Question about OKI MICROLINE 320 Turbo Matrix Printer
How do I set my Oki Microline 320 Turbo to automatic tear. When I print an invoice it will not automatically move to the top to the perforated line.
  • 40 Answers
SOURCE: oki microline 590 elite
What driver are you using for this printer? Try loading a Epson LQ1050 driver and try again.
Dezzi
Posted on Dec 31, 2007
  • 139 Answers
SOURCE: Oki Microline 320 Turbo page alignment
This sounds like a problem in the computer program that is sending the prints to the printers....especially since it is happening in several of them.
Posted on Jan 23, 2008
SOURCE: Alarm light Microline 320 Turbo 9 pin printer - won't print
We swapped out the printer for another one we had in the office that was working. The new printer also got the alarm light. From that we concluded that it was a bad serial card. We swapped the serial card from another printer, and the original printer started working perfectly. Now we just need to find out where we can purchase another serial card, as we have no more 'spares' around here.
Posted on May 23, 2008
flopez
  • 161 Answers
SOURCE: oki microline 320 turbo
Your Oki model does not need drivers, for they are already contained since Windows 98 and up. However, if it still doesn't work, check that the printer emulation is set to IBM and then install a new printer using the IBM Proprinter II/III driver, also contained in Windows.
Be blessed.
Posted on Nov 07, 2008
wayneard
  • 1901 Answers
SOURCE: oki 320 turbo, serial interface, how do I change
To change the settings, make sure you have a good ribbon installed.
Press the MODE button. The SEL light will go out. Menu light will come on.
Press the GROUP button until the printer prints something like:
Serial Interface Parity None
To change the Parity, press SET. A new line will print as:
Serial Interface Parity Odd
Press SET until the Item is the one you want.
Then Press the ITEM button. It will then print:
Serial Interface Serial Data 7 or 8 bits 8
Again if you want to change it, press SET. Otherwise go to the next Item.
Continue using the ITEM button to choose the item you want to review or change and the SET button to change the selection.
When you have made all the changes verify by going through all of the items with the ITEM button. When you are satisfied, Press the MODE button to save all of the changes. (The Menu light will go out.)
If you have any trouble Comment back.
Thanks for using Fixya.
Posted on Aug 27, 2009
We print a 3 part Invoice and the print on page 2 & 3 are so light you can hardly read them.
On the left side of the ribbon holder is a blue lever. move this towards the paper (rear of the printer) until you get clear prints
Dec 13, 2010 | OKI MICROLINE 320 Turbo Matrix Printer
Installed a new okidata microline 320 turbo dot matrix printer and now the tear/set button does not set the paper where i need it to as my old printer did. How can i change the tear line setting?
Make sur that the paper length is correct in the settings. With paper in the printer hold down the "SHIFT" button then press the "SEL/MENU" button. The "SEL" indicatr will light up. Now press the "PARK" button, a settings page will print. Select your paper length you require by going through the settings, if you press the "LF" button it wil take you through the different groups of settings, the "FF/LOAD" button wil take you through the different items in the groups and the "TEAR" button will change the settings on the different items. To save the new settings hold down the "SHIFT" button and press the "SEL/MENU" button.
Aug 20, 2009 | OKI MICROLINE 320 Turbo Matrix Printer
Rolling halfway down the page
is the form tear off on?
if it is try changing it to off
Dec 03, 2008 | OKI MICROLINE 320 Turbo Matrix Printer
OKI DATA MICROLINE 320 TURBO PRINTER PROBLEM
Hi Charles,
Use the IBM proprinter driver for this printer and select IBM in the menu of the printer.
Hope this helps.
Dezzi
Sep 10, 2008 | OKI MICROLINE 320 Turbo Matrix Printer
Used to print pharmacy medication administration records. Problem!
This sounds (vaguely) familiar; I maintained these excellent workhorses years ago.
It sounds as if the initial settings have changed or been changed that allow one to set paper length, default font and so forth.
Oddly, I saw the service manual first, here:
http://www.eserviceinfo.com/downloadsm/14445/Oki_ML%20320%20&%20321%20Turbo.html
Jul 14, 2008 | OKI MICROLINE 320 Turbo Matrix Printer
Oki microline 320 turbo printer
Did you check your print queue? May be there is an error in there waiting for you to instruct it.
May 22, 2008 | OKI MICROLINE 320 Turbo Matrix Printer
Feed and Tear Off position problem
You can give this a try. This will alter the top of form setting.
http://www.profitmonster.com/printers/ml320tb.html
Let me know if this helps.
Mar 27, 2008 | OKI MICROLINE 320 Turbo Matrix Printer
Jan 23, 2008 | OKI MICROLINE 320 Turbo Matrix Printer
Page advance problem
print out your menu of the printer and load the IBM Proprinter driver in windows ,your printer default driver is IBM Proprinter this will sort out the problem.you have probably loaded a OKI driver while the printer is set for IBM.Hope this helps.
Dezzi
Oct 16, 2007 | OKI MICROLINE 320 Turbo Matrix Printer
OKI MICROLINE 320 Turbo Matrix Printer Logo
62 people viewed this question
Top OKI Office Equipment & Supplies Experts
WTF Chuck.....
WTF Chuck.....
Jimbras
Level 1 Expert
mukhtar21 shaikh
mukhtar21 shaikh
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
