Question about Canon L90 Fax
Fax won't receive fax. Yesterday, it said it needed a new toner cartridge. It stopped receiving faxes at that time. I added a new cartridge today and it won't received faxes still. Thanks, Gail 478 254-3751
  • gwest76829 Mar 18, 2011
    Thanks. It's working now.
  • 2,632 Answers
Welcome to Fixya. If your fax machine cannot receive faxes automatically, ensure you have set your machine to automatically receive them. In addition, the unit may already have a document stored in its memory and there is no more memory available. See if an error occurred during reception by checking the LCD screen for a message. You can also print an Activity Report, checking for an error code. If none of these are your problem, make sure the multi-purpose tray is not empty and that the phone line is connected properly.
If you have questions please let me know. Thanks for using Fixya.
Posted on Mar 17, 2011
  • Rofel Lantican
    Rofel Lantican Mar 17, 2011
    You can also use the support site to fix the problem. Click Service and Support and type unable to receive fax. You will see various solutions about the problem
    Canon L90 Fax
MY HP FAXNUMER 640 WON'T RECEIVE FAXS AFTER I REPLACED TONER CARTRIDGE
The two aren`t related, you must have pressed a button that changed the `reception mode` to Manual from either `auto` or `tad`
Apr 04, 2012 | HP 640 Inkjet Fax Machine
Incoming fax does not print, and also cannot get printout of faxes received. Memory was received. Regular printing and photocopying works fine.
if you found the msg on lcd like "toner empty" & red light near the lcd
then you have to reset toner counter through tech mode.
MENU # 1 9 3 4 MENU pres continues you will find tech mode on lcd
then press 3 times right arrow key "new cartridge" will come on lcd bottom line
then press 2 times ENTER button & swicth of the macine for 5 second then on
all samsung mfds stop printing FAX when "TONER EMPTY" msg comes.
Feb 10, 2011 | Samsung SCX 4521F All-In-One Laser Printer
White space in middle of faxes sent or received
Printing irregularites on sent faxes are due to spots or a dirty scanner.
Spaces on received faxes are due to a dirty drum, corona wire, or a failing or improperly installed toner cartridge. A new cartridge should be gently shaken back and forth sideways prior to installation.
Jun 23, 2009 | Brother IntelliFAX 4750 Plain Paper Laser...
Fax not receiving
if there are "empty toner"
the printer not print received fax until cartridge replacement.
May 21, 2009 | Samsung SCX-4828FN All-In-One Laser...
Can't receive fax but can send fax
I have a feeling that it is a re-manufactured or compatible cartridge??
There is a fuse that needs to be replaced on this unit. it blows when the cartridge is installed to reset the machine. If the fuse has not been replaced or is defective the machine will not recognize the new unit.
Feb 12, 2009 | Samsung SF-5100 Plain Paper Laser Fax
Black vertical streaks on faxes & copies
On top of the toner/drum cartridge there should be a blue slider, move back and forth 10 times.
If no fix, you need a new toner cartridge.
Dec 30, 2008 | Brother IntelliFAX 2600 Fax
Low toner message
sounds like you have a bent toner sensor. turn the machine off and take the toner out and place on the side
what you could try to do is grab a piece of paper fold it in 4 like so
__ __
|__|__| __
|__|__| then rip one piece like so |__|
then rip one piece off and fold that 5 times over it self.
look into where the toner goes in the middle you will see a silver bracket with a black round piece of plastic on the top left conner you need to put that piece of paper under that coner where the black circle is and turn the machine back on then put the toner in.
if this does not work you need a tech to look at it
Dec 04, 2008 | Panasonic Panafax UF-790 Plain Paper Laser...
SF-560R. When receiving and sending Faxes
needs a new toner cartridge probably but the fuser rollers may be damaged as well usually if the lines are indented into the paper that means its the fuser roller if they just appear strait down the page then its the toner cartridge
Nov 18, 2008 | Samsung SF-560 Plain Paper Laser Fax
GestetnerDsm516pf
I'm surprised you're trying to make a buck off this kind of stuff. Instead of being part of the solution you're part of the problem. Easy one .....get the service manual. Mfg has rigged it so you must buy New cartridge unless you can discover the key to reset counters.
Thanks
Mar 26, 2008 | Gestetner Office Equipment & Supplies
Samsung scx-4521f fax memory received but never print out.
In 3 second make combination on you Samsung 4521F 'Menu'-#-1-9-3-4. You will enter in tech menu. Select 'toner'-new toner-yes. You will receive faxes. It really works.
Oct 24, 2007 | Samsung SCX 4521F All-In-One Laser Printer
Canon L90 Fax Logo
156 people viewed this question
old marine
old marine
