Question about Cameras
Hi! When I put the camera on it says in the display: "locked card". I can print the pictures out but I cant take a new picture or delete the old ones. Whats happened?? C. Its a CANON, digital ixus 70
  • 1,679 Answers
Remove the memory card and you will find a switch on the left side of the card. It must be locked, so slide or push the lock on other side to open it and then insert the card back to the Camera.
Regards
Ron
* Please rate this solution with Thumbs up and Testimony to help us improve providing support
Posted on Mar 17, 2011
Memory card error appears.cant take any more pictures. what do i do now...
Your camera can handle MMC and SD cards. Modern SD cards are most likely SDHC cards and can't work in your camera. `please look for maximal 1 or 2 Giga Byte cards and the should not have SDHC or SDXC printed on them.
If your card is full, and it won't take more pictures, try putting most or all photos on a computer. Then delete the pictures you transferred. Make sure you also backup you pictures on an other medium.
Also check the lock switch on the memory card is NOT in the lock position.
Jun 22, 2014 | HP Photosmart M415 Digital Camera
Tip
Transfer photos from Camera to PC
<span><span><i><b>Hello and welcome to FixYa!</b></i><br /> <br />To transfer your photos from your</span><span> Digital Camera</span><span><span> to PC, Follow the given steps:</span><br /> <span style="font-weight: bold;">1.</span>First connect your digital camera to your computer.<br />You can do this in two different ways:<br /> <br /></span></span> <ul> <li><span><span> <b>Use a USB cable:</b>Most digital cameras come with a cable that connects the camera to a USB (Universal Serial Bus) port on your computer.</span></span></li></ul> <ul> <li><span><span> <b>Through memory card:</b>A memory card reader is a piece of hardware that plugs right into your computer. You remove the memory card from your camera and insert it into your memory card reader, similar to the way you might transfer a file between two computers using a floppy disk.</span></span></li></ul><span><span> Now connect USB cabe or Memory card Reader to the port of the computer<br /> <span style="font-weight: bold;">2</span>.Once you've connected your camera to your computer or inserted your memory card into your memory card reader, your computer will detect the connection and ask you what you want to do with your pictures. If you connected your camera with a USB cable, click <b>Microsoft Scanner and Camera Wizard</b>, and then click <b>OK<br /><br /><img src="angel_bird_1.gif" /><br /><br /></b></span></span><span><span>If you are using a memory card reader, click <b>Copy pictures to a folder on my computer using Microsoft Scanner and Camera Wizard</b>, and then click <b>OK</b>.<br /><br /><img src="angel_bird_2.gif" /><br /><br /></span></span><span><span><span style="font-weight: bold;">3</span>.When the Scanner and Camera Wizard appears, click <b>Next</b>.<br /> <span style="font-weight: bold;">4.</span>All of the pictures on your camera (or in your camera's memory card) are now displayed on the Choose Pictures to Copy page. By default, Windows XP selects all of the pictures for downloading. If there are pictures you do not want to download, just clear the check box next to those pictures. At this stage, you can also rotate pictures that you took while holding your camera vertically. To rotate a picture, click it, and then click either the <b>Rotate clockwise </b>or <b>Rotate counterclockwise </b>button on the lower-left side of the page. When you have reviewed the pictures for downloading and rotated your vertical pictures, click <b>Next</b>.</span></span><br /><img src="angel_bird_3.gif" /><br /><br /><span><span><span style="font-weight: bold;">5.</span>On the Picture Name and Destination page, type a name for the group of pictures. (This name, plus a number to differentiate each picture, will be applied to each of the pictures you download; for example, if you name the group "Vacation," the pictures will be named "Vacation001," "Vacation002," and so on.) Click <b>Browse</b>, and select a folder in which to save your pictures.<br /> <span style="font-weight: bold;">6</span>.If you want to erase the images from your camera's memory card to make space for new ones, select the <b>Delete pictures from my device after copying them </b>check box, and then click <b>Next</b>. The Scanner and Camera Wizard copies the pictures from your camera to the folder you specified and then removes the pictures from your camera's memory card.<br /><br /><img src="angel_bird_4.gif" /><br /><br /><br /></span></span><span><span><span style="font-weight: bold;">7.</span>On the Other Options page, you can choose to publish your pictures to a Web site or order prints. If you have finished working with your pictures, click <b>Nothing</b>, and then click <b>Next</b>.<br /> <span style="font-weight: bold;">8.</span>On the final page of the wizard, click <b>Finish</b>. Windows XP opens a Windows Explorer window showing the pictures you downloaded from your camera. Your camera's memory card is now clean and ready to store new pictures. If you connected your camera to your computer using a USB cable, disconnect your camera. If you used a memory card reader, return the memory card to the camera.<br /> Your photos are now stored on your PC, ready for whatever you want to do with them, and <span style="font-style: italic;">your camera is ready to take more pictures.</span></span></span><br /><br /><span>Thank you for Using FixYa!</span><br /><span><span><br /></span></span>
on Apr 28, 2011 | Cameras
Samsung PL100 - strange problem
Put the card back into the camera and format it.
In the future, always format the camera after you finish download your pictures, instead of deleting them.
Jun 03, 2012 | Samsung PL Cameras
How do I delete pictures when the camera will not display them
Hi can you take the memory card out and look at them on a pc or laptop ? if so you could delete them there.
You could delete everything on the card by formating the memory card.
Sounds like there is some sort of problem with the card or camera if you cant see the pictures. Can you see any pictures on the camera? Do you have another memory card you could use to do a few test shots on and then see if you can delete them.
May 30, 2012 | Nikon D60 Digital Camera
Protected card on camera?
your card is probably locked take out the memory card and on the side is a lock tab slide the tab to unlock when you put it in your camera it may say format card when you do this it will format the card but will delete any pictures saved to the actual cameras memory so save them on your computer or print them.
Mar 20, 2012 | Hitachi i.mega HDC-401 Digital Camera
I cant use my cam the screen appear only the "WRITE PROTECT" word with a pic of like key.but still i see my old picture.i cant take new picture.
Take the memory card out of your camera and look at it. SD and SDHC cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Jul 28, 2011 | GE A830 Digital Camera
I have Sony DSC-T90 camera. I think it's memory card is virus infected. When i attach my camera to computer to download pictures then only shortcuts of the folders are displayed. I can view the...
Have you tried removing the memory card from the camera and inserting it directly into the computer's card reader or any other card reader?
May 20, 2011 | Cameras
Canon IXUS 95 IS - camera is displaying "card locked". I am unable to delete pictures and take pictures. Also i am unable to delete the photos from my computer. I get an error saying that write...
Take the memory card out of the camera and look at it. SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
Dec 07, 2010 | Cameras
My PS SD1220 IS is displaying "Memory Card Full". How do I empty the Memory Card?
Just delete some pictures you have taken. You can use memory card reader to copy your pictures to computer and then delete some picturse or all of them. And you can delete pictures directly with your camera. On the back side you can find delete button it hase simbol of basket.
Dec 05, 2010 | Canon PowerShot SD1200 IS / Digital IXUS...
I have a Canon Powershot camera. While I was on holildays I ran out of room on my memory card so started deleting some older photos. After deleting half a dozen or so, the picture on the display showed a...
Two things to try: 1. Go into the camera menu and find "reset" to get the camera back to factory default settings. 2. With the new card installed, go into the menu and find "format"...follow the on-screen instructions. If the new card now works, you will probably need to do the same with the old card but download the pictures first using a card reader if necessary because formatting will completely erase it.
Oct 28, 2010 | Canon PowerShot SD600 Digital Camera
Cameras Logo
62 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
