Question about Belkin Basic Wireless Router
Cannot connect iplayer asking for password on iplayer wan number does not work
  • 4,281 Answers
Connect your router to computer with ethernet cable then you can access it with following default link. http://192.168.1.1 or http://192.168.0.1 or http://192.168.15.1 or http://192.168.2.1 If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. If you are still not able to access router with above ip then you need to RESET it for that press RESET button for 10 seconds it is in back side of router then all settings defaults..Then you can access it with above method. . Then click on wireless->wireless security->WEP security there is code password note down it or enter new password then save setting s and restart router. then you can connect wireless with new password. Let me know if you need further assistance. Thanks for using FixYa.
Posted on Mar 17, 2011
My installation cd for the basic router does work how do i fix this?
You can also configure router without disk.Follow below procedure.Connect your router to computer with ethernet cable then you can access it with following default link. http://192.168.1.1 or http://192.168.0.1 or http://192.168.15.1 or http://192.168.2.1 If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. Then configure wan settings and lan settings enable wireless if you want to use wifi Then save settings and restart router Then connect cable from internet service provider to WAN port of router and connect ethenet lan cable from computer to lan port of router. . Let me know if you need further assistance. Thanks for using FixYa.
Nov 12, 2010 | Belkin Basic Wireless Router
I am trying to install my netgear Universal Wifi Range Extender WN2000RPT. I have green lights for my connection to the router, the extender is on and it is connected to the main PC. But I only have...
For that you need to check WAN settings and also make sure local ip settings gateway should be your router ip address. Make sure WAN settings are fine connect internet cable to WAN port of router. Then check. You can configure router with below method. Connect your router to computer with ethernet cable then you can access it with following default link. http://192.168.1.1 or http://192.168.0.1 or http://192.168.15.1 or http://192.168.2.1 If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. Then configure wan settings and lan settings enable wireless if you want to use wifi Then save settings and restart router Then connect cable from internet service provider to WAN port of router and connect ethenet lan cable from computer to lan port of router. . Let me know if you need further assistance. Thanks for using FixYa.
Nov 10, 2010 | NetGear Computers & Internet
How to install the router
onfigure your router with below method then all messup will be fixed. Connect your router to computer with ethernet cable then you can access it with following default link. http://192.168.1.1 or http://192.168.0.1 or http://192.168.15.1 or http://192.168.2.1 If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. Then click on WAn settings and set wan settings as internet service provider settings. Then click on wireless settings then enable wifi also enter SSID name and enable broad cast turn on wifi . If you want to secure wifi then enable WEP in wireless security .Enter code it is your password to connect wifi. Then connect internet cable to WAN port then you can use internet with it. Let me know if you need further assistance. Thanks for using FixYa.
Aug 07, 2010 | Encore 802.11G WIRELESS LAN ROUTER...
Access my lan from the WAN
I assume you want to log into your pc from another pc outside your lan. To do this you need to forward port 3389 to your pc.
  1. Make sure your pc (the one you want to connect to) has a static ip address. Also, it should have a password on the windows account you use.
  2. In the router, forward port 3389 (tcp) to the ip address of the pc.
  3. If you do this correctly, you can go to any pc outside your lan, and use remote desktop connection to connect. When you start the remote desktop connection, put in the wan ip address of your lan. If you did the port forwarding correctly, you will be asked for a user name and password. Put in the username and password for your user account on the lan pc and voila! - you are logged into your lan pc remotely.
Let me know if this works, or if you need some more help.
Aug 08, 2009 | Zhone 6211-I3-200 Router
I can't get my inernet connection working for some reason. It keeps asking me for my acct. number and password that I use to connect to my ISP but I called comcast (who I have internet with) and asked them...
On the routers you can use different mode for connecting to your ISP. Try resseting your router or enter the administrative area of the router and set the WAN to DHCP.
Jul 06, 2009 | Computers & Internet
Dlink DIR-625 permanently stopped working. Connected directly to internet with dsl cable through sympatico and internet works fine but doesn't work at all when connected through Dlink DIR-625
you may need to reset the router and reconfigure the settings. please follow the steps below if you have a username and pw from sympatico.
1. Press the reset button for 30 seconds
2. Plug the modem to the internet port of the router. Check the internight light if lit; otherwise, use another known working cable.
3. Plug the PCs to the numbered port at the back of the router. Check the lights on the port number if lit; otherwise, use another known working cable.
4. Open a web browser and enter http://192.168.0.1 and press Enter. When the login window appears, set the user name to Admin and leave the password box empty. Click Log In to continue.
5. Click on manual configuration when prompted.
6. Select PPPoE on My Internet Connection and enter the username and password provided by Sympatico. Select Dynamic IP and Always ON options. Click Save Settings.
7. Click on Status tab and verify WAN status if connected. You should see WAN IP address when connected.
8. Try to open a browser and verify your connection.
Hope this helps!
Jun 25, 2009 | D-Link DIR-625 (790069292637) Wireless...
Can not connect to the internet in trying to setup the router.
Yes time warner is a cable connection and they dont require a username and pasword. You can set up the router manually by accessing its set up page. By default the router's IP is 192.168.2.1. Make sure to set the wan connection type to dynamic, change the wan mac address or clone your pc's mac. Then save the settings. Check your internet connection.
Aug 18, 2008 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Username /password to change
to change username and password in dlink router you have to access http://192.168.0.1 in the address bar of internet explorer
it will bring you to the configuration screen of dlink.. it will ask for the dlink usid and password, the default userid is "admin" , for the password leave it blank.
  1. The router's Web-based Setup Utility should appear. Do not run the wizard. Select the WAN button on the left-hand side of the screen.
  2. Select the PPPoE and Dynamic PPPoE options on the WAN settings screen.
Enter the your USERNAME and PASSWORD that your broadband connection provider gave you into the corresponding fields and select Apply and then Continue.
Once the screen refreshes, exit the browser.
now try to connect
Jul 18, 2008 | Computers & Internet
Remote access to lacie ethernet hard drive
you will need to open a port on the router first. Maybe 8080 once you get that set you will type the WAN ip and the port number. It will look like this: http://165.123.123.0 : 8080
it will then ask for a username and password.
Nov 05, 2007 | Computers & Internet
Belkin Basic Wireless Router Logo
41 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
