I cant get the infocus lp70 to display whats on my computer. i have it connected to my computer.
    Sergeant:
  • 261 Answers
Look on your keyboard for a dual display symbol (looks like 2 monitors) usually hit Function (F8) and that will cycle you thru the output options that the computer can do.... Good luck and have a great day.... Sincerely HDTV GURU JAY
Posted on Mar 17, 2011
Process to upgrade firmware for InFocus lp70 ... can some describe this for me please? I've got the firmware downloaded, but my PC does not see the projector .. Help!! I also can not find the USB drivers...
Go here: https://portal.infocus.com/support/Product%20Pages/downloads.aspx?mic=LP70%2b&on=downloadsthen down load the file then find the text document "D3 D3+ firmware upgrade instructions.pdf" in C:\LP70plus\002-0870-08\I , or where ever you saved it. That will give you the complete instructions on how to upgrade.
Apr 27, 2011 | InFocus LP70+ Multimedia Projector
I have a 6year old infocus LP70 projector. its footstopped gripping, so i opened the case and bodged a permanent pastic knob to keep at an APPRPRIATE LEVEL - BU i SEPARATED TWO WIRES ON THE LINK BETWEEN...
if you are talking about the ribbon connection on the rear of the main board, then yes I would scrap it unless you want to try and find a LP70 on E-bay to use for parts. You may or may not get a good board but if the price is under 50 bucks it may be worth the risk.
Oct 16, 2010 | InFocus LP70+ Multimedia Projector
I cant get an image from the macbook pro onto the screen using my infocus lp70...help!!!
hi
check your input with remote control(key-menu)
there is different input that you have to select the one you connected in (RGB- analog- digital)
Jul 29, 2010 | InFocus LP70+ Multimedia Projector
Connection to laptop
make sure you are using the correct cable and you know they are good. also go into your desktop display and see if it allows you to select a source to select the projector.
Jun 21, 2010 | InFocus LP70+ Multimedia Projector
Infocus LP70 powers itself down after 30 seconds or so.
HI,,
ITS PROBLEM WITH URS PROJECTION CIRCUIT WHICH HAS BAD CAPACITORS..
JUST REPLACE THE CAPACITORS..
TNKS
RABBANEES
Nov 12, 2009 | InFocus LP 70 Multimedia Projector
InFocus LP70 projector is running hot
clean the dust out of it with canned air. the dust keeps in the heat that the projector is trying to expell. it also shortens the life of the lamp.
Sep 21, 2009 | InFocus LP70+ Multimedia Projector
InFocus LP70 color problem
try resetting the settings to factory default through the menu. if there's still a problem, take the cover off. if you look from the back of the machine, inside on the bottom left, you'll see the main board attached by a large white plug. use something thin and non-metalic to push the bottom of the board towards the plug to tighten it. now do the same to the other side of the plug. this should solve it. if it doesn't, you need to replace the main board.
May 11, 2009 | InFocus LP70+ Multimedia Projector
Cannot see computer displyed on output of infocus screen shot
Many laptop computers do not automatically turn on their external
video port when a projector is connected. On many laptops, the activation function key is labeled with an icon or the text CRT/LCD.
Try the Function Key with the Icon of a monitor to enable the external video port.
If that does work, look at the settings on the projector using the buttons on the top.
Check the "Default Source"
Default Source toggles among Computer 1 analog, Computer 1 digital, Computer 2, and Video. This determines which source the
projector checks first for active video during power-up. Highlight
Default Source and click the left or right mouse button to toggle
among the options.
Jan 12, 2009 | InFocus LP70+ Multimedia Projector
Infocus LP70 - It's all Green
A tinted image (whether green or another color) is almost always a symptom of a bad or damaged cable - or a loos cable connection. In your case, you'll likely need a new M1 to VGA cable (Part# SP-DVI-A-R).
Assuming that you've made sure that the cable connections are solid at both ends, there is a simple test to verify that this is a cable issue and not a costly projector issue. While the image is tinted green, open the menu. If the menu colors appear fine while the rest of the image is still tinted green it's the cable.
Nov 20, 2007 | InFocus LP70+ Multimedia Projector
Computers & Internet Logo
29 people viewed this question
David Payne
David Payne
