Question about Kenwood DNX5120 DVD Navigation System GPS Receiver
When I go to "Address" I receive the message - No
  • 140 Answers
Try to do an update to your gps and it will work
Posted on Mar 17, 2011
My gps says "no
Question: What should I do if my Garmin nuvi or zumo displays the message "No Detailed Maps Found That Support Routing" or "No Map Data Available?"
--> Answer: The "No Detailed Maps Found That Support Routing" or "No Map Data Available" message may appear on your device for the following reasons:
  • The GPS device is missing it's unlock code
  • The maps on the GPS device have been disabled
To determine the cause of the message, touch the screen until the message "No Detailed Maps Found That Support Routing" disappears.
  • If you see a "Can't Unlock Maps" message following this error, remove any microSD / SD cards in the device and follow the instructions below for Retrieving your unlock codes followed by the instructions for Creating an unlock file
  • If you do not get the Can't Unlock Maps message then skip to the instructions for Enabling maps on the GPS device
Retrieving your unlock codes:
  1. Log into your myGarmin account
  2. Select Manage Maps
  3. Select Details
  4. The unlock code is located under the Installed Maps.
Nov 16, 2010 | Garmin Nuvi 360 Bilingual GPS Navigator...
I was in Tyler Tx. and could not pull up an address. A couple of days earlier I had a message show up that said something about I needed to update. Not sure what that means or how to go about it. ...
How long has it been since you've updated the maps on the unit? You may have gotten a message stating your maps were over a year old, and recommending you update them. The address in Tyler may have been too new for the unit if the maps have not been updated recently also. If this is not the case, you should be aware that some addresses may show as being in a different city due to ZIP code status. For instance, you may know an address to be in a certain town/city, but it may show as being in a neighboring town in the unit as they share a ZIP code. If you cannot find an address in your GPS, go back to the beginning and re-enter the address. When it comes to the city, however, try, "Search All". See if this helps.
Jan 27, 2010 | Garmin nuvi 200W GPS Receiver
"Detail maps Don't Support Routing" in Garmin Quest
I too have a Garmin Quest and yesterday felt like throwing it against the wall because of the above problem. I found the solution eventually. When you download the maps from the Garmin Maps page, where you select the maps download, make sure that the checkbox to "Include route calculation data" is ticked before downloading your maps. Also make sure that the total memory required for the number of maps selected does not exceed the available memory on your Quest. If you try to fit more information into your Quest than it can receive then you are bound to have some problems. The Quests seems to have different memory specifications. According to the USA spec the memory is only 128mb, the Garmin site says 115mb and the box that my Quest came in says that it has 243mb.
Jul 10, 2009 | Garmin Quest GPS Receiver
File format error
search on the internet for other file, because yours is broken. After you have it, overwrite the old file.
You can try http://rapidlibrary.com/index.php?q=canada+fbl+maps
Apr 08, 2009 | Mitac Mio P550 GPS Receiver
Garmin Quest: Not able to upload detail maps
hi bud, just had the same problem. hard reset i.e turn off unit, hold down ok, page and then the power button at the same time. it should then ask you if you want to delete all data. select yes and then you should be able to upload your maps again, this worked for me good luck
Feb 18, 2009 | Garmin Quest GPS Receiver
Map data availability
"I tried to load the new 2008 City Navigator but the update was interrupted."
You deleted your previous maps, therefore there are no maps on the unit. Try reloading the maps again and this time let it continue all the way to the end. It will take a couple of hours depending on loading all maps or only certain states.
Aug 22, 2007 | Garmin StreetPilot c340 GPS Receiver
Kenwood DNX5120 DVD Navigation System GPS Receiver Logo
61 people viewed this question
Top Kenwood GPS Experts
Mike
Are you a Kenwood GPS Expert? Answer questions, earn points and help others
