Question about Respironics Health & Beauty
MY HELIOS PLUS WON'T FILL. WHEN PLACED ON THE RESERVOIR TO FILL, WITH THE FILL LEVER OPEN, IT ALLOWS THE O2 TO ENTER, BUT IMMEDIATELY PURGES THRU THE PORT ALONG SIDE THE FILL PORT ON THE BOTTOM OF THE UNIT. THIS HAPPEN WHILE THE WAS UNIT EMPTY. ONCE BEFORE WE WERE ABLE TO FILL THE UNIT, BUT IT WOULDN'T FUNCTION ON 4 L/M PAUSE MODE. WE LET IT SIT FOR ABOUT 5 DAYS AND IT BEGAN TO WORK. ANY IDEAS WHAT'S GOING ON? THANKS FOR YOUR TIMELY RESPONSE! RAY BODICKY
moncapitaan
  • 78 Answers
SOURCE: Water leaks (spewing) from sides of bottom of machine when it's filling up
The normal cause of leaking while it is filling is a leaking Inlet hose. Try pulling the washing machine away from the wall and watch the hoses as the machine fills. If it is leaking you can see which hose is leaking. You may either need new tighner clips or to replace the hoses depending on how bad they are leaking. Another possibility is the water pump inside the washing machine could be broken and spewing out water.
Posted on Aug 31, 2007
  • 1294 Answers
SOURCE: My machine will fill & go thru a wash cycle but wont rinse or spin.
Check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
Rate me pl.....if helped.
Posted on Feb 08, 2008
ozztech
  • 285 Answers
SOURCE: Zebra 4M Plus Pauses unexpectedly
try to run the manual calibratio from the setings.
run "manual calibration"
move the ribbon out from the sensor (with the print head open) and take out 3 or 4 labels from the rollar and put that blank label paper unther the sensors on the left,
say "ok"
wen appear "reload all"
put the ribbon and the normal labels on the correct possition, and say "ok"
try to run sext the sensor profile.
save data (twice on "setup button")
tur off, and on again.
Posted on May 08, 2008
Nic61
  • 1073 Answers
SOURCE: numeric key pad
Whats the model of your laptop?
I know that on some IBM models, there was a button called "Num Lock", and by pressing that on you activate the nemeric keypad under the ordinary letters
Posted on Dec 10, 2008
  • 79 Answers
SOURCE: 1999 GMC Jimmy Running Hot w/ Engine coolant reservoir empty
Hi
The problem is most likely 90% head gaskets but could be intake manifold gasket leaking too. Intake gasket has to be checked when intake is removed. Might find problem there if not continue and remove heads. Bars Leak will not work.
Posted on Apr 03, 2009
How much power steering fluid is required upon rebuild and pump replacement?
If you replaced the rack and pinion, it takes about a quart. To purge the air out, Fill the reservoir to the top of the pump, unplug the coil pack. Crank the engine and turn the wheel left and right. Watch the reservoir so you don't make it over flow, The fluid will rise and fall as you turn it. Turn it about 10 times, check and refill the same. Do it again. Two times usually purges the air, three times always purges the air. Plug the coils up, start the car. turn the wheel all the way left and right, check fluid. Should be ready to go.
Jun 27, 2015 | 1998 Ford Taurus
Need help bleeding clutch on my 05 v-rod
As the clutch wears the fluid level in the reservoir will rise so the initial fluid level should not exceed the FILL LEVEL. And the motorcycle must be upright and the handlebars set to level the fluid in the clutch reservoir.
When filling an empty clutch fluid line, a VACUUM BRAKE BLEEDER with a fitting that mates to the secondary clutch actuator bleeder screw threads can be used to draw the fluid down the clutch line and the air out of the system.
Take off the clutch fluid reservoir cover and then initially loosen the banjo bolt just enough to allow air bubbles to escape. Be careful because clutch fluid under pressure can squirt a steady stream a long way.
