I cant view the whole screen, the top and bottom are cut off?
  • 902 Answers
Thats normal if you have a wide screen tv. either your tv or your cable box must set your picture to zoom or stretch to get rid of the bars. via cable box its in settings then aspect ratio or display settings and same goes for the tv. let me know if this helped.
Posted on Mar 17, 2011
Projection is too close cuts the screen what do i do
have you tried zoom setting in the menu? wide, full , or zoom?
Feb 16, 2012 | GE D52GW12 52" Rear Projection HDTV-Ready...
The screen does not show the whole picture and it is cutting the top or the bottom of the picture
If the button on the television remote that is meant to adjust the picture size i.e. wide or format/view mode button is not working then you need to adjust your cable box. There is a hd zoom# button on the cable remote towards the bottom that will fix this or sometimes the button will say format or aspect. You may have to go into the cable box's settings and choose crop 1080i or some other picture format setting that will keep the heads from being chopped off. You may have your cable box on the wrong resolution for your television. Your cable box may be connected to the television in two places, and your television might be on the wrong source/input for hd viewing.
Sep 20, 2011 | Televison & Video
How come the top and sometimes the bottom of my screen are cut off
Not all bradcast are in 16:9 resolution (wide screen). Most are still in 4:3 (old TV).
Sometime the advertisements are in 16:9 letterbox to project correctly on 4:3 TV and TV logo or titles are on the bottom or top of the picture. If TV is set to project wide screen, these logos or writings will be cut off.
If you have an option to switch TV resolution from remount, you will see whole picture.
Check your TV manual for settings.
Dec 20, 2010 | Panasonic TH-42PX20U/P 42 in. HDTV Plasma...
My top ds screen is white and i have an R4. the bottom screen is fine though. help!
the problem may be that the screen cord may have been cut from the bottom screen so that is why you cant see the top screen so go get it checked by gamestop or other video game stores
Sep 30, 2010 | Nintendo DS Lite Console
I cant see the bottom or top of my show
Push the View Mode button on ur rmote.Pick the mode u can see the whole screen.
Feb 15, 2010 | Toshiba REGZA 47HL167 TV
Microsoft outlook 2003 - no reading/viewing pane, whole right column (from, date,subj, size, file attach, tag, etc) is gone, so can't view the emails. only left column's Mail (favorite folder, all mail...
Click on the View menu, then
Reading Pane
and then choose from:
Right
Bottom
Off
Oh No! you are not able to view the entire right column (from, date,subj, size, file attach, tag, etc. Hmm!
Current View, then
Customize Current View..., and then click
Reset Current View
Hopefully now you will be able to view the whole right column.
Jun 07, 2009 | Microsoft Outlook 2003 for PC
Cuts off picture at top of screen and bottom of screen
good luck tryin to find a universal remote i cant...but if you do there should be a button that might say something like pip, pix, screen mode something like that and it will make the picture streach to fit the screen however not all channles will be set on the same screen settings.
Dec 27, 2008 | Emerson EWL3706 37 in. LCD Television
Picture jumps
you might have bad caps or the vertical output integrated circuit, try to locate the vertical ic and check the surrounding areas for bad capacitors.
good luck
caypianan@yahoo.com
Oct 23, 2008 | Hitachi 53SWX10B 53" Rear Projection...
Picture is cut off at top and bottom
I had the same problem with my westinghouse 47 inch HDTV. It turned out that someone had inadvertently hit the "format" key on my satellite (Direct TV) TV remote controller. If you have satellite TV you might want to check this out. I set it back to the previous setting and I get the entire screen. Hope this helps someone.
Oct 20, 2008 | Vizio L32 32 in. LCD HDTV
Depending on the manufacturer of the cable box, there will be a menu somewhere regarding aspect ratio using the terms - cropped, zoom, and a few other terms as well. You probably want cropped, which will cut some of the sides off, but you wouldn't miss the picture as a whole when view at full screen. Hope this helps!
Jun 14, 2008 | Toshiba 43H70 43" Rear Projection...
Televison & Video Logo
132 people viewed this question
Top Televison & Video Experts
Electro Med Services...
