Question about Bosch 24 in. SHU43 Built-in Dishwasher
Shu43 built in dishwasher
Not drying dishes, and having problem finding someone in the Little Rock, AR area that works on Bosch dishwasers.
  • 117 Answers
Running the hot water in the sink until you get the water hot then, make shore you are using jet dry. Bosh dishwasher dry with condensation. Let me know
Posted on Aug 02, 2008
Bosch dish washer does not pump out water before drying cycle
either the pump is faulty or there is a blockage in the outlet drain.
if you hear pump working then clean the filter and the kitchen drain. If pump is not working then replace it.
Oct 06, 2011 | Bosch 24 in. SHU43 Built-in Dishwasher
My dishwasher does not dry the dishes
Check your heating element..
Dishwasher2_bing.gif Problems The Heating Element not Working
http://www.fixya.com/support/r4589033-dishwasher_problems_heating_element_not
Dishwasher2_bing.gif Maintenance
http://www.fixya.com/support/r4319937-dishwasher_maintenance
heatman101
Asker's Testimonial " expanation very clear. will give it a go and see how simple it was. thanks Ronnie " - ronnieshomes
Jul 17, 2010 | Bosch 24 in. SHU43 Built-in Dishwasher
My diswasher won't dry my dishes. It leaves them
if no rinse agent is present it doesnt matter how hot the water gets they will still not dry check unit make sure it is full. rinse agent is only to aid the drying process the machine will wash happily without it but not dry.
Feb 15, 2010 | Bosch 24 in. SHU43 Built-in Dishwasher
Bosch SHE43MO2UC/48 - Dishes do not dry properly
rinse aid is required to aid the drying process either it is underdosing or the wash programme is too short temps over 55 degrees are needed for satisfactory drying result.
Nov 08, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
The rinse agent light is on and the water will not spray out
NO WILL STILL WORK IS ONLY A FLOAT SWITCH TO WARN YOU,HOWEVER RINSE AGENT DOES AID THE DRYING PROCESS SO WITHOUT YOURE DISHES WILL BE WET AND SMEARY
Sep 06, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
My bosch dishwasher will not dry the dishes
this dw to save energy works this way- the final rinse will reach a temp of 161 F . the dishes have to absorb this heat. when the cycle is complete the dishes become a heater in themselves radiating the heat they absorbed during the final 161 F heat. If you have any tupperware or plastic dishes in the unit they will not absorb heat therefore not radiate the 161 f temp need to dry all the dishes. try to avoid plastic items and they must always have jet dry. this is the european way of conserving energy. on the old ge or whirlpool they had electric element in the bottom that would bake the dishes dry ....not these..but they do save alot of energy.. it helps right after a cycle to crack the door open release all the steam from the unit
Dec 07, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Dishwasher problem, Bosch
make sure u have jet dry in unit and put on higher number inside doors
Oct 02, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Bosch dishwaser
WHAT IS WRONG WITH YOUR DISHWASHER?
small_9_26.jpg For a detailed Dishwasher illustration, click below.
redarrow.gif Built in
Warning!To avoid personal injury or even death, always disconnect yourappliance from its power source--that is, unplug it or break theconnection at the circuit breaker or fuse box--before you do anytroubleshooting or repair work on your appliance. Also, because somecomponents may have sharp edges, use caution while working on yourappliance.
There's an error code on the digital display
It doesn't work at all
It cleans poorly
There's no water entering the machine
The water doesn't drain from the machine
It's noisy
It leaks
The dry cycle has problems
The door has problems
The cycle doesn't complete
I see an error code
The detergent cup doesn't open
The cycle times are too long
Hope this may help;
DON'T FORGET TO RATE;
Aug 14, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
SHU43 built in dishwasher
There is no heater element in bosh D/W
Problaby, your hot water is not hot enough and I don't know nobody in your area.Your water heater in your home should be set at 120-140 degrees, read the book to make sure.
Aug 02, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Dishwaser is stuck in Rinse/Dry cycle
It could be a sensor or timer solenoid in the dishwasher maybe broken and needs replacing.
http://www.repairclinic.com/bosch-dishwasher-parts-gg.htm
Apr 05, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Bosch 24 in. SHU43 Built-in Dishwasher Logo
187 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
prem mathew
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
