Question about Dell Inspiron 1521 Laptop
New Hard Drive purchased Reloaded OS (XP Home
New Hard Drive purchased Reloaded OS (XP Home Premium) - updated all drivers including chipset and BIOS - ran diagnostics - All passed - 4 USB ports do not work will not recognize Flash drives (1 or 2) - will not recognize external mouse
  • 902 Answers
Go to your device manager under xp its right lcick my computer-properties-devicemanger. check on the bottom your usb settings if there is a red or yellow marking you may need to re-install your chipset drivers. or download generic usb generic drivers. let me know if this helps
Posted on Mar 17, 2011
Blue screen when usb plugged in to new board old xp home
1.) Ensure XP is updated with latest device drivers
2.) Ensure latest chipset & motherboard drivers are installed
3.) Check USB drive, and USB port
4.) Boot up with any Linux OS Boot up disk and check if USB is working
5.) Install Windows 7 in case new drivers not available on XP
Feb 26, 2013 | Computers & Internet
Operating system not found
No, you won't get the OS to automatically install on the new drive. The OS is not stored in the BIOS chip (or a similar permanent location inside the computer). You will need an OS install disc (not an upgrade disc). Windows Vista Home Premium or Basic was the original OS on most of the Acer Aspire 4530 series. Acer appears to have drivers for the system for XP through Windows 7 to get the hardware to work. You will need to have these most of these ready before you install your OS. Put them on a flash drive or optical disc using another computer.
This computer may work with Unix as well. However, driver issues may be a factor. You can try most versions of Unix from a CD (LiveCD) to test it out.
When you get a new hard drive, install it into the laptop. Then put the OS disk in the optical drive bay. Boot to the optical drive. Follow the directions for formatting the hard drive and installing the OS. (Of course you will need a drive that doesn't have a higher capacity than the BIOS supports.) The motherboard needs to recognize the drive.
If you find a member of a Windows User Group, they may have Windows install discs available. The license number on the label of your computer will probably work as your license key. (The key for a computer like this is locked to the CPU and motherboard; unless someone upgraded the OS to Windows 7 or downgraded to XP, this should be the key you need.) Use the information on the label to obtain the correct version of Vista (the Basic install disc may not work for installing Home Premium). You also need to match the 32-bit or 64-bit install disc (and the service pack you need).
I hope this helps.
(An Acer recovery disc wouldn't help you. Most of those are completely locked to the original hardware (including hard drive) and look for the recovery partition that was on that hard drive.)
Dec 05, 2012 | Computers & Internet
Recently I upgrade my 400sd4 to 512 memory, anew hard drive 160gb and loaded in vista home premium. Now my wireless adapetr linksys wireless-b causes the computer to freeze and not load. I tried loading...
I suspect your problem is with the drivers for that WiFi-B card. You didn't say what the make & model is of that card, but most manufacturers have not updated their older products for Vista (older WiFi-B & not-so-old WiFi-G cards included). If you're trying to force some older Windows 2000 or XP drivers to work in Vista, you're bound to have issues. You may need to replace that card with a new WiFi device that has drivers for Vista. If that device is USB 2.0, you'll need a USB 2.0 PCMCIA card because the built-in USB ports are only 1.1. You should be aware that this laptop supports only 1 PCMCIA card.
There are other problems with your setup, as the hardware of this system just is not up to running Windows Vista well. First, the graphics hardware does not support the shading instructions and DirectX 9.0+ needed for the "Aero" interface included with the Home Premium version of Vista. Second, Vista might run with only 512MB of RAM (the max this laptop will support), but not well; it really "likes" around 2GB of RAM or more. Third, the BIOS of this system (even the latest and last update) does not support 48-bit LBA (logical block addressing), so it can only "see" hard drives up to 137GB. Any hard drive capacity above that will not be seen by the system, and may result in some drive corruption. At best, you will not have use of the full capacity of that 160GB drive.
Lastly, even if you can get all of the Vista drivers needed for this system's chipset and such to work properly, you will probably not be pleased with this system's inability to run the "Aero" interface, or with the performance limitations when running under Vista. My suggestion would be to remove Vista and install Windows XP. That is what this system was designed for, and all the appropriate drivers are readily available -- possibly including the correct one for your Wireless-B card.
Jan 30, 2011 | Gateway 400SD4 Notebook
Had to format hard drive. Have reloaded XP, which was my initial OS. Now computer won't recognize the printer even with new downloaded drivers. What do I do?
Please make sure that you have all the Microsoft updates and service packs installed on the computer after OS installation.
Apr 29, 2010 | Brother MFC 420CN All-In-One InkJet...
Aspire 5315 down and out new hard drive, bunch of problems
and home or pro xp will work you should have thexp cd key code on the bottom of the notebook - go to acer .com to download the drivers ..... i can make you a cd for 20 bucks if so email me @ jepito@gmail.com and ship it to you in 3 days the sticker on your pc will tell you what it was xp home xp pro or vista :()
Sep 09, 2009 | Acer Aspire 5315 Notebook
I want to remove my Vista Home Premium (64 bit) os and replace with XP Pro
All you need to do is insert your Windows XP disk at start up and boot the disk by pressing any key when prompt to. Then run a clean install since a upgrade will not be available. You may want to backup your programs e.t.c.
Regards
Jan 05, 2009 | AMD Satellite L355D-S7829 Laptop
Maxtor 3100 will not work on Desktop with Windows XP Home version
actually telephone numbers are not available through this service...perhaps you will consider a premium or chat investment of your resources.
Oct 20, 2008 | Maxtor Personal Storage 3100 (M01E100) 100...
Vista Home Premium fails to work correctly with 3rd party audio-ware, even though ALL audio product Vista drivers updated, and Vista OS software updated. Apparently the Vista audio problem is a common...
you will have a very hard time finding drivers for xp. dell will not support and dell does not have drivers for xp for your system. try vista sp1. i have no problems with my 1530
Aug 11, 2008 | Alesis Multimix 8 USB 8-Channel Mixer...
None of my external hard drives or flash drives recognized by Vista
Ok Go into your hardware device manager and uninstall your Universal Serial Bus Controllers and if there is mass storage device also uninstall it. Click on action -> scan for hardware changes, then it should automatically install the drivers back now it should detect.
May 03, 2008 | Maxtor Hard Drive
Dell Inspiron 1521 Laptop Logo
90 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
