Question about HP DeskJet F4280 All In One Printer InkJet
Pages are printing on an angle, how do we get it to print straight
  • 1,179 Answers
You would use the software that came with you printer.
Look for the option to align the ink head/nozzles!
Thanks
damnor01
Posted on Mar 17, 2011
Not printing straight
Check the paper guides in the trays closely to make sure that they are set correctly.
Sep 14, 2015 | Kyocera Office Equipment & Supplies
My Dell 946 All in one printer prints all pages at an angle.. how do I fix this
go to your printing options... maybe, all the things you will print are set to a specific angle.
May 02, 2010 | Dell 946 All-In-One InkJet Printer
Printer using to many pages at once
When printing in moist climate or conditions, be sure to fan your paper before loading printer. Also set your paper guide so that the paper does not pull in on an angle.
Mar 25, 2010 | Canon PIXMA MP150 All-In-One InkJet...
Media problem during printing
If the media is coimng out straight, then look at the cutter mounting.
If the cutter is slightly off angle then it can be corrected on the mounting beneath the right lower side, and the lft upper (head latch) side.
Try printing a barcode or straight line of print on the top and bottom of the label. Look at the print in relation to the cut.
If it is off , it may also be the printhead azimuth.(angle of the head in relation to the platen roller(roller beneath the head).
There is an adjustment fo tthe head to suare it up to the platen.
Jan 27, 2010 | Zebra 105SL Thermal Label Printer
Di351f. Can not print over the network.
I am confused. If you can see the printer via the web browser and you can print a window's test page you are all set up and ready to print. There should be no problem printing as long as you have that printer selected as the default printer and it is selected in whatever program you are printing from. What do you mean by "straight over the network"
Dec 22, 2009 | Minolta Di351F All-In-One Printer
HP C7280 does not print straight, ie the print is angled on page
There is no way that a printer prints out of alignment unless the paper slips enroute. Meaning that the rollers are not holding the paper tight and the guides not pressing the paper snugly, as you put it. So, it could either be the rollers not aligned to each other properly or the guides not pressing the paper equally. The print head moves on a steel rod which is straight. So that can not be the culprit as the print head has to move in a straight line, irrespective of the paper being straight or slipped. So, that leaves us with the slipping paper for which there are the rollers and the guides. If you feel that the tension in the guides is not equal, then change the guides, else the rollers need a closer look. Or at least clean them with a damp soft cloth and allow them to dry up before using them.
Nov 04, 2009 | HP Photosmart C6180 All-In-One InkJet...
Pages printing off-centre
Have you run the print head alignment program? It will be in your printing software.
Oct 19, 2009 | Office Equipment & Supplies
How do I put new cartridge in
Follow this procedure to install print cartridges in you printer.
1 Turn on the HP Officejet, and then lift open the print-carriage access door.
The print carriage moves into view.
2 After the carriage stops moving, push down on the top of the print
cartridge to release it, and then pull it toward you out of its slot.
3 Remove the new print cartridge from its packaging and, being careful to
touch only the black plastic, gently remove the tape by using the pink pull tab.
Caution! Do not touch the gold-colored contacts or ink nozzles.
Once you have removed the plastic tape, install the print cartridge
immediately to prevent the ink from drying in the nozzles.
4 Hold the black or photo print cartridge with the HP label on top. Slide the print cartridge at a slight angle up into the right side of the print carriage.
Press firmly until the print cartridge snaps into place.
Caution! Do not attempt to push the cartridge straight into the slot.
It must slide in at a upward slight angle.
5 Hold the tri-color print cartridge with the HP label on top. Slide the print
cartridge at a slight angle into the left side of the print carriage.
It must slide in at a slight upward angle.
Note: You must install both print cartridges in order for your HP Officejet to work.
6 Close the print-carriage access door.
“Press OK to print Align page” appears on the display.
7 Press OK.
Oct 06, 2009 | HP OfficeJet 4215 All-In-One InkJet...
Printing has started coming out at a slight angle
Please click here and folow the instructions to resolve the issue.
May 21, 2009 | HP OfficeJet 7410 All-In-One InkJet...
I can't print web pages
What Internet programme are u using? Ie: Internet Explorer.. mozilla etc ! need info ..
Regards Faggly
Mar 27, 2008 | Office Equipment & Supplies
HP DeskJet F4280 All In One Printer InkJet Logo
Seeker5211
Seeker5211
