Question about Fujitsu ScanPartner fi-5015C Pass-Through Scanner
Im getting black lines on my paper. - Fujitsu ScanPartner fi-5015C Pass-Through Scanner
    Problem Solver:
  • 12 Answers
YOU NEED TO GET THE SCANNER SERVICED TO REMOVE THE BLACK LINES AS DUST IS INSIDE THE GLASS
Posted on Mar 23, 2011
How to get rid of the vertical black line on the paper?
Usually replacing the toner cartridge fixes that problem. Sometimes it's the fuser.
Jan 20, 2014 | HP LaserJet 1018 Printer
I have tried everthing in "Lexmark X5495 Help"
Sounds like you just need a new printer. Some times the encoder wheel can get dirty with aerosolized ink and it will start to skip lines. The encoder wheel is a small plastic wheel on the paper feed of your printer. Around the edge of the wheel are hundreds of small thin black lines. As paper goes through the printer it counts these lines as the wheel turns to know how far to push the paper. If ink or debris gets between the lines over time it can start counting two lines as one and thus advance the paper too far, causing blank space between prints. See the below picture of a printer encoder wheel for reference. My professional opinion is to not purchase Lexmark. New Canon printers are very reliable with a high quality output, look for one that uses CLI-221 cartridges. Or most any HP.
Oct 29, 2010 | Lexmark X5495 All-in-One &USB...
Problem with printing black and white photos
Probably what happen is that you are printing black and white but you have your printer on color mode, try to set the printer to grayscale or black and white before print. The printer is tring to get the black and white by mixing all three color, that is the most comon way of make black, so, when one of the color is missing you see those red lines.
Also you will solve the problem replacing the color cartridge.
May 19, 2010 | HP PSC 1510 All-In-One InkJet Printer
Black line down paper
Pull the doc feeder open and clean the scanner glass
Feb 11, 2010 | HP 1040 Plain Paper Inkjet Fax
Wide black lines down the paper. I have changed
Have you changed the Drum unit. Also there is a cleaning pad that you slide across the corona for cleaning. If you leave it in the middle it will give a black line, should be moved all the way to one side.
Nov 18, 2009 | Brother IntelliFAX 3800 Plain Paper Laser...
When I fax the recieptent is getting 2 big black lines..........ive tried cleaniung it but not sure if im cleaning the corredt parts..........there a little glass part that looks like there may be ink
Open the auto sheet feeder (where you place your originals), look underneath and you will see a narrow "scanner" glass that the originals are scanned across. Clean this thoroughly with glass cleaner (or water) - there is probably correction fluid or some other foreign dirt on it. If you make a copy for yourself (before and after) it gives a good indication of the quality you are sending to fax recipients.
good luck, and please rate solution
Apr 28, 2009 | Brother FAX-575 Plain Paper Thermal
A Dark Vertical line appears 1 inch into the left side of scan
Most Mustek scanners have a black inside cover on the lid, this can give a black line down the side of the job.
ether cover the inside of the lid with white paper or place a bigger sheet on top of the sheet to be scanned!
Jan 24, 2009 | Mustek A3 USB Flatbed Scanner
Black lines on photo
Are the lines always in the same places? If they are, then I would try using different photo paper. Humidity plays a big factor when printing with any kind of paper and buying new paper would be a good start. Make sure that the paper is made for your printer specifically. You might also try printing on plain paper to see if you get the same results.
Jan 17, 2008 | HP PhotoSmart 7760 InkJet Printer
Help
hi im jules_09,check the fuser unit paper are folded because the rubber roller is worn out then the black line is also cause by scratch or damage upper or hot roller in the fuser unit.if the hot roller or uuper roller is fine check the drum unit if the opc drum is damage or scratch then check also the drum cleaning blade or roller,blak line in copy indicate one or two part either in the fuser unit or drum unit is damage.
Nov 15, 2007 | Panasonic FP-7735 Black and White Copier
Black line down right side of paper
On the ADF check the twink mark on glass scanning mirror
Oct 15, 2007 | HP LaserJet 3055 All-In-One Printer
Fujitsu ScanPartner fi-5015C Pass-Through Scanner Logo
149 people viewed this question
Top Fujitsu Office Equipment & Supplies Experts
Electro Med Services...
Are you a Fujitsu Office Equipment and Supply Expert? Answer questions, earn points and help others
