Question about Lands Phones
Can not transfer music from PC to LG cu720. USB can charge the phone but now show on my computer as removable device.
Do you have a memory card? You can only transfer to the phone through a micro sd card. Get one and try it there pretty cheap now.
Posted on Apr 14, 2009
LG Optimus M+ add music
Hello William,
To transfer files using USB devices
  1. Connect the LG OPTIMUS M+ to your PC using a USB cable.
  2. If you haven't installed LG Android Platform Driver on your PC, you need to change the settings manually. From the Home screen, touch the Applications Key Settings > Connectivity > Default connection mode > Mass storage only.
  3. You can view the mass storage contents on your PC and transfer files.
Dec 06, 2013 | LG GT540 Cell Phone
I cannot download pictures from my LG Neon gt365 to my computer. What do I need to do? Do I need a USB? Do I need a micro SD? If so, what kind do I need? any help would be great!
You should be able to connect it using a usb cable that will need to be bought separately and a micro SD card installed in the phone. You should be able to buy any micro SD card up to 4GB. Also, if you buy a card with an SD adapter that will allow you to connect the SD card (with a memory card reader) to your computer without the additional usb cable. The manual link is attached: http://www.tmoatt.com/uploads/53/LG_Neon_GT365_UG_English.pdf
Per the manual:
Transferring Music from the Digital Music Service 1. Using your computer, open your preferred PC music management client. 2. Download the selected song to your library. 3. Make sure the microSD™ card is inserted properly into the handset. 4. Use the USB adapter cable to connect the handset to the PC. When you try to connect handset on your PC, the handset displays "Call and Message functions will not be available while connected to USB". 5. Once the USB connection has been established, the handset displays "To avoid data corruption always carry out safe removal hardware on PC after use." and the computer screen then shows the LG NEON device. If the detection does not occur, skip to Changing USB Connection Settings section on page 63. 6. Follow the instruction in the program to transfer music to your handset. n Note If you have a USB hub, connect the handset directly to your computer rather than through the hub. Transferring Music using Windows Media Player 1. Open Windows Media® Player on your computer (version 10.0 or higher). 2. Use the USB adapter cable to connect the handset to the PC. When you try to connect handset on your PC, the handset displays "Call and Message functions will not be available while connected to USB". 3. Once the USB connection has been established, the handset displays "To avoid data corruption always carry out safe removal hardware on PC after use." and the computer screen then shows the LG NEON device.
Jul 23, 2011 | Cell Phones
Transfer Music To And From Phone
the easiest way is to put the songs on a sd card in mp3 form then put the card in the phone and they should be there in my music. I hope this helps.
May 31, 2009 | LG enV2 EnV-2 VX-9100 VX9100 Premium Pink...
LG shine CU720 moving pictures rto memory card.
The LG Shine allows you to do a multiple picture DELETE - but not a multiple pic transfer to memory card, at least that I've found. You have to transfer your pics one at a time from phone memory to the SD card as follows:
Select Menu --> 8 My Stuff --> 4 Pictures
Highlight the pic you want to transfer using the center toggle button,
then select Options --> 5 Move (or 4 Copy) --> 2 Memory Card --> Paste
Once your pics are on the memory card then put the phone into USB mode by selecting
Menu --> 9 Settings --> 7 Connection --> 2 USB Connection Mode --> 2 Mass Storage
Then attach a suitable USB cable to the phone at the charging jack and open Explorer (Windows) or Finder(Mac) and navigate to the phone. Your pictures will appear and you can copy them to your computer as needed.
NOTE: be sure to return the phone from Mass Storage mode to Data Service or your phone will not work.
Also - set your phone to highest resolution for best quality pics.
Menu --> 8 My Stuff --> 7 Camera and Recordings --> 1 Take Photo --> Options --> 4 Resolution --> 1 1600x1200
Mar 22, 2009 | LG Shine CU720 Cellular Phone
How do I transfer computer images and music to my LG Voyager?
If you already have the drivers installed and it still doesn't show up as removable storage in My Computer, you may have to go to Settings & Tools -> Tools -> USB Mass Storage (on the phone, while it's connected)
Jan 23, 2009 | LG VOYAGER VX10000 Cellular Phone
I cant load music to my lg shine from my computer.. HELP!!!!!!
this might work you might have to try to plug it in to a different usb an see if the computer will pick it up
Jan 09, 2009 | LG Shine CU720 Cellular Phone
The LG Shine is a nice phone, but it is very disappointing with the USB cable.
You may expect the cable would connect the phone to your PC for Calendar Sync, music, videos etc.
Obviously, this will not work.
It will only allow you to hook your LG Shine to your PC to copy music and video files ONLY if you have a Micro SD card in the phone inserted.
After you have copied the files to the Micro SD card from your PC, you can copy them to the phone memory.
There are nice websites with free management programs for also the LG phone, but the Shine is unfortunately NOT listed (yet).
http://www.bitpim.org
Jan 01, 2009 | LG Shine KE970 Cellular Phone
LG Secret charging
Dr Know, doesn't know what he's talking about. I have a LG KF750 and have experienced the same problem.
Solution - Really jam the cable into the socket! The connection is pretty rubbish. The phone charging icon will (with some force and wiggling) appear on screen. Then carefully put it down and don't touch it!
USB charges very slowly, if charging from a dead flat battery it may take a good 20mins of charging to boot up.
P.S. the red camera light is not supposed to come on when charging. Keep wiggling the cable and the light will go off when the phone charging icon appears.
Dec 16, 2008 | LG Secret ? KF750 Cellular Phone
How to download music to Lg 260
There are several ways and options to do that:
A.With the use of Data cable
-Use Lg260 USB datacable or an Infrared USB datacable to transfer music files that are saved in your computer. Both of this should be connected to the USB port of the computer as well as to your phone.
B.Wireless transfer between phones and devices
-First option via Bluetooth and Infrared transfer to download music from your friends phone or devices which has Bluetooth and infrared features by sharing.
C.Wireless transfer/download from PC
-2nd is using your phones Bluetooth with a USB Bluetooth Dongle inserted in your computer's USB port and is wireless.
That's it, u can download music now in easy ways.
Enjoy!
Rate this solution according to the use obtained from it. It will be much appreciated.
Thank you!
For other questions, post here....good luck!
Sep 30, 2008 | Cell Phones
Music transfer
http://www.soft-go.com/view/LG-Phone-Manager_21689.html
try this software !
if not make shure you windows media 11 is up to date i use wmp 11 to transfer my music!
Jan 22, 2008 | LG Shine KE970 Cellular Phone
Lands Phones Logo
51 people viewed this question
Top Lands Phones Experts
Are you a Lands Phone Expert? Answer questions, earn points and help others
