Question about NEC MultiSync LCD1860NX black (Black) 18.1" LCD Monitor
I have the NEC MultiSync LCD 1860NX , and the screen is only showing in a blue low res mode - what is going on? A "Video Input" message comes up when I first plug in the monitor which says - DVI Digital "No signal" any help would be greatly appreciated
  • johnbauld Mar 17, 2011
    Thank You!!!
  • 314 Answers
Hi johnbauld ,
have you tried turning off your LCD for a couple of minutes?
Posted on Mar 17, 2011
  • Tada Phiriyanuphong Mar 17, 2011
    Make sure your LCD is firmly plugged into the computer or the device aswell.
    one more thing. on your computer,
    while you are on the desktop right click and then press properties then click Detect, this should enable the computer to detect the LCD.
Why does a monitoring keep going off?
you forgot to say, screen dark? and power light off.
does the OSD work? Push button that pops up the OSD screen for bightness, does that work>
\can be one of 4 things. 100 % dead.
try it on another PC>
bad power cord
bad video cable.
bad LCD
bad PC, bad Video card in PC or some game using an illegal video card mode.
try another PC and see if the LCD works there.
easy huh?
Sep 30, 2013 | NEC MultiSync 1550V 15" LCD Monitor
When on "computer" mode I
disconnect the cable at the projector end and plug into a monitor to check that the video signal is enabled on the cable. If it is then reconnect to the projector and select a lower resolution on the pc screen setting. See if anything appears on the projector
Aug 24, 2011 | NEC MultiSync VT590 LCD Projector
NEC Multisync LCD1765: Screen flashes and then mintor turns off with message "No Signal"
Restart your computer.
As soon as it starts the start-up process, keep tapping the F8 key, repeatedly.
When you see the Windows "start-up" menu, select "start in safe mode".
Does your monitor work in this low-resolution (640-by-480 or 800-by-600) mode?
If so, then you had configured Windows to a too-high resolution that the NEC did not support.
Choose 1024-by-768, and click "Apply", to test that the NEC supports this mode.
Try connecting the NEC to some other computer, to see if the NEC itself is the problem.
Mar 28, 2011 | NEC MultiSync LCD1765 17" Flat Panel LCD...
Nec Multisync LCD 195VXM+ black screen after turning on computer
I'm thinking your video card is sending a signal the monitor doesn't recognize.
You'll need to start the computer and hit F8 until you get the black and white menu. Choose the VGA mode and it should work well enough for you to adjust the refresh rate or the resolution to get the monitor to work
Aug 28, 2009 | Computers & Internet
NEC 1860nx. When owering up monitor, screen lights up, then 2 seconds later goes dark. Can I repair this?
The inverter board was made using lead free solder.... thank the Europeans for that. The larger components develop cracks on their solder joints after a few months of on time. Remove the inverter board. Use 15x magnification or better in bright light and you'll see the cracks on the ends of the large resistors. Apply fresh solder and you'll be good to go. You might run into resistors where you solder one end and they lift up... that means joints on both sides went bad. Son't kow how many more fixya's I'll answer w/o free access to the other responders?
Mar 15, 2009 | NEC MultiSync LCD1860NX 18.1" LCD Monitor
Monitor not working
These messages appear during if the video cable becomes disconnected or
damaged.(most likely you will need to replace it)
Turn off your monitor and reconnect the video cable; then turn on both your computer and the
monitor.
If your monitor screen remains blank after using the previous procedure, check your video
controller and computer system; your monitor is functioning properly
Nov 14, 2007 | NEC MultiSync LCD1830 18.1" LCD Monitor
NEC MultiSync LCD1860NX black (Black) 18.1" LCD Monitor Logo
104 people viewed this question
Top NEC Computers & Internet Experts
parusdi rusdi
Level 1 Expert
Alun Cox
Are you a NEC Computer and Internet Expert? Answer questions, earn points and help others
