
    1. Depress & hold the MONTH/DATE and the ALARM2 buttons (at the same time). After 3 seconds the display will show the DST 'end' month, week, and date. It should be alternately showing "10 L" (October and last week week) and "10. 28".
    2. While still holding the MONT/DATE and the ALARM1 buttons, press the UP (or "+") button 1 time, until the display is showing "11" (November) and the week as "F". It should alternately flash "11 F" and "11. 4".
One thing to note, if you ever have to change the lithium backup battery for the Smartset clocks, it will revert back to it's factory defaults and you'll have to go through his all over again.
And this conclude's Search Marketing Guru's public service announcement. :) We'll be back with relevant online marketing posts with our next posting!
Nov 03, 2010 | Vacuums
Oregon Scientific Model 323a--Atomic clock...the atomic clock keeps setting itself to one hour behind what time it actually is in my time zone...I mannually re-set the clock to the correct time...but when...
Make sure that the clock is set for the correct time zone and that the DST (Daylight Saving Time) function is ON. Also, although not mentioned in the manuals, these clocks will typically jump and hour ahead or behind when the batteries get weak. Replace your batteries if they are more than a year old.
Bill B
Mar 21, 2010 | Oregon Scientific RM323A Travel Alarm...
New daylight savings schedule
(http://www.emersonradio.com/dst.htm) Copy this web link and paste it into the address bar of the browser. It will take you to the Emerson customer support web page. On this page is the update for setting the day light saving time function on your clock/radio. You may also have to replace the internal battery in the clock/radios to keep it working up to date. The battery usually has a three year life span. This may be shorten by power outages and leaving the radios unplugged for long periods of time. I hope this information helps you with your problem.(http://www.emersonradio.com/dst.htm) Copy this web link and paste it into the address bar of the browser. It will take you to the Emerson customer support web page. On this page is the update for setting the day light saving time function on your clock/radio. You may also have to replace the internal battery in the clock/radios to keep it working up to date. The battery usually has a three year life span. This may be shorten by power outages and leaving the radios unplugged for long periods of time. I hope this information helps you with your problem.(http://www.emersonradio.com/dst.htm) Copy this web link and paste it into the address bar of the browser. It will take you to the Emerson customer support web page. On this page is the update for setting the day light saving time function on your clock/radio. You may also have to replace the internal battery in the clock/radios to keep it working up to date. The battery usually has a three year life span. This may be shorten by power outages and leaving the radios unplugged for long periods of time. I hope this information helps you with your problem.(http://www.emersonradio.com/dst.htm) Copy this web link and paste it into the address bar of the browser. It will take you to the Emerson customer support web page. On this page is the update for setting the day light saving time function on your clock/radio. You may also have to replace the internal battery in the clock/radios to keep it working up to date. The battery usually has a three year life span. This may be shorten by power outages and leaving the radios unplugged for long periods of time. I hope this information helps you with your problem.(http://www.emersonradio.com/dst.htm) Copy this web link and paste it into the address bar of the browser. It will take you to the Emerson customer support web page. On this page is the update for setting the day light saving time function on your clock/radio. You may also have to replace the internal battery in the clock/radios to keep it working up to date. The battery usually has a three year life span. This may be shorten by power outages and leaving the radios unplugged for long periods of time. I hope this information helps you with your problem.
Apr 06, 2009 | Emerson Smartset Clock Radio
RCA atomic clock radio didn't reset to DST
Perhaps you've already tried this but on my atomic clock I have to select the DST option and make sure you're in the correct time zone.
Mar 09, 2009 | RCA RP5430 Clock Radio
Daylight Savings Times Changed
Oct 29, 2007 | Emerson Smartset Clock Radio
Correct Time Zone
Using the Emerson CKD5809C manual (also with SmartSet(tm) ), try Zone 4. TIME ZONE button: "04".
Zone 1: Atlantic Time
Zone 2: Easter Time (Default)
Zone 3: Central Time
Zone 4: Mountain Time
Zone 5: Pacific Time
Zone 6: Yukon Time
Zone 7: Hawaiian Time
Reference:
http://www.emersonelectronics.ca/emerson/en/category/list/694
or
http://www.emersonelectronics.ca/emerson/en/product/details/2361
As for disabling the Daylight Saving Time (DST) time change I have some guesses to try (not having one of these radios in my hand) or just skip to #4 below.
1. Manually setting the time and see if this disables the DST change.
2. Is there a Zone setting other than above? Like maybe a Zone 0? And then manually set the time.
3. Look at http://www.fixya.com/support/t236208-daylight_savings_time_adjustment for my solution there and try adjusting the DST Start to the same as DST End or DST Start and End with a month of 0 (if that is possible).
4. Or for the really desperate, change the Zone to 5 during DST and back to 4 during standard time (no worst off than with no DST auto setting.) (After I wrote this, I found an Emerson reference to no DST areas, Saskatchewan in this case, in the CKS1850C manual http://www.emersonelectronics.ca/emerson/en/product/details/2383, pg 9, and this is their solution.)
Oct 28, 2007 | Emerson CKS3029 Clock Radio
Emerson Research SmartSet Clock Radio
Hello everyone,
I finally found a manual that I hope that it will help you as much as it helped me. It took long enough. Here goes; try this site:
http://www.emersonradio.com/owners/SmartSet%20Series/
Oct 28, 2007 | Emerson Smartset Clock Radio
Daylight savings time again
Appparently the problem could be with your location, or just that there may be a delay before time correction until the old date - check again the link to amazon i posted before - there are a couple of new reviews that discusss the daylight saving issue, also - The US clock says; "I have a radio controlled clock that receives NIST time. Will the new rules affect me? Your radio controlled clock should automatically implement the new DST rules. The WWVB broadcast contains information that tells your clock whether DST or ST is currently in effect. NIST always sends this information to agree with the current DST rules, so your clock should change automatically on the day of the change, just as it has in previous years. If the time is wrong after the DST change, make sure that your clock has recently received the time signal. Many radio controlled clocks have a synchronization indicator that will tell you if your clock has recently synchronized. If the clock isn't receiving the signal, click here for some tips on improving reception. If it has received the signal recently, check to make sure that the clock's time zone setting is set properly. Also, if you live in an area where DST is not observed (Arizona, for example), you need to disable the automatic DST function on your clock. I have a non-radio controlled clock that used to automatically correct itself for DST. Will it still work? The only way to find out is to wait and see, or to contact the manufacturer of the clock. There are a large number of non-radio controlled clocks, marketed under names like "AUTOSET" or "SMARTSET" that have internal firmware that automatically changes the time by one hour on the transition days to and from DST. These clocks do not connect to a NIST time service, and some of them will no longer work properly due to the DST rule change. For example, clocks manufactured prior to the rule change will probably not switch to DST in March, but will wait until April in accordance with the old rule. If you have a clock like this that fails due to the new rules, your only recourse is to adjust the clock manually, or to contact the manufacturer and ask for an upgrade or a replacement. If you need to contact manufacturer check http://www.emersonscott.com/ezsetamclocr.html Hope this helps:)
Mar 11, 2007 | H.H. Scott SCR120 Clock Radio
Seth Thomas Radio-Controlled Howard Wall Clock - SET717 Logo
1,276 people viewed this question
Top Seth Thomas Audio Players & Recorders Experts
Dennis Key
Dennis Key
Are you a Seth Thomas Audio Player and Recorder Expert? Answer questions, earn points and help others
