Question about Disney Memorex Portable CD Player Personal CD Player
HOW TO TURN ON MEMOREX CD PLAYER 6451R - Disney Memorex Portable CD Player Personal CD Player
Memorex portable cd player will not hold place on the cd when turned off
Audio books may be different but with a music CD if you press STOP once you can pick up where you left off. Pressing STOP twice reverts to the beginning.
Jul 15, 2016 | Memorex MD6451R Personal CD Player
I can't get my Memorex dvd writer to play a DVD, is there something I need to do to start it?
Search Results
    Amazon.com: Memorex 98251 CD/DVD Writer 8x- External ...
    www.amazon.com/Memorex...DVD-Writer.../B002O0...
    Amazon.com, Inc.
    Rating: 3.5 - ‎51 reviews
    Amazon.com: Memorex 98251 CD/DVD Writer 8x- External: Electronics. ... my hp/xp has a writeable cd drive but a player dvd. wanted to save space on my hp ... hoops toget it to work, and I also feel cheated that I can't use the cd software that ...
    Customer Reviews: Memorex 98251 CD/DVD Writer 8x ...
    Amazon.com, Inc.Memorex 98251 CD/DVD Writer 8x- External ... See all 30 positive reviews> .... myhp/xp has a writeable cd drive but a player dvd. wanted to save space on my hp ... hoops to get it to work, and I also feel cheated that I can't use the cd software ...
Dec 29, 2015 | Memorex 32020019660 8X DVDRW External Slim...
I have an older Memorex Radio CD Player compact music system (wall mount) that I need to take off the wall or find a manual.
MEMOREX Portable CD Player Boombox FOR PARTS OR ...
www.ebay.com/.../MEMOREX...CD-Player...PARTS...-/151141511...
eBayMemorex Portable CD Player MP8806 CD/Radio Boombox Fast Shipping ... Sharp Boombox CD Cassette Recorder Player AM FM Radio Portable Parts or ...
Oct 15, 2015 | Cars & Trucks
I Lost the dam instruction Guide and I cant figure out how to turn it on... It pisses me off that yall cant make one online! So please tell me how to turn it on...
unfortunately, the service manual for your Memorex MD6451R Personal CD Player is not available anywhere online. The manufacturers of this Unit did not make it available. I went further searching and couldn't find any.
I would suggest you contact the manufacturer of your Memorex MD6451R Personal CD Player via phone or e-mail and request for the service manual from them. They might give it to you or direct you to a dealer where you can get the service manual.
This is the best you can do to get the service manual you are requesting for.
Also there are similar manual for Memorex Cd player that you can use as a guide tool.
http://www.generalmanual.com/Players/Memorex-MD6451R-BLK-Personal-CD-Player.htm
Good luck.
May 30, 2011 | Memorex MD6451R Personal CD Player
I have a memorex cd player and it plays the same song over and over again. I know its sticking and not the cd itself. What can I do ? the product is a memorex mp8806 cd/radio player
I found a diagram of a cd player when I asked for a general search on the net, since memorex couldn't find the model number because it was not a new line of products. From the diagram and e-how I was able to learn that I needed to clean the laser head with a special solution. I will try that but not now. At least I know it is fixable and should not be thrown away.
Thanks for all your help
Jan 19, 2010 | Memorex AM/FM Clock Radio with CD Player
MMP9008 Wont turn on
I'm having the exact same problem, and I'm 99% certain I know how to fix it. Unfortunately I need the cd that came with it, and I don't have it. On the cd there should be a folder with some files to re-install the firmware on the player. It might have "stmp" in the name but I'm not sure. Assuming the cd does have those files, you want to first install the drivers that come in that folder. Then on the mp3 play, keep it unplugged, hold the on switch in the "On" position, and while keeping the switch held, plug in the usb cable to the player(make sure the other end was already plugged into the computer.) What this does is force the player to be detected by windows as a recovery device. Those drivers you installed were for this new setting. Once that's done you can run the firmware installer/updater from the cd, and it should re-install the original firmware. Then just unplug the player, wait 30 seconds or so, and then turn it on as normal. That -should- get it working again. If it doesn't, you might have to plug it back into your computer, the normal way, and format the player's hard drive. You'll lose whatever music and videos you had on it, but it might need to be formatted after a firmware re-install.
If I'm right about the cd having the firmware update(and I should be), and assuming my post is helpful, you might consider putting those files into a zip file and emailing it to me at polign at yahoo dot com so I can fix mine too. I've searched the internet for hours, and no once has it for download. I'd really appreciate it. And if you don't happen to have the cd, then I guess we're both out of luck.
Good luck fixing yours.
Nov 30, 2008 | Memorex Audio Players & Recorders
Memorex Model MD6451R CD play - LCD readout "hold"
Looking down on the unit from above with "Memorex" reading left to right look at about one oclock. There is a switch marked hold ...turn it off. Its black on black, so its hard to see. It disables the onboard controls. The remote if you have it works either way, but when on hold it will act just as you describe.
Aug 06, 2008 | Jwin Personal CD Player
Disney Memorex Portable CD Player Personal CD Player Logo
29 people viewed this question
Top Disney Audio Players & Recorders Experts
Lyle Siemens
Lyle Siemens
Are you a Disney Audio Player and Recorder Expert? Answer questions, earn points and help others
