Question about Pinnacle Steinberg Clean 4.0 (210100265) for PC
I have steinberg clean 4 & 5 but both versions only show CPF file choice .i want to save as wav.
  • chty jones Mar 20, 2011
    i did try this but still does not work and the program no longer recognises my burner ,strang e because i did burn 1 audio cd then it stopped working. thanks any way for your help .
    Genius:
  • 1,043 Answers
On the File menu you will find an option named "Export Audiotrack as WAV" as well as "Export Audiotrack as MP3". This will allow you to Save or Export the files you create as either the .wav format or the .mp3 format. Check your Help file, specifically page 86, if you need further information.
Posted on Mar 17, 2011
    tried that thanks any way for your help.strange but it did burn 1 audio cd before this problem started.
Can I instal clean 4.0 on win7-64
You can install it on win7-64 bit. But windows has its own cleaning tools. Plus the 3rd party cleaning programs have a high possibility of letting viruses into your computer.
Sep 02, 2014 | Pinnacle Steinberg Clean 4.0 (210100265)...
Steinberg CLEAN 4.01 win7
It's worth trying, as I run version 5 on Win7-64
Apr 16, 2014 | Pinnacle Steinberg Clean 4.0 (210100265)...
I need driver to install Pinnacle Steinberg Clean Plus 5 in Windows 7 Thank you for help Jiri
I installed the driver on the CD on Win 7 without problems. Try re-installing, but also check that you have selected the Pinnacle pre-amp in the program itself.
Nov 23, 2010 | Pinnacle Steinberg Clean Plus 4.0 Full...
I have a WAV project that is 1.99 GB & when opened in Magix Audio Studio 10 Deluxe results in no sound & shows no graphics as if there is nothing there. Bit Rate=1441kbps Audio Sample Size=16 Bit;...
Thw bit rate is way too high!...
The other wav files you g=have are probably around 128kbps.... that files has 1441kbps.
You also reached the 2GB file size limit...
The other files are probably less than 4MB.
See if you can change the bit rate to 256kbps or so...
Hope this helps!
Sep 12, 2009 | Magix Audio Cleaning Lab 2005 for PC
Tascam DP-02 cd player...
You cannot rip a CD directly into the DP-02 using the unit's CD drive.
Your choices for doing what you want are:
1.) Rip the CD into .wav files onto your PC using ripper of your choice. Then you'll have to edit the resulting .wav file using a program like 'Audacity' (which is a free one) and convert the stereo wav files into 2 mono wav files. You'll have to save the mono files with dos 8.3 filenames and then import them into the DP02 using the instructions for importing wav files in the manual. To preserve the stereo, import each mono wav file to a separate adjacent track on the DP02 and then pan one left and one right.
2.) You could play the CD on a stereo and connect the stereo outs to the two inputs on the DP02 to record the CD track. You'll need patch cords which are RCA (mini phono 1/8" jack) to regular phono (1/4") to do this.
Cheers,
bd.
Nov 09, 2008 | Tascam DP01 All-In-One Recording Package...
Plug in for downloaded ringtone
You can't actually do that.
If you have the original version Katana, the 6600, it's only plays polyphonic ringtones, in the qualcom format of QCB.
Freeringers.net has a good help section if you sign up with them, here's a cut and paste version.
You basically need a program to convert an mp3 to a wav file format. (like dbpower amp but there are many others, alot of them freeware).
Sound recorder on your computer applications, to pick a segment and crop the audio. Usually about 30 to 60 seconds is good enough. There's a file limit size on the Katana for downloads of about 100kb.
And a converter program that will convert wav to qcb. You can download an application from Qualcom Communications for free, or this little program called purevoice.
http://www.freeringers.net/apps/pvconv.exe
All you do is little drag the wav file over this application and it automatically compiles in about 3 seconds, a qcb file into the same folder.
http://www.qctconnect.com/products/purevoice_downloads.html
Provides the full version of purevoice convertor so you can listen to the quality of the qcb file.
You'll need an application to convert the MP3 or CD to a WAV file. We suggest this free tool:
dBpowerAmp Converter 10.1 (Download and install it)
You'll also need PureVoice for QCP conversion:
PureVoice Converter (No installation. Right click "Save Target As...")
If you're running Windows Vista you'll need the Windows XP version of Sound Recorder:
Sound Recorder (Right click link, "Save Target As...", save to "C:\Windows\System32\")
s_win.gif Conversion Steps:
Note: If you want to rip a song from a CD, replace step 1 with these instructions.
  1. We'll assume you're converting a file named "test.mp3" for this guide. Insert your own file name instead. Run dBpowerAmp and select the "test.mp3" file and click "Open".
  2. Change the drop downs to "Wave", "16 Bit (CD)", "8000 Hz", "1 'Mono'", Output To: "Folder", and "Browse" to select your "Desktop".
  3. Click "Convert >>" and once it's completed click "Finished" and you'll have a file named "test.wav" on your Desktop.
  4. Run Sound Recorder (included with Windows) and from the "File" menu "Open..." the "test.wav" file created in step 3. (if you can't find Sound Recorder, see Needed Applications above)
  5. Shorten the ringtone to 30 seconds or less. You can also crop it so it starts at the beginning of the choirs. To crop the audio clip, use the "Edit" menu to "Delete Before Current Position" or "Delete After Current Position". [?]
  6. Click the "File" menu and select "Save" which will overwrite the "test.wav" file.
  7. Grab and drag the icon for "test.wav" and drop it on top of the PureVoice icon "pvconv". It will convert and create a new file named "test.qcp", almost like magic.
Oct 04, 2008 | Sanyo Katana SCP-6600 Cellular Phone
Pinnacle Steinberg Clean 4.0 (210100265) for PC Logo
185 people viewed this question
Top Pinnacle Computers & Internet Experts
AL Schehr
AL Schehr
Level 1 Expert
 Ian Kayhan
Ian Kayhan
Pavel Pranovich
Pavel Pranovich
Are you a Pinnacle Computer and Internet Expert? Answer questions, earn points and help others
