Question about Food Mixers
Fitting instructions astini pullout kitchen tap
2 Suggested Answers
SOURCE: How to fit POLO PULLOUT SPRAY KITCHEN SINK MIXER TAP 0119 **NDD**
hi i need to fix a pull out sink mixer...but i have no idea how to fix.pls help.thanks
Posted on Aug 19, 2011
Why won't my bristan kitchen mixer tap turn off ? Changed washer but no avail
Modern taps don't have washers, they have ceramic cartridges. If you changed a 'washer', it won't have fixed it. You can contact Bristan direct in this link
Products
Mar 21, 2018 | Food Mixers
The drip ring and a seal ring dropped into the batter how are they attached on a Kitchen aid MOdel k5-a
The drip ring is held in place by friction. Simply put in place and tap it around with a small hammer (use a piece of wood between the ring)- and hammer).
I don't know what you mean by a "seal ring." The only piece I can thong of is a rubber o-ring around the agitator shaft (where you attach the beater). If it somehow broke and worked loose you will have to disassemble the machine to either replace the shaft assembly or to fit a new o-ring. The K5=-A service manual is available on line with a bit of searching.
Oct 09, 2014 | Food Mixers
Will not turn on
Undo the black plastic caps, one on each side. You probably need new carbon brushes. Remove them carefully and note that the brushes will only fit one way there is a blocking stop on the inner edge of the brush holder, you can see it with a torch when brush is out. Line the chamfered off corner of the new carbon brush up with the blocking stop. On one side it is at the back at the top and the other at the back at the bottom ( I think )
Nov 21, 2013 | KitchenAid Kitchen Aid STAND MIXER 5qt...
Kitchen aid 5KSM150PS pin fallen out
The pin that you refer to is called the hinge pin, first get a towel and lay it out on a clean work space (to protect your finish) then turn the mixer upside down on the towel and look down into the base cavity you will see a small screw either flat head or Phillips style or maybe hex. get what ever driver you need to fit that screw ans turn it counter clockwise a couple times, then get a non metallic hammer and gently tap the pin back in until it is flush on both sides. then re-tighten the set screw that you turned counter clockwise, now turn it clockwise and give it a firm turn to set the screw again. If the pin comes out you have to do it all over again but this time you have to turn the pin 180 degrees to get fresh pin to drive your set screw into again, if it happens again you need to replace the pin. let us know if this helped.
Mar 12, 2013 | KitchenAid K45SS Classic Stand Mixer
Oct 05, 2009 | Food Mixers
I need instructions to use my new kitchen aid attachment
Hi. Basically all you really need to know is to start the machine at a slow speed, begin shredding, increase speed to a point where the machine is not labouring. Next time you use that attachment, set it for that speed. Different attachments and the foods they process load different stresses on the mixer. Always use a speed that is one step above/below the labouring sounds. Kitchenaid doesn't see fit to publish these instructions online as they do their other manuals. Another missed opportunity by Kitchenaid. You might want to check out the kitchenaid forum. one of these people just might have it in digital form. Good luck! ricardok45
If this solution has assisted you, please rate it. ricardok45
Mar 19, 2009 | KitchenAid Food Mixers
Can the Kitchen aid accessories fit the Wolfgang puck stand mixer
If you happen to have a friendly toolmaker with a small metal lathe it should not be too difficult to modify KITCHEN AID accessories that fit on to the front powwer outlet. However Puck Stand Mixer accessories are occasionaly offered on the Web. Meat grinders are very common and original Puck pasta maker have also been seen. Get searchin'!
Dec 01, 2008 | Wolfgang Puck Stand Mixer
10 speed - 12 speed arms
Found the answer on the internet. THanks.
Nov 22, 2008 | Food Mixers
Instruction manual for oster kitchen center
how do iget the driver gear off
Sep 03, 2008 | Food Mixers
Food Mixers Logo
71 people viewed this question
Top Food Mixers Experts
Oscar Netto
Oscar Netto
Are you a Food Mixer Expert? Answer questions, earn points and help others
