Question about Canon PowerShot SD600 Digital Camera
  • Wesley Gardner
    Wesley Gardner May 11, 2010
    have you noticed the amount of pictures you are able to take going down more and more over time?
    or is this new batteries that you have placed in the camera?
Had the same problem. Open battery/memory card compartment and identify the protruding piece on the inside of the door which when the door is closed appears to make contact with a switch. I solved my problem by using a very soft pointed object and very very gently pushing down on the switch. Replace the battery & memory card and switch the camera on as normal. It worked for me which would suggest that maybe sometimes the switch can become stuck or the protruding part on the door does not make proper contact. Hope this works for you.
Posted on Aug 24, 2008
My fujifilm xp60 will not turn on, the battery is okay. the battery is inserted properly.What other cause could there be ?
Make sure battery is actually charged and charger is not faulty. Try a different battery? Make sure contacts on battery and camera are clean. If the camera still will not start, it may need to be serviced.
Sep 14, 2014 | FUJIFILM Cameras
Battery wont charge
As in the first part of the manual is explained, when you have inserted the battery correct and you then plug in the charger, the charger light should go on. When the light is out, the battery is charged. When the light blinks, your battery is fault.
When the light does not go on, when you plug it in a power outlet, the battery is not inserted correct, or the contacts are dirty.
If you want to clean the contacts, please only use a dry cloth. Never us a sharp tool. It would damage the contacts bend repair.
Even when you plug in the charger, with a fully loaded battery, the light should go on for only a few moments.
Make sure the power outlet works normally. and the power cable is not defect.
Dec 29, 2013 | Fuji FinePix F460 Digital Camera
Can not run netbook off battery even though battery shows fully charged' When charger is removed netboook will not turn on
Make sure the battery is fully inserted and clicks in to the netbook body. Your battery may also be showing that it's charged but is actually dead. Try a new battery and see if it solves your problem.
Jul 04, 2013 | Wolvol Mini NOTEBOOK COMPUTER Laptop...
I just got my Nikon D3100 and it wont turn on..why?? i didnt buy a memory card yet..doest it need memory card to turn on??
The battery ships in an uncharged state. Slip the battery into the charger until the it indicates it is fully charged. Install into the camera. The camera should power up without an SD/SDHC/SDXC type memory card installed - and should flash [-E-] in the viewfinder alerting you to the fact that no memory card is inserted.
Sep 06, 2011 | Nikon D3100 Digital Camera
How do I know when an EN-EL! for the Nikon Coolpix 5000 is fully charged? what do the following conditions indicate? 1. Charger red light flashing 2. charger red light steady 3. charger red light...
Charger flashing red indicates the battery is still not full and is in the process of recharging.
Red light steady indicates your battery is fully charged and ready to operate with your Coolpix 5000.
When red light is off it indicates there is no battery inserted or the charger is not pluged in.
Mar 26, 2011 | Nikon EN-EL1 Battery + Charger...
Camera never used and won't turn on, battery fully charged.Ideas? Thanks, Deb
The fe-280 user manual notes hat it is possible to insert the battery "the wrong way round" in either the charger, or camera itself (whereupon its hard to extract).
An extract from the faq about it .....
The camera no longer powers on. What could be wrong?
The battery may be dead or underpowered.
If the battery is completely drained, the camera will not power on when the Power button is pressed. If the battery is nearly drained, the camera may briefly display a Battery Empty error message and then power off, or it may power on and then quickly power off without displaying the error. In either case, charge the battery using the LI-40C battery charger bundled with the camera.
Be sure to properly align the arrow on the bundled battery with the arrow on the bundled battery charger. It is possible to force the battery into the charger so that the arrows are not aligned. This is an improper orientation, and the battery will not be charged. For instructions on how to properly inset the battery into the charger, please see "How do I charge the lithium-ion battery?"
So in a nutshell, the first few steps to check are:
1) Are you sure the battery is charged correctly?
2) Have you inserted it into the camera body correctly?
3) Do you have a spare charged battery to check the camera with? (A photo store will do this for you sometimes, if you ask nicely).
Feb 25, 2010 | Olympus FE-280 Digital Camera
Battery charger says charged. camera will not turn on
Hi there i can 't get your these word." camera charger is blue, used battery and new,". Please let me know the battery is new or or its old? If its old then the battery life is finished. Thats why he can't store the power.
Feb 15, 2010 | Olympus Mju Tough 8000 Compact Digital...
M753 kodak camera does not come on.
go to the nearest electronic place that sells cameras they will tell you wats wrong
Nov 28, 2008 | Kodak Easyshare M753 Digital Camera
Cannon camera will not turn on
Dear Trish,
There are a couple of things that will usually cause this. A few are simple to check.:
1. Make sure that you battery is inserted properly and that your battery door is closed completely.
2. Make sure that your CF card is inserted properly and that your card slot cover door is completely closed.
3. Make sure that your battery is charged (charge it for 90 minutes) and that your charger works properly during the process. Your charger's light should go from red to solid green during a full charge. If possible test a fully charged battery on another camera. If you don't have access to another camera take your battery down to a local store that sells Rebels and ask to try it on one.
4. If these aren't the cause then you likely have an electrical issue with your camera and you should call Canon's tech support at 1-800-828-4040 to do a little troubleshooting and possibly send the unit in for service.
Hope this helps.
May 27, 2008 | Canon Rebel XT / EOS 350D Digital Camera
Canon PowerShot SD600 Digital Camera Logo
214 people viewed this question
Top Canon Cameras Experts
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
