Question about Gestetner C7435n Laser Printer
Duplex printing second page upside down - Gestetner C7435n Laser Printer
Duplex printing in HP 2420dn on Mac OS X Lion 10.7.4
According to the specs, this printer does not have a duplex unit and therefore cannot print double sided prints.
DOUBLE SIDED PRINTING USING A SINGLE SIDED PRINTER
If your printer does not have a duplex unit then the printercannot print double sided pages automatically.
You can print double sided pages but you have to do it one page at a time.
First print Page 1 then place the page back into the paper tray, but turn thepage upside down and the print Page 2.
Then print page 3 on one side then page 4 on the other side and repeat for therest of the document.
I suggest you try a test page first, to get the printing the right way up onboth sides of the page so it reads correctly.
Jul 17, 2012 | HP LaserJet 2420 Printer
I have a printer thats printing on one side only. how can i fix this
Do you mean double sided printing? If so this model printer does not have a duplex unit and cannot print double sided prints automatically.
DOUBLY SIDED PRINTING WITHOUT A DUPLEX UNIT
Open your Word document.
Open page 1 - then Print the current page.
Then put the printed page 1 back in the paper tray upside down.Open page 2 and Print the current page (page 2 will beprinted on the other side of the page 1).
Repeat this procedure for the other pages.
Jun 15, 2012 | Brother Office Equipment & Supplies
How do i find info on duplex printing on a canon pixma 4500
This model Canon printer does not have a duplex unit and cannot print double sided printing automatically.
Then put the printed page 1 back in the paper tray upside down.Open page 2 and Print the current page (page 2 will be printedon the other side of the page 1).
May 03, 2012 | Xerox Phaser 4500/B / Phaser 4500/YB Laser...
How do I use my printer as a duplex for making copies on both sides? Thanks Roxanne
The printer does not support duplex coping. If you want to do manual duplex copying, you can make a copy of the first page.
Then reinsert the paper upside down in the manual tray or paper tray, fil the page on the document feeder and make the back copy.
Aug 27, 2010 | Samsung CLX-3170FN All-In-One Laser...
Duplex Printer prints one side upside down
If it's the same as the Brother 4070 you go into printer proerties (press properties next to printer selector after sending a document to print).  Choose the advanced tab, on this tab near the top are five buttons with icons on, the second one shows two pages with A and B on, press this to access the duplex and binding options.  In there change from "flip on top edge" to "flip on left edge"
Jan 17, 2009 | Brother HL 5250DN Laser Printer
When printing duplex document 1st page is upside down
make sure the driver is set to book bind duplex, rather than tablet style which is what it is doing now. Good Luck!
Dec 29, 2008 | Lexmark X9350 All-In-One InkJet Printer
MP610 How do I duplex print. I have had every second page print upside down. o I manually turn the page over/
I had the same problem, the operative being had!
All I did was change the paper orientation from landscape to portrait and the problem went away!
Hope this helps!
Robbie
Jul 17, 2008 | Canon MP610 Photo All-In-One Printer
Sharp arm355N/fx/srg
If your printer does not have the duplex module installed, then you are manually trying to print duplex, correct? If so, rotate the first printed batch before reinserting into the printer. On the second pass, the printer will print with the proper orientation.
If you are having problems with the duplex module, section 3-4 of the operations manual has some good troubleshooting tips. Section 3-2 describes printing with the duplex module.
You can read the operations manual here:
http://www.google.com/url?sa=t&ct=res&cd=9&url=http%3A%2F%2Fwww.wisconsinimaging.com%2Fdownloads%2Farm355n_arm455nmanualcopier.pdf&ei=I_OZR_PhIY3YpgSezaT_Bw&usg=AFQjCNG-V-wFgvShiy2YTsn-dgEwrZqmag&sig2=Utq7qqf1Pw6MT9P8YOQfmg
Jan 18, 2008 | Office Equipment & Supplies
Duplex printing
I think you given the wrong printing on one side. So Check the page orientation and do the printing
Sep 29, 2007 | Canon PIXMA iP5000 InkJet Photo Printer
Duplex printing: 2nd page is upside down.
START PRINTERS & FAXES PRINTING PREFERANCES choose both the options - print on both sides - flip the page option apply ok close the printing preferances box try printing
Aug 18, 2007 | HP Photosmart 3310 Printer
Gestetner C7435n Laser Printer Logo
59 people viewed this question
Top Gestetner Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
Norman  J Weimar Jr
Norman J Weimar Jr
Are you a Gestetner Office Equipment and Supply Expert? Answer questions, earn points and help others
