Question about Lexmark Office Equipment & Supplies
Printer keeps telling me it is out of paper when paper is in place - connection from printer to computer is fine but stops short of printing out.Problem occurred after paper jam and have removed and uploaded CD Rom twice but no change.
    Genius:
  • 1,126 Answers
Try unpluging unit from the wall and that will reset it back to normal.
Posted on Mar 17, 2011
How do I get my HP OfficeJet Pro 8725 printer to spit out the printed paper without force and an extra sheet?
Have the memory inside the printer tested. Add as much printer memory as you can to the printer to speed it up.
Mar 16, 2017 | HP OfficeJet Office Equipment & Supplies
Printer keeps printing blank pages non stop going
drop kick unit across room:)))) sorry just kidding I had the same problem with mine. If the computer is continually printing that means the printer is receiving print orders from your computer. Best thing is just disconnect the printer from the computer and turn the computer off and wait 30 seconds then turn on . This should clear the print cache then reconnect the printer. Make sure to only request one print at at a time.
if the printer continues to print blank pages check to see if you have the latest software driver for the printer installed on your computer. You can do this by going to the manufactures website and download the software its easy to do just follow the prompts and install! Hope this helpful!!!
Jul 24, 2010 | Epson Stylus C84 InkJet Printer
HP Deskjet 3500 series, my printer keeps telling me that is is off when the light is green, keeps stating it is offline. When I installed the printer everything was fine, now when i print the printer...
Hi
HP Deskjet 3500 serie --
There could be a Software issue or hardware issue --
1) To check the software issue
Print a Test Page -- from the computer
2) To check the hardware
Press the Power button to turn the product on.
Press and hold the Power button
Open and close the front cover four times.
Release the Power button. The self-test will print
and it it is printing the hardware is fine ...
3) Then you can check by changing the USB Cable connection
Jan 01, 2010 | HP DeskJet 3520 InkJet Printer
Error message reads "34 short paper". What does this code mean and what can I do to correct it? Thanks
This error means that the type of paper that is configured in the printer is different from the one you have chosen in your computer to send for printing. Make sure that the paper size is the same in both places the computer program you are using and the printer. For example if I have a Letter size word document that I want to print but the printer has A4 configured then I will get the 34 short paper error but If I change the paper in the printer and the setting to letter size then everything should print fine.
Nov 13, 2009 | Lexmark C510 Laser Printer
Y printer is fine while with test paper. there is no cable connection problem. there is problem in window with printing only. same printer work fine with another computer system
printing operation in a computer system is disturbed easily by a virus...have your computer scanned and cleaned. spywares are likely too.
May 12, 2009 | Office Equipment & Supplies
Paper keeps feeding through and won't stop
Two possibilities;
One you have a messed up print job trying to print and when you turn the printer on the job just starts over.
Two the clutch that stops the pick roller is bad and the roller just keeps turning.
Unplug the machine from the computer and turn it off unplug power for awhile turn it back on not connected to the computer. If condition remains it is the clutch.
If condition goes away delete print jobs and re connect printer.
Hope this helps
Mar 26, 2009 | HP LaserJet 1300 Printer
I have this printer that is networked in a small office with 4 other computers. The person who installed this printer has left the left with all its documentations and the user guide. Someone has printed...
restart the Windows printing services, if they run Win2000 or newer. Go to Start > Run, type CMD, hit Enter, in the command dialog that opens, type NET STOP SPOOLER and hit Enter and it should tell you the service has stopped.
then type NET START SPOOLER and hit Enter and the service should start again.
Do this on all computers until printing stops. If printing doesn't stop, power off the printer and its server (unless it's connected to one of those pcs in which case you already restarted that service).
Jan 12, 2009 | Xerox DocuPrint N2125 Laser Printer
Printing problem with HP 2015 Laserjet Printer
If you have an adjustable paper tray, make sure that the tray is set for the right size paper. Also, you may have some type of sensor in or around the printer tray that tells the computer when the paper tray is empty. Sometimes these sensors get stuck and you have to free them up (very gentley).
Hope that helps - Ghost
Oct 27, 2008 | HP LaserJet P2015dn Printer
HP psc 2350
You need to reintialise the printer again from the scratch. turn off your printer and disconnect from the computer. Uninstall all the drivers and application of the printer. reinstall the driver by following the instaruction. Connect the printer cabel to the computer when it prompts you to do that and then align the printer cartridge. The paper fedd will work fine
Oct 07, 2008 | HP PSC 1210 All-In-One InkJet Printer
Brother MFC6800 not printing
To answer more effectively - how is the printer connected to the iMac? Is it a USB connection, a printer cable, is the MFC 6800 connected to a print server, an AirPor, etc? A second question I have is if you are trying any kind of tricky printing such as manualduplex printing.
Also, a shot in the dark...Is the Auto Reduction set to on or off? To check:
1. Press MENU/SET, 2 (Fax), 1 (Setup Receive), then 4 (Auto Reduction).
2. Press the up or down navigation key (keys located above and below the
MENU/SET key) until the display shows "Reduction: ON?".
3. Press MENU/SET.
4. Press STOP/EXIT.
Another item to keep in mind:
You can use three sizes of paper for printing your faxes and
copies---letter, legal and A4. When you change the size of paper you ha
ve loaded in the Brother machine, you need to change the setting for the paper size so your Brother machine can fit the incoming
fax on the page. To set the Paper Size:
1. Press MENU/SET, 1 (General Setup), then 1 (Paper Size).
2. Press the up or down navigation key to select LETTER, LEGAL, or A4.
3. Press MENU/SET.
4. Press STOP/EXIT.
Nov 20, 2007 | Brother MFC 6800 All-In-One Laser Printer
22 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