Hold the reservoir cover in place and pump the clutch hand lever 5 times or so and then hold the clutch hand lever against the handlebar and with a shop towel under the fitting loosen the banjo bolt and watch fro air bubbles to be released and then retighten the banjo fitting and only after it is tight release the hand lever. Check and refill the reservoir with fluid to the FILL LEVEL line and repeat the previous step three or more times and until only a steady flow of clutch fluid without air bubbles escapes from the banjo fitting at all times keeping the clutch fluid level in the reservoir at the FILL LEVEL with motorcycle in an upright position.
THEN remove the secondary clutch actuator cover, cover the exhaust pipe(s) with towels and place a suitable pan under the right side case to catch excess clutch fluid THEN while holding the reservoir cover in place pump the clutch hand lever 5 or more times, then hold the clutch hand lever against the handlebar and loosen the secondary clutch actuator bleed screw and watch the bleed screw for air bubbles. When the hand lever touches the hand grip hold it there without releasing it until the bleed screw has been tightened again and then release the hand lever., refill the fluid reservoir to the FILL LINE and repeat the previous steps, always keeping the fluid reservoir full of fluid, until a steady stream of fluid with no air bubbles coming from the bleed screw. When there is no more air coming out leave the bleeder screw tight and fill the reservoir with fluid to the FILL LINE.AUTION
THEN test pressure by squeezing clutch hand lever repeatedly does not build pressure in the hand lever and the fluid level does not remain at the FILL LINE then there is a leak somewhere and it will have to be located and fixed. If there is no visible leak check the secondary clutch actuator boot for leakage.
When there is no evidence of leakage and the clutch lever works properly and the fluid in the reservoir is at the FILL LINE install the reservoir cap and insert and tighten the fasteners to 0.7-0.9 Nm (6-8 in-lbs); the reservoir banjo bolt to 23-31 Nm (17-23 ft-lbs); the bleed screw to 9-11 Nm (80-100 in-lbs); the secondary clutch actuator cover fasteners to 6-10 Nm (53-88 in-lbs) and then test ride the motorcycle.
If the clutch does not have correct pressure you may have a dragging clutch and/or hard shifting.
Jun 12, 2014 | 2004 Harley Davidson VRSCA V-Rod
How do I bleed the brakes on a 2007 Kawasaki zx-10r?
For front brakes. Fill reservoir with fresh brake fluid.
Pump lever until it is tight. Open bleeder and slowly pull lever into closed position letting fluid out of bleeder. Close bleeder, then let go of lever. Refill reservoir as needed.
Repeat the above until the fluid comes out in a clear stream. Do the other bleeders the same way. Rear brake you pump the foot petal , of course.
May 23, 2014 | Motorcycles
How does the easy fill water dispenser work?
there is a micro switch behind the door lever wich activates a water valve solenoid that allows water to go thru.
Oct 23, 2013 | Amana 21.9 cu. ft. Bottom Freezer...
How do I Bleed my clutch on my 07 honda cbr1000rr
  • 1 Fill the fluid reservoir and lightly tap the line, lever and reservoir to free any air bubbles trapped in the fluid. Keep the fluid reservoir filled to prevent air from entering the line.
  • 2 Pump the clutch lever three to four times, then hold it in.
  • 3 Open the fluid fitting on the slave cylinder a half turn. A small amount of clutch fluid should appear
  • 4 Close the fitting before the fluid stops moving and release the clutch lever.
  • 5 Repeat Steps 2 to 4 until the fluid's color is consistent and without air bubbles. Fill the fluid reservoir as needed.
    Tip: If you don't want to make a mess, slip a clear hose over the end of the bleeder so you can catch the fluid.
    I hope this helps.
  • Aug 28, 2011 | Honda FXDLI Dyna Glide Low Rider...
    How do I bleed the clutch on a 1978 Honda Goldwing GL 1000
    break loose the bleed nipple on the caliper. Open the reservoir at the brake lever and fill with fluid. Keep it open as it has a very small capacity and you will be re-filling it as you go along. Wait and see if it will gravity bleed out. If not, pull the brake lever and put your finger over the bleed when you release the lever- so it won't **** air back in. You should be able to feel the air bubbles "squish" out of the caliper. Continue till no air is left.
