Question about Hotpoint 3.6 cu. ft. / 102 liter Upright Freezer RZA21
Water gathering in pipe in fridge and overflowing into fridge
  • 4 Answers
Hi you will find this is a common problem bits of food get into this outlet and it gets blocked you should have got a small tool with the freezer when you bought it if not use a small screwdriver or smilar item to unblock the hole and you will find this will solve the problem
Posted on Mar 21, 2011
Fix-ya
Find the water drain hole/pipe and clean it thoroughly with a pipe cleaner or other softish flexible rod. That should allow the water to drain away. Make sure back of the unit is clear and clean so water drains and evaporates off properly.
Jul 31, 2014 | Fisher Paykel ActiveSmart Fridge - 17 cu....
Freezer insulation
Could you fit a trace heater inside the drain tube to keep the ice from forming? Or extend the dripdown time after defrost cycle so the water doesn't accumulate? If the tech thinks the insulation has blown, it may be time to bite the bullet and replace the fridge.
Apr 18, 2014 | Freezers
My FRE 196A fridge won't drain.. is there a stopper in the drain. This has been the case since I bought it a year ago. When I pull out the veg drawer water under the drawer spills onto the floor and also...
To an evaporation tray. Some have coils to heat the water to evaporate it some have nothing some trays are incorporated into the compressor as it's base.
Oct 20, 2013 | Frigidaire Freezers
Water is dripping from the bottom of the fridge (slow drip). How do I fix it. I have a Maytag French Door stainless steel fridge (4-year-old) with freezer on the bottom.
There should be a drip tray catching the defrost water... it may be overfull... Try to remove it and empty it. The tray is actually supposed to have a heat evaporator to dry up the water before it overflows. Your may be fuller due to excessive frost also... from hot temperatures outside or opening the fridge too often or for too long... good luck!
Jul 24, 2011 | Freezers
Water leaking from underneath. Not currently
This could be a blocked drain.Behind the fridge is a hose/pipe running from the inside of the fridge down to the compressor where the water will then evaporate.If this pipe is blocked,the water will push up back into the fridge.Try to blow the hose clean from inside the fridge.This should solve your problem.
Regards
Andre Nagel
Mar 13, 2010 | Freezers
My Maytag side by side with water dispenser and ice maker doesn't work. We bought a house - never lived in - and the fridge and freezer work fine. We replaced the water filter and find that no water comes...
The sadle valve is located on the copper pipe where the tube attaches to your water pipe in the house. Shut the water off at the saddle valve. Remove the hose from the rear of the frig on the water inlet valve and put it into a pail. Tunr the water on at the saddle valve and see how fast the water comes out. Some times if the saddle valve is installed on the bottom of the copper pipe they will get corrosive and restrict water flow. Open and close the valve several times to make sure it is clear and reinstall the hose to the rear of the frig. Turn the water back on to see if it works.
Dec 29, 2009 | Freezers
My Bosch frostfree fridge freezer keeps icing up!
My Bosch Frost Free Fridge Freezer did the same thing - Ice forming in the bottom of the freezer area after a few days.
It was caused by a blocked drain pipe - When the freezer does the de-frosting cycle, the melted ice drips into a tray and tehn runs into a dish on top of teh compressor, through a pipe.
If this pipe gets blocked, the de frosted ice overflows from the tray and overflows into the bottom of the freezer and then re-freezes !
To fix, pull the freezer away form the wall, locate the pipe that runs to the dish on top of the compressor and blow through it - This should clear it. Alternatively, from inside the freezer compartment, pull off the cover at the back, but the clips holding it on will probably break off, as mine did ! You can sort of push the cover back on and re-fit the food draws.
Feb 23, 2009 | Freezers
Connecting to water supply
If you mean icemaker or water supply it's easy you just have to connect a water pipe 1/4 to your main water supply of your sink 1/2 inch. Just putting a valve first on the 1/2 pipe reducing to 1/4 & you bring it to your water valve solenoid of the fridge. That's it!
Francois
Dec 10, 2008 | Freezers
Kelvinator fridge
The freezer defrosts every day. the puddle is from that. It is supposed to go into a pan at the bottom and evaporate. You need to look at the pan and determine if it has a hole or the drain hose is leaking somewhere.
Feb 09, 2008 | Kelvinator 12 cu. ft. / 340 liter Chest...
Water dispenser / ice maker whirlpool fridge frezzer
Check that you haven't turned the ice maker off in the menu.
thanks J
Jan 15, 2008 | Freezers
Hotpoint 3.6 cu. ft. / 102 liter Upright Freezer RZA21 Logo
75 people viewed this question
Top Hotpoint Freezers Experts
AJMAL KHAN
Victor Nwachukwu
Victor Nwachukwu
Gerard Curran
Are you a Hotpoint Freezer Expert? Answer questions, earn points and help others
