Question about Admiral AAV7000A
How to open top of machine - Admiral AAV7000A
    Master:
  • 713 Answers
With a hammer and a flat head.
Posted on Mar 17, 2011
On my CLP770, the duplex component located at the top of the machine when you open the top door is totally trashed. I cannot get one anywhre can someone help? Thanks in advance WAZ
If you are looking to replace the paper transfer unit (this is the unit that hinges down with the front cover when you open the front of the machine) then you should shop for CLT-T609. If you need to replace the fuser unit (at the top of the machine when you open the top cover) then you should shop for JC96-05455A (220V) or JC96-05454A (110V). Both are available on the open market.
Jun 07, 2011 | Samsung CLP-770ND Laser Printer
The door is not opening
1. the door will not open if in the sanitary cycle.
2. the door will not open if the water level is too high. (open access door at lower left on front of machine and use the hose there to drain water out of washer.
3. the door will not unlock without power to machine except for the following:
4. unplug machine, remove top cover by removing bottom screws from plastic clips on back of washer top, then standing in front of machine, using the palms of your hands to sharply push back the sides of the washer's top about 2 inches, allowing top to be lifted off machine. reach down to door latch and manually move latching arm on door latch to allow door to open.
Mar 06, 2011 | LG Washing Machines
Smart drive9 the machine will not fill and it beeps
Power off the mains,close your wall faucet, unscrew the hoses at the top where the water comes to machine (need not open machine). Check to see if anything is blocking the mesh you see, clean out with old toothbrush, toothpick. Check you faucet, water pressure should be good, use bucket. Refit carefully without cross threading, check for leaks. If it still does not work, open top of machine to check wiring harness at inlet valve. No work? change inlet valve, you can do it yourself.
To open top, remove 2 or 3 screws behind top of machine, the top shd slide away an inch or so backwards, then lift off.
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Try these sites for spares:
RepairClinic.com
espares.co.uk
AppliancePartsPros.com
mcminone.com
How abt rating me 'very helpful' for the free help, thnks
Jun 13, 2010 | Fisher and Paykel Washing Machines
If we open the lid of the top load machine at the spin time?there will any problem for the machine
All top load machines have a braking system to stop them spinning when the lid is opened.. Most have a mechanical system which, although sometimes noisy, does not damage the machine.....However, direct drive machines like fisher & paykel may have an electronic system which converts the motor to a generator, which slows the spin....The generated power in this type of machine can cause damage and the lid should never be lifted while the machine is spinning.....Check with your brand's service agent... Good luck....Nomess
May 17, 2010 | Washing Machines
How do I open the machine to clean the metal bin
To open machine take two flat head screwdriver and gently insert them in top of front panel about 3 to 4 inches from side and push in to get clips to compress and lift top panel of machine. This will give you access from top side. If you need more room there are two screws, one on each side of front panel, remove and pull panel forward and up. Reinstall in like manner.
Jul 09, 2009 | Maytag Atlantis MAV6000 Top Load Washer
The lid on my top loading admiral mega 22 plus washing machion is
These are plastic and will need to be replaced with new.
Once you have sourced new hinges then the machine top needs to be opened,
Electrically Isolate the machine, then at the joint between the machine front panel and top insert a flat blade 4" from each side to release the lid catches, tilt back the top to access the screws on the hinges and replace with new.
Mar 03, 2009 | Admiral AW22 Top Load Washer
How do you open the top of a front load washer?
most have a few screws at the back of the machine holding the top in place.....once you have taken the screws out, slide the top forward....please make sure you unplug the machine prior to opening it up
Dec 30, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Calypso 22066 top=load washer
You probably have hoses and sump pump plugged/jammed by not enough to the machine from operating, my machine leaked prior to cleaning out all the hoses and sump pump
Aug 29, 2008 | Kenmore 22062 Top Load Washer
Admiral AAV7000A Logo
18 people viewed this question
Top Admiral Washing Machines Experts
Dan Webster
Dan Webster
Sal De
Are you an Admiral Washing Machine Expert? Answer questions, earn points and help others