    Tighten up the caliper nipple and fill the res to the top and your done.
    Jun 25, 2011 | 1978 Honda GL 1000 (K3)
    If you pump the clutch lever it will engage the clutch. when you pull in the lever without doing this it will not engage. How do i fix this problem?
    Take cover off the clutch reservoir and check the fluid level. Fill it if necessary. Look for leaks between the clutch lever/reservoir, down the hose to the clutch slave cylinder. If no leaks visible, slowly squeeze clutch lever and release, watching for air or fluid pumping in the reservoir. Repeat until clutch has a solid pull. If the pull doesn't improve and stay good, you'll need to bleed the hose and slave cylinder. Locate the bleed valve at the clutch, squeeze the lever till it's a good solid pull, hold it in, and open the bleed valve. Watch for air bubbles. After doing this several times, you should get nothing but fluid. Refill the reservoir and close it. Good riding
    Apr 18, 2011 | Suzuki VS 800 Intruder Motorcycles
    I just changed my frunt brakeline and pads i dont have any pressur what do you think the problem is thanks bill
    Hello Bill.
    You must bleed the brake line (remove all the air).
    First fill your reservoir, leaving the cap/cover OFF.
    2. Open the BOTTUM bleed screw on the front caliper it self. LET it set there (open) until fluid runs freely thru, (do not let fluid get more than half empty in the reservoir during this time).
    3 After a few seconds of fluid running out of the bottom (30-40 seconds should be adequate), .... then u tighten the front bleeder plug/screw. You NOW should have some srt of pressure! But you also should pump up the front bake lever and manually finish bleeding the front caliper to remove any air left in the system by Gravity bleeding the system.
    THAT will take care of the No Pressure - - - UNLESS your CALIPER is STUCK/FROZEN.
    NOTATION - - - - BRAKE FLUID >>EATS PAINT UP!!!!! WIPE ANY excess off immediately.
    Aug 08, 2009 | 2002 Honda VT 750 CD Shadow A.C.E. Deluxe
    How do you fill the water tank on the steamer conair model GS15RN?
    FOR HOUSEHOLD USE ONLY
    FILLING INSTRUCTIONS
    1. Place the unit on a stable surface.
    2. While holding the water tank with one
    hand, move the release lever toward the
    power cord.
    3. With the reservoir released, pull up on
    the reservoir to remove it from the body of
    the unit.
    4. Turn the reservoir over, revealing the rubber
    inlet cover.
    5. Open the inlet cover and fill the tank
    with everyday tap water (filtered water may
    reduce hard water problems).
    6. Close the inlet cover and return the
    reservoir to its place, making sure that the
    reservoir is secure.
    Hope this helps! Hal
    Jun 04, 2009 | Conair Compact Garment Steamer Iron
    Inatallation 92 honda accord power steering pump
    Hey, here's the procedure, disable air bag, if equipped w/ one, disconnect the pump return hose from the reservoir and place the end in a large container. Plug the port in the reservoir. Start the engine and turn the steering wheel lock to lock several times, until fluid stops running from the hose. Turn off engine immediately. Re-attach hose. Disconnect the inlet and outlet hoses at the pump. Remove the drive belt. Remove the mounting bolts/nuts and remove pump.
    Install in reverse order. Adjust belt tension,fill ps reservoir and bleed any air from the system (to bleed air from system, fill reservoir, start engine and allow to idle, turn wheel from side to side all the way several times. Shut off, fill if necessary.
    . Tighten bolts to : Thru bolt 30 ft lbs., mounting nut 16 ft lbs.
    Dec 26, 2008 | 1992 Honda Accord
    Health & Beauty Logo
    Top Respironics Health & Beauty Experts
    David Payne
    David Payne
     Bob S
    Bob S
    Level 1 Expert
    Are you a Respironics Health and Beauty Expert? Answer questions, earn points and help others
