Question about Sony CDX-GT21W Car CD/ MP3 Player
My CDX-GT21W is wigging out. I replaced my battery, and when the radio powered back on, it displayed every digit/symbol on the display. In this state, no button worked except 2. The DISP button scrolls through the all-on state described above, some repeating asian characters, some repeating shapes, and blank. The source button puts a more typical display and turns on the radio at max volume. The tuner doesn't work (seek+ goes to 96.1 and repeat presses do nothing), and pressing the volume knob scrolls through some of the proper settings, but those settings aren't adjustable: turning the volume knob in one of these setting modes just turns the volume to max again. Switching sources automatically turns the volume to max. The off button turns the unit off, then 2 seconds later, it tries to eject a disk and turns back on to the all-on display state again. I have tried disconnecting/reconnecting the battery several times again to no avail. At a total loss...
4 Suggested Answers
thesoundman
  • 41 Answers
SOURCE: sony cdx-gt21w
If you stop by any car stereo shop, you should be able to purchase a wiring harness that will plug into your car's plug. You can then wire it up to the wires coming from your sony by matching up the standard wire colors.
Posted on Sep 21, 2007
  • 2039 Answers
SOURCE: Please Help
check face plate maybe contact dirty if not well our in trouble sometime it not worth to repair it cheers
Posted on Jan 14, 2008
welcomejee
  • 10594 Answers
SOURCE: Sony CDX-S2200 CD Player Problem
Please press Reset switch in CDX-S2200. You can see it if you de-attache front panel.
If problem still exist, then you need to replace IC300 " 6-705-360-02 " IC TDA8588BJ/N2/R1
Posted on Oct 02, 2008
Unlocking gateway theft deterrent
go to the dealer
  1. Turn ON the ignition, with the engine OFF.
  2. Turn ON the radio.
Does the radio display LOC?
Is the security code known?
  2. Press and hold the radio preset buttons 2 and 3 for approximately 8 seconds until the first 3 digits of the backup code are displayed on the radio.
  3. Record the displayed code.
  4. Press and hold the AM/FM push button until the second 3 digits are displayed on the radio.
  5. Record the displayed code.
Could you successfully extract the code?
Contact Delco Electronics in order to give them the backup code information and to obtain an unlock code.
Did you complete the action?
Important:: If 8 unsuccessful tries are made to unlock the radio, the display will return to the LOC display, but when the SET button is pressed, INOP will be displayed. This means that the radio must be left powered up for 1 hour with the battery and the ignition applied before any more attempts to unlock the radio can be made. Anytime INOP is displayed, 3 more attempts will be allowed after the 1 hour waiting period with the battery and ignition applied.
  1. Ensure that the code to be used is correct.
  2. Turn ON the ignition, with the engine OFF.
  3. Press the MN button until 000 is displayed.
  4. Press and hold the HR button until the first 2 digits agree with the code.
  5. Press and hold the MN button until the last 2 digits agree with the code.
  6. Press the AM/FM button when the complete code is displayed. If REP appears on the display, repeat this step.
Did you successfully complete the action?
Replace the radio. Refer to Radio Replacement.
Did you complete the replacement?
Operate the system in order to verify the repair.
Did you complete the repair?
Apr 03, 2014 | 2001 Chevrolet S-10
I have a # symbol in place of volume strength
Here is a link to the user guide: http://www.giantintl.com/RadioPDFs/Outdated%20Manuals/T6400_User_Manual_E.pdf
You might try reprogramming back to a very basic function by turning off any special features such as VOX, VibraCall, Interference Eliminator Code, Qt filtering, etc. Then see if the radio works any better. Also replace your battery pack with a known good battery, or trade batteries with a working radio.
Best regards.
Nov 24, 2012 | Motorola Talkabout T6400 (22 Channels)...
I have two uniden GMR1088-2CK radios, If I press the transmit button on the side and speak into the Mike you can see tx appear in the display, the 2nd unit receives the call, rx appears in the display and...
What this code indicate mean that your radio have have been compress with power however the can also be an indication of lower power supply but most of the time is always power compress.
What you need to do to solve this code problem is to put off the radio for some time allow it relax, then remove the battery if possible after some time replace it if you are able to remove the battery then put on the radio and operate it.
Good luck.
Jan 15, 2011 | Radio Communications
I have power going to the unit yet there is no display,a sony cdx-gt220,i know i have power because it is loading and ejecting cds yet no display.please help,its doing my nut in!!!!
I have a Sony CDX GT 530U. I had a problem with no display and I thought no power period. I did not try to install a CD, so maybe I did have power to the CD motor but no display. This was frustrating because I could get the old factory Nissan radio to power up and work so I thought I had a dead Sony unit. After a lot of monkeying around, I discovered I had blown a fuse while installing the unit (you should disconnect the negative terminal of the battery when installing the radio... which I thought I skip, that was a no no.). I had checked the auto fuses, those cheap little plastic fuses behind a panel below the stearing column inside most cars, at least all the fuses I thought went to the car stereo. Turns out I missed one that was labeled "Batt" or something like that, which was the constant power wire to the car stereo. There was another fuse for the Accessory power to the car stereo (the main juice went the key is tuned to ACC or Start position). Turns out the Sony unit display runs off the constant power, or at least the unit on/off button runs off the constant power wire, so even though the ACC power wire was live, the Constant power wire had a blown fuse and the unit would not turn on. Check all your fuses inside the car, I bet that's your problem. Constant power on my Nissan Sentra was a 7.5A fuse, while the ACC power ran off a 15A fuse, but your vehicle may vary. Good luck.
Jul 16, 2009 | Sony Xplod Car Audio CDX-F7810 - CD/MP3...
Storing channels and time display
* Connect Yellow wire to continues power ( it is back-up power to memory circuit)
* Connect Red wire to switched power
You can download User Manual and Installation Guide for CDX-S2000 from Sony Support for more information.
Oct 23, 2008 | Sony CDX-S2000 CD Player
CDX changer has power but doesn't want to eject after flat battery
i resolved this myself in the end.
I unplugged the audio & power cables whilst the stereo and engine was running.
Then plugged back in.
I turned the engine off and stereo off as well.
I then unplugged audio and power again from the back of the CDX, left it unplugged for 10 minutes whilst the engine was still off.
I then plugged the leads back in and turned the engine on. the stereo recognised the CDX, but stayed on displaying "CD Checking". I switched to radio for 20 seconds, turned back to CDX and it selected CD 1 and has been good ever since.
I'm rather pleased with myself!
Steve
May 13, 2008 | Sony CDX-T69 6-Disc CD Changer
Sunshine Symbol on Display?
DST - There is a switch in the back.
Mar 12, 2008 | RCA RP5440 Clock Radio
Sony cdx-gt21w
Sep 13, 2007 | Sony Xplod Car Audio CDX-F7810 - CD/MP3...
Sony CDX-GT21W Car CD/ MP3 Player Logo
20 people viewed this question
Top Sony Car Audio & Video Experts
xxxxxx xxx
Larry Stiles
Larry Stiles
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
