Question about HP Pavilion zd8000 Notebook
My laptop has vertical lines about 3" at the bottom of the screem. where the start button
  • 3 Answers
No you are incorrect, it MAY be an indication of a bad LCD panel if the problem exist in the LCD internally. Does the issue occur on a different computer? If so, read on. There are external vertical and horizontal IC driver's respectively driving a RGB grid, notice how the line colors do not stay the same in relation to the background? You should check the ribbon cable(s) corresponding to the location of the vertical lines whether on the left, middle, and/or right side that typically travel from the bottom of the LCD and terminating to the vertical IC driver on the PCB. This COULD be the issue because I have a Cintiq 18SX interactive pen display that exhibited a related problem. One way to know for certain is to push gently on the bezel below the lines, if you see the color change or lines go away, that is most certainly your problem. You may push on the ribbon cable connectors firmly after disassembly, if symptoms completely disappear you can try hot gluing or any other non-permanent means to fasten the connector down using firm clamping force and/or replace the ribbon cables. Hope this helps, please keep me updated if it does!
Posted on May 05, 2011
    Sergeant:
  • 186 Answers
It sounds like you might have a bad LCD, or it could be a bad video chip on the mother board. You can check to see which one it it by simple connecting an external monitor to the laptop, if the same vertical lines show up on the external monitor then it;s the video chip on the mother board and you would have to have the mother board replaced. If the lines are not on the external monitor then it's the LCD on the laptop and you would have it replaced. Hope this helps
Please Rate and vote Thanks
Posted on Mar 17, 2011
  • HP Master
  • 6,771 Answers
Unfortunately this is not a good sign, it will be one of two things, the LCD panel is defective and will need to be replaced, or the video cable from the motherboard to the screen has come loose and must be reseated back in place. There should be a spare monitor hooked to the computer to rule out the video graphics card on the motherboard.
When plug is remove from laptop the screem get darker
This is natural. In the power settings, usually it is set to reduce the brightness when laptop is on battery power.
you can increase the brightness, but it will drain the battery quickly.
To increase or decrease brightness, use one of the buttons indicated on the keyboard with 'Fn' button on the bottom of the keyboard.
Thanks for using FixYa!
Sep 16, 2011 | Dell Vostro 1500 Notebook
I have a Nikon D100 with a Nikon AF Nikkor 24-85mm 1:2.8-4 D lens or a Nikon AF-S Nikkor ED 7-300mm 1:4-5.6G VR lens. I'm on vacation in Hawaii and am troubled by an error that appeared today. The...
Hi
i know what exactly the problem, but if your unit is under warranty go to Nikon service center the problem is in hardware and only Nikon can fix that..and only nikon have parts for that!
Thanks! Likha
Sep 23, 2008 | Nikon Cameras
Tip
How to Troubleshoot Vertical Lines on an LCD TV Screen
<p>There are two prevalent formats for video programming: full screen and wide screen. LCD TVs are designed to show a wide screen picture to go with high-definition (HD) programming. When standard-definition (SD) programming is watched on an LCD HDTV in its default settings mode, there will be two vertical lines on the right and left sides of the picture. You need to go into your TV settings menu to troubleshoot this issue.<br /> jQuery('.intro .thumbnail').each(function(i,e){ jQuery(e).find('img').one('error',function(){ jQuery(e).remove(); }); }); <span><br /></span> <span>Instructions</span> <ol> <li> 1 Press the "Menu" button on your remote control and open the "Picture Settings" sub-menu.<br /> </li> <li> 2 Select "View" from the list of options.<br /> </li> <li> 3 Choose a viewing mode that will eliminate the vertical lines. Select "Zoom" to crop the on-screen image to fit the screen. Select "Wide/Widescreen" to stretch the on-screen image to fit the screen, or select "Panoramic/Panorama" to stretch the sides of the onscreen image to fit the screen (recommended).<br /> </li></ol>
on Dec 27, 2010 | Televison & Video
"acer laptop lcd screen has
If has a green vertical line then it's definitely hardware problem. Either your graphics card or the lcd itself. the only possibility is to take it to a repair store.
May 24, 2011 | Computers & Internet
Blue vertical line on my desktop
The blue lines are a sign that the screen itself is failing. You can try to reseat the data cables from the motherboard to the back of the screen, but in most cases this is indicative of an immenent screen failure.
Jan 13, 2010 | ASUS G1SN-A1 Gaming Notebook PC
HP Pavilion Laptop - vertical lines on screen from top to bottom
this will more than likely be a video card issue. The bad news, on laptops, everything is integrated into the motherboard and and you will have to replace. Getting to the motherboard can be a pain.
Aug 06, 2009 | HP Pavilion zd8000 Notebook
Black Vertical line appeared on my Daewoo Plasma
Bad connection somewhere along the bottom or top of the panel, there are boards most likely along the bottom of the screen that control vertical drawing, a connection that breaks as it is heated up sounds about right. check the connectors along the bottom. Be very careful because if you wreck em the screen is junk. The connector that will be at fault will be in direct line with the black bar.
Oct 28, 2008 | RCA L26WD26D 26 in. LCD TV
Vertical lines o my desktop
Sounds like your video inverter is bad or possibly the screen is going bad
Jul 21, 2008 | Toshiba Satellite M65 Notebook
uninstall video driver reboot it should start on windows basic video drivers if it does and screen is good try reinstalling your original card drivers. or search on the net for updated ones
Jul 20, 2008 | Sis 6326, (4 MB) Graphic Card
HP Pavilion zd8000 Notebook Logo
132 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
