Question about GE Profile PSW26P Stainless Steel Side by Side Refrigerator
Freezer warm Everything melting....refrigerator seems fine
  • GE Master
  • 43,501 Answers
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Posted on Mar 18, 2011
My freezer is freezing food fine but my refrigerator seems to be warm and not cooling like it should. The temp control has been adjusted to a higher setting but does not seem to help.
if your freezer is working your fridge is fine
Your problem probably started a couple weeks ago when the drain that allows defrosted ice (water) to drain into the drain pan at the base of your fridge became plugged for some reason. Then everytime the fridge went on defrost more water melted but did not drain which in turn froze. Now ice has built up and caused the air that flows into the fridge to be blocked, causing a warm fridge.... my advice is to leave fridge unplugged for 48 hrs to thaw it and find the cause of the water not to drain... could be a corn niblet or pea from the freezer... the tube should be visible from the inside or the back
Jul 21, 2011 | Amana ABB1927DE Bottom Freezer...
I opened freezer on my Kenmore elite model #596 73503203 and everything was melting, ice had started to turn to water. The refrigerator is only 7 years old, is it worth fixing? The freezer does not seem...
It could need refrigerant...I'd try to possibly get a quote on that.
BUT FIRST,
I'd ensure the coils were cleaned of all dust and dirt...either by vacuum or blow it with compressed air.
I'd also check to make sure the light goes out when the door is closed. Sounds crazy but I had a bad switch once that allowed the bulb to stay on constantly...makes everything warm.
Jul 17, 2011 | Kenmore 73503 Stainless Steel Bottom...
Freezer not working
the symptoms you describe, freezer temperature rising while the fresh food section "seemed" ok, my guess is by the time you read my response, the fresh food side will be just as warm as the freezer. when the cooling pattern is similar to this, it has to do with the compressor no longer running. the compressor itself may be ok, instead the starter has failed, but i would not recommend you even attempt this yourself, as you can cause permanent damage to your compressor, property damage to your home, or electrocution hazards to your self. I would highly recommend you have a reliable refrigerator repair service at least inspect it for you.
Apr 02, 2010 | Amana ARS2464B Side by Side Refrigerator
Refrigerator not cooling-Freezer Coils Freeze Up & Don't Defrost
check the fan assembly theres not enough air flow going over the coils
Feb 11, 2010 | Maytag MBB2254G Bottom Freezer...
My refrigerator is not cooling the freezer works
We have this refrigerator and what you described is a chronic problem. (I hate this refrigerator!) Our repairman got tired of hearing from us so often and told us how to fix it ourselves! Take everything out of the freezer side and unplug it. Remove the white back part inside the freezer part. There are 2 screws at the top. The inside will be full of ice. Melt the ice with warm water. It makes a huge mess so get lots of towels. Once all the ice is melted you can put everything back and plug it in. It may take a day for it to get really cool again. My long term advice is to get a new refrigerator...
Jan 05, 2010 | GE Refrigerators
Side by side Amana freezer/refrigerator thawing.
The doors not being shut can make it freeze up,Just thaw again and make sure the doors get shut each time and see what happens,just post back details if it doesn't work after thawing
Aug 05, 2009 | Amana ASD2625KE Side by Side Refrigerator
Kenmore Elite 596755 - Freezer warm, Ice Melted, then...
did you move it or tip it on its side when these devices are moved sometimes it will create anair pocket in the cooling system after moveing let stand for a few hours before plugging back in.
Jan 15, 2009 | Kenmore 73502 / 73504 / 73509 Bottom...
GE side by side not working
Defrost cycle not functioning. Could be defrost timer, timer motor, or defrost heater. I detailed this for someone else. see other solutions.
Nov 05, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
HSS25IFMDWW- freezer frosting up but working
sounds like the defrost thermostat or you may have a crack in the water line causing the freezing.
Jun 10, 2008 | Hotpoint HSS25IFMCC / HSS25IFMWW Side by...
Amana bottom freezer working fine but refrigerator not/ warm since 24hrs.
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
Apr 28, 2008 | Amana ARB2517CC / ARB2517CB / ARB2517CW...
GE Profile PSW26P Stainless Steel Side by Side Refrigerator Logo
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
